SW Version: DRIVE-V5.1.6-E3550-EB-Aurix-With3LSS-ForHyperion-StepA-3.05.04
Complation date: Jun 25 2019, 14:25:36
When we are using socket.can drivers from Can 1&2 and/or Can 6&4 we can record data successfully. But when we are using Aurix can we can see the messages with “sample-canbus-interpreter” but recorder fails to record the data.
Error occurs as follows:
We run recorder gui with required json file.
Recorder sees the storage.
Recorder successfully calculates sensor statistics shows how much kb/s will be recorded.
Then when I press “Start recording” button it says failure and gives the following error in terminal:
Error: one of the recorders abruptly exited!recorder-qtgui: recorderSendCmd: failure!
Error: timeout unable to stop recorder2 gracefully!
Sorry. Let me rephrase my question; you said sample_canbus_logger works with aurix can. Does recorder-qtgui recording only the same aurix can work? If not, please provide the command and relevant files you are using.
Does the issue only happen with both “can.socket” and “can.aurix” existing in rig file? Could you provide your command and narrowed down rig file for our reproducing?
Issue does not appear when I record the exact same CAN network using the socketCAN.
When I am using aurix CAN I am able to see sensor statistics but problem occurs when I press start recording button.
My recorder command for socketCAN and aurix can respectively:
/path/to/recorder/recorder-qtgui /path/to/rig/canbus.json
/path/to/recorder/recorder-qtgui /path/to/rig/aurix-record.json
We haven’t tested the recording tools with Aurix CAN. But per below topic, on DRIVE Software 9.0, the developer was able to record Aurix CAN with “recorder” tools (instead “recorder-qtgui”). Though he still hit playback speed issues with “replayer” tool.
We will inform you here once we decided to support Aurix CAN recording with our recording tools.
Moreover, below topic is an example of a short-term alternative for your problem; the developer was using USB to CAN device. FYR.
