My orin nano was working fine but i have tried installing jetpack 5.0.2 and 6.0 with flashing sd card method when i connect to display. But in display no output no hdmi signal. Kindly give me any solutions please. Sorry my English may be bad.
Please re-flash with SDK Manager first.
While flashing in sdk manager I encounterd errors here is the log
and Thanks for replying brother.
Dump the log, please.
Also, are you using a DevKit?
By saying HDMI I feel like it’s not. Or you don’t know what I am talking about?
Yes I am using devkit.
We use Display port to hdmi converter so that I meant HDMI.
I didn’t even see any logos like NVIDIA.
Is there any chance of hardware issues.
We still need the log to check.
Also, you need an active DP to HDMI cable in case it’s not.
Logs are there in the drive link.
We also have normal Jetson nano devkit (4gb version). In that if I connect to HDMI port it is working. But when I connect with d port it is not. I have checked that dp cable it works fine with the systems.
When I try to connect with serial like Jetson hacks it keeps on booting
After this when I click continue or else if I leave it for sometime again it boots.
Is it what you got when flashing the device?
I don’t believe this is log from JetPack 6.
UEFI version is still 35.4.1, which means JetPack 5.1.2.
What should I need to do now?
Make sure you are really flashing JetPack 6, and attach both flashing log from SDK Manager and serial console log from the device during flashing.
I have flashed with sd card
Do you know what I said here?
Sorry What do you meant for log.
The screenshot says Jetson UEFI firmware (version 4.1)..., which means it’s log from JetPack 5.1.2 instead of JetPack 6.0, so clearly your previous attempt to flash JetPack 6.0 did not succeed.
That’s why I told you to do this.
I have tried again flashing with sdk manager and I’ve got it.
Thank you soo much and sorry for wasting your time.
Small doubt I need to work with ROS but in forum they’ve told that there is no ROS support currently. What shall I do to work with Ros. The reason I was changing the OS is to work with ROS.
Maybe consider this:
