I flashed my device Jetson Orin Nano 8GB dev kit (dual boot with an external drive, Ubuntu 22.04) . After flashing, I took the device out of recovery mode, and booted the device. The display goes blank after the initial logo. A portion of the serial is included:
output.txt (36.4 KB)
However, I am able to ssh into the device, and login
Screenshot from 2025-03-28 11-28-59|580x500
Is is possible the display issue is connected to login. Is there a way to fix the display update so that I can operate the device independently?
How do you flash your device?
Could you provide the commands or method to flash your device?
Also some questions to confirm:
Is your Orin Nano a dev kit or a custom boards?
Hello - I used the SDK manager. I installed jetpack 6.1 using a dual booted version of Ubuntu 22.04
I have the 8GB dev board
kayccc
April 9, 2025, 2:52am
7
Yes, this is still an unresolved issue
Please boot again, ssh to the device and record below for us to review:
/var/log/Xorg.0.log
The output of lsmod saved to a file: lsmod > lsmod.txt
The output of dmesg saved to a file: dmesg > dmesg.txt
ps aux | grep gdm3
01_Xorg.0.log.txt (18.7 KB)
02_lsmod.txt (6.2 KB)
03_dmesg.txt (59.4 KB)
root 960 0.0 0.1 241412 8072 ? Ssl 19:32 0:00 /usr/sbin/gdm3
user 2052 0.0 0.0 8620 2044 pts/0 S+ 20:00 0:00 grep --color=auto gdm3
The log you provided is similar in topics .
Please use the sdk manager to flash your device again and check whether issue exist.
