Hi:
I tried to adapt the imx390-gmsl2 camera module on Linux36.2.0. The driver was loaded successfully and the correct frame rate was printed using the v4l2-ctl command. As shown in the picture below:
After this, I used the dmesg command to view the log when printing the frame rate, the specific information is shown below:
Did you have any modify for the imx390 kernel driver or device tree for the sensor mode?
