The new driver(319.17) don't save the colors with nvidia-config
The new dirver 319.17 has a bug that had been fixed in 313.30
If you open nvidia-config > GPU 0 > DFP-O > “Color Correction” and set the colors (ganma, brigh and contrast), when you re-open nvidia config or reboot THIS CONF DON’T SAVE. This bugs was fixed in the 313.30 version, but now this bug is here again.
< My system >
  • OpenSUSE 12.3 (x86_64)
  • KDE 4.10.2
  • Kernel 4.7.10-1.1
  • Nvidia GT 440 (Gigabyte)
Can you please attach your .nvidia-settings-rc file from after you adjusted those options?
I confirm this with nvidia-settings version 319.17 and 319.23.
It applies changes but doesn’t load them.
Here is example of what nvidia-settings writes to -rc file after I change/apply values and exit:
silverstone:0[dpy:5]/RedBrightness=-0.150000
silverstone:0[dpy:5]/GreenBrightness=-0.150000
silverstone:0[dpy:5]/BlueBrightness=-0.150000
silverstone:0[dpy:5]/RedContrast=-0.150000
silverstone:0[dpy:5]/GreenContrast=-0.150000
silverstone:0[dpy:5]/BlueContrast=-0.150000
silverstone:0[dpy:5]/RedGamma=1.234000
silverstone:0[dpy:5]/GreenGamma=1.234000
silverstone:0[dpy:5]/BlueGamma=1.234000
It doesn’t work that way. If I open nvidia-settings and just exit, it writes default zeroes and 1.0 gamma to -rc, but still never load them. Other entries in -rc file are not corrupted.
So I created separate file with corrected entries that do apply and load them with nvidia-settings -l --config=~/tmp/.nvidia-settings-rc
[DFP-4]/RedBrightness=-0.150000
[DFP-4]/GreenBrightness=-0.150000
[DFP-4]/BlueBrightness=-0.150000
[DFP-4]/RedContrast=-0.150000
[DFP-4]/GreenContrast=-0.150000
[DFP-4]/BlueContrast=-0.150000
[DFP-4]/RedGamma=1.234000
[DFP-4]/GreenGamma=1.234000
[DFP-4]/BlueGamma=1.234000
Thanks for the bug report. We’ve identified the problem and it should be fixed in a future driver release.
319.32 does not fix this problem.
Same behavior as previous versions; nvidia-settings overwrites nvidia-settings.rc with default values.
I confirm this in the “new” driver 319.32.
For me, this is a very, very importart feature, please fix the bug.
Please try 325.08.
325.08 tested on two PCs.
HP Pavilion Desktop t3540 - GeForce GF 8400GS
HP Pavilion Laptop dv7-3140 - GeForce GT 320M
Works perfectly!
nvidia-settings starts immediately and does not overwrite nvidia-settings.rc
Yes, now works perfectly!
THANKS. Nvidia RULZ!
