when I was installing Cuda 10.2 on a new laptop (GeForce RTX graphic card and window 10 ) this error came out :
The flowing processes must be stopped before the CUDA Visual studio integration installation can proceed Performance Monitor(Process ID : 12244)
this id has changed every time I reboot and I haven’t seen such A error before pls help :)
I have the same issue with an older GeForce GT 710 when installing CUDA version 11.0 on Windows 10.
The following processes must be stopped before the CUDA Visual Studio Integration installation can proceed:
Monitor (Process ID 2552)
With the number changing after each reboot.
Solution: you must close the two ASUS GPU TweakII Monotors that are opened on startup.
