The IsaacSim4.2 is very unstable on a PC with 4 GPUs
On a PC with 4 GPUs, the following operations cause crashes. It is very unstable.
Is there any solution for this issue ?
*NOW I am using the IsaacSim4.2 by a single GPU.
*Composer work well by 4 GPUs.
Environment:
HP Z8 G5
GPU RTX RTX6000 ADA x 4GPUs (Driver 553.09: latest)
  • I tried to use Driver 537.70 , the result was same.(IsaacSim4.2 was freese)
    Memory 128 G
    Windows11
Operations01:
1.Start IsaacSim4.2
2.RenderringMode is Renderer(Real-Time)
3.Change Rendering Parameter for Renderer(Real-Time)
Automatic Tilling : OFF
Tile Count : 1 ----> 4 ←—(Try to change from 1 to 4)
Tile Overlap : 128
GPU 0 Weight 0.0
Mult-Treading : ON
4.When I change “Tile Count” . Apllication was freeze
5.Crash Report (Already pressed the Subject Button)
Operation02:
1.Start IsaacSim4.2
2.RenderingMode is Renderer(Real-Time)
3.Just change RenderingMode from Renderer(Real-Time) to RTX – Interactive (Path Tracing).
4. Apllication was freeze
5. Crash Report (Already pressed the Subject Button)
Could you also attach the crash reports here? Thanks.
@VickNV
Thank you for your reply.
I upload two log files.
Operation for LOG1
  • Start IsaacSIm4.2
  • Just change RenderingMode from Renderer(Real-Time) to RTX – Interactive (Path Tracing).
Operation for LOG2
  • Start IsaacSIm4.2
  • Change Rendering Parameter for Renderer(Real-Time)
LOG1.txt (3.1 KB)
LOG2.txt (3.9 KB)
Additional Information:
I see SYSTEM LOG for Windows 11 , it is no GPU error.
@VickNV
I uploaded the log. Is there anything else you need?
