Jetson orin nano has no display when starting up the card. I can’t even provide logs, as I can’t even see anything on the screen. The green light is ok, so I think the power is ok. I have flashed again the SD card, but it does not change anything. Is it possible that the card is dead ?
Which JetPack version you flashed on SD card?
Could you try to have a Ubuntu host PC to ownload SDK Manager to your host and follow user guide steps to re-flash BSP on your device?
Download link: SDK Manager | NVIDIA Developer
User Guide: NVIDIA SDK Manager Documentation — SDK Manager 2.1.0 documentation
Install Jetson Software with SDK Manager — SDK Manager 2.1.0 documentation
Falshed jetpack 6.0.
I will follow your recommandations.
Actually the board was working well but I reset settings in the bios, then the board crashed and nothing worked after that.
I have tested to communicate with the board using serial console and putty and the console remains locked after:
ASSERT [FvNorFlashStandaloneMm] /out/nvidia/optee.t234-uefi/StandaloneMmOptee_RELEASE/edk2-nvidia/Silicon/NVIDIA/Drivers/FvbForFlashDxe/FvbNorFlashStandaloneMm.c (937): ((BOOLEAN) (0==1))
Don’t understand that. And putty is locked, I can’t write anything after this line.
Please refer to the following thread to flash QSPI only to recover from this.
Re-Flash AGX Orin without flashing APP partition - #8 by KevinFFF
