The device cannot find the hard drive after reloading the device tree
Today, I updated Jetson Linux to 36.3, and installed jetpack6.0 on Jetson Orin NX 8GB. Then restarting the device, I modified the device-tree to load a new camera.
/opt/nvidia/jetson/jetson-io/jetson-io.py
Then device encountered this issue.
ERROR: mmcblk0p1 not found
log麻煩抓文字檔 你拍這樣什麼都看不出來
還有你的jetson-io改了什麼東西
Firstly, the device is currently stuck at the boot screen, so I am unable to capture any text.
The key information is that ERROR: mmcblk0p1 not found.
Additionally, I selected a camera in “Configure Jetson 24pin CSI Connector.”
學一下怎樣抓log
Due to the device being stuck at the boot screen, I rebooted the device and connected an HDMI display, which showed no signal. I have to flash the device.
The correct logs is right part of picture. Upon comparison with the previous logs, I noticed an issue here.
I want to know the reason.
Do you have any problem understanding how to capture log or not?
Your partial log in screenshot totally does provide detailed info…
mmcblk0p1 means trying to booting from sdcard or emmc. There is no such thing existed on a Orin NX. Do you want to find out why it happened? Dump the log as we said.
