The following processes must be stopped before the Nsight Compute integration installation can proceed
I cant install Nvidia Cuda, Can someone help me ? I used RTX 4060
Hi, @xitai_squall
Seems there is some conflict.
Can you please choose “custom” installation and deselect “Nsight Compute” to install, with the same method, you can install “Nsight Compute” separately again if you need.
I tried to follow the instructions, I did not select the 2 items Nsight Compute & Nsight Visual Studio Edition.
Can you please reboot to try again ?
I have tried many times
This is what I found.
  • Performance Monitor: If you see an error like “The following processes must be stopped before the Nsight Visual Studio Edition installation can proceed: Performance Monitor (Process ID: XXXX)”, open Task Manager, find the Performance Monitor process, and end it. After doing this, retry the installation; it should proceed normally.
Have you tried checking in “Task Manager” ?
