Summary:
Need to run both SPI & OpenCV in Jetson TK1. First, I successfully installed The Grinch Kernel with SPI support, as instructed:
[url]http://neurorobotictech.com/Community/Blog/tabid/184/ID/12/Using-the-Jetson-TK1-SPI--Part-2-Configuring-the-kernel-for-SPI.aspx[/url]
OpenCV was missing after the installation. Tried to install optimized OpenCV4Tegra as instructed in Jetson/Installing OpenCV - eLinux.org and got the error:
dpkg: error processing archive libopencv4tegra_2.4.10.1_armhf.deb (–install):
cannot access archive: No such file or directory
Errors were encountered while processing:
Then updated the Jetson with sudo apt-get update, now the Jetson is in infinite login loop.
Question:
How should I install OpenCV? Please note that OpenCV efficiency is quite critical for my high speed camera application.
Thank you
