The recorder-qt failed when I try to record with CAN interface at driveworks 0.6
I want to use recorder-qt of drivework-0.6 for recording camera & can, but it failed.
There’s no problem to record camera only. However, If I add configuration for can for recorder-qt, then it shows fail sign on the screen. Of course, the configuration file was working well at drivework-0.3.
If I try to test CAN interpreter, it is working very well. So it is not problem of CAN interface.
I wish I could report this symptom as another bug of driveworks 0.6.
