Configuring Aurix to forward extended CAN frames
Continuing the discussion from Configuring CAN Channels on the Drive Xavier:
Software Version
DRIVE OS Linux 5.2.0
DRIVE OS Linux 5.1.6
other DRIVE OS version
other
Hardware Platform
other
I have a Drive AGX Xavier setup connected to 3 different can buses [CANA, CANB and CANF]. While I am able get the data on CANB and CANF (Socket CAN) , I am unable to read data in CANA (Aurix) using the ./sample_canbus_logger.
Below is the command and output to read data on CANA (custom.conf file is attached):
/usr/local/driveworks/bin/sample_canbus_logger --driver=can.aurix --params=ip=10.42.0.146,config-file=/home/nvidia/custom_repo/config/easy_can/custom.conf,bus=a --filter=""
Program Arguments:
--driver=can.aurix
--filter=
--hwtime=1
--offscreen=0
--profiling=1
--send_i_understand_implications=0
--send_id=6FF
--send_size=8
[06-08-2021 19:14:30] Platform: Detected DDPX - Tegra A
[06-08-2021 19:14:30] TimeSource: monotonic epoch time offset is 1628263552705149
[06-08-2021 19:14:30] PTP Time is available from NVPPS Driver
[06-08-2021 19:14:31] Platform: number of GPU devices detected 1
[06-08-2021 19:14:31] Platform: currently selected GPU device integrated ID 0
[06-08-2021 19:14:31] SDK: Resources mounted from /usr/local/driveworks-2.2/data/
[06-08-2021 19:14:31] SDK: Create NvMediaDevice
[06-08-2021 19:14:31] egl::Display: found 1 EGL devices
[06-08-2021 19:14:31] egl::Display: use drm device: drm-nvdc
[06-08-2021 19:14:31] TimeSource: monotonic epoch time offset is 1628263552705149
[06-08-2021 19:14:31] PTP Time is available from NVPPS Driver
[06-08-2021 19:14:31] Initialize DriveWorks SDK v2.2.3136
[06-08-2021 19:14:31] Release build with GNU 7.3.1 from heads/buildbrain-branch-0-gca7b4b26e65 against Drive PDK v5.1.6.1
[06-08-2021 19:14:31] SensorFactory::createSensor() -> can.aurix, ip=10.42.0.146,config-file=/home/nvidia/custom_repo/config/easy_can/custom.conf,bus=a
[06-08-2021 19:14:31] EndpointUDP: started 10.42.0.146:50000
custom.conf (242 Bytes)
All messages coming on my can bus are Extended Frames
Using an external can tool I tried to send a standard CAN frame on CANA and I was able to see the data forwarded (the config file was modified for standard can frames). when I sent an extended frame it had no output, How do I get it working with Extended frames?
Note I went through the easy can setup guide and was able to read data using the demo files provided after configuring the messages correctly (using aurix_configure_easy_can.py and aurix_tegra_a_send_receive.py). This confirms the data is being received by aurix.
Hi @anil-kumar.chavali ,
The extended frame isn’t support in DriveWorks 2.2.
