Hi there,
We are planning to use multiple RADARs that each require dedicated CAN sockets. Since only two of the CAN buses(CAN2, CAN6) are directly accessible from Xaviers, we are planning to use CAN interface hardware for additional CAN sockets (maybe similar to this one). I came here to ask about if anyone used such a tool and whether they had driver problems etc. If so, how did you connected (via M.2, or Mini-SAS).
Additionally, I inspected Confused about CAN stuff: mttcan, mttcan-ivc and nvhvseccan - DRIVE 4.1.8.0 and have similar questions which isn’t answered in that topic such as whether can aurix drivers provide socketcan interface etc.
Thanks in advance, platform information is as follows:
Drive_AGX_EB_AURIX_Software_UserGuide.pdf in ~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/utils/scripts/DRIVE-V5.1.6-E3550-EB-Aurix.zip in your host system.
I saw Easy CAN Usage section of the documentation, there I could see that those 4 CAN channels are quite limited and require custom API (no socketcan) which does not help us since our sensor requires socketcan. I asked that additional question just to make things more clear, thx @VickNV. Also will check other pdf you mentioned but my priority is driver issues that might be seen when additional CAN hardware (from PCI) is used.
