Recording tool throw an error
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
When I start the Recorder tool with this command:
cd /usr/local/driveworks/tools/capture
./recorder-tui OR <rig_directory> [–bbr]
i get the error "fail to run rig legacy converter. What does it excatly mean? I tried it with several rig-files.
Hi, @eunow
Please provide the complete command (with the rig file) and its output for our analysis and reproducing. Thanks.
Command:
./recorder-tui /home/nvidia/rig/rig.json
Output:
-Rig rig.json
Copying rigs and setup code
Platform setup..
ERROR @rig : cmd: ['sudo', '/usr/local/driveworks-2.2/tools/capture/scripts/rig-legacy-converter' , '/tmp/recorder-5393/rig.json'.'/tmp/recorder-5393']
stdout: b'' stderr: b'Traceback (most recent call last):\n File "/usr/local/driveworks-2.2/tools/caputre/scripts/rig-legacy-converter", line 136, in <module>\n protocol = sensor[\'protocol\']\nKeyError: \'protocol\'\n'
Error: fail to run rig legacy converter.
Please also provide the rig file so we can reproduce the issue here. Thanks.
Dear @eunow,
It looks like the rig file is not complete. Could you share the other rig files too used in the shared rig.json
Dear @eunow,
I could reproduce the issue on my machine. It seems the issue is at line 136 in rig-legacy-converter python script. You may print sensor object value at line 136 in tools/capture/scripts/rig-legacy-converter It is checking for protocol parameter in the sensor object which is failing when you use json-merge based Json files. Could you use a single Json file similar to configs/rwd/hyperion7_1/release.json instead of multiple Json files.
Thank you, I will try!
Dear @SivaRamaKrishnaNV,
I used a single json file. This time I get the following error:
And all error logs are empty.
Please make sure the below sample_radar_replay sample work with the settings in your rig file first.
/usr/local/driveworks/doc/nvsdk_html/dwx_radar_replay_sample.html
The radar_replay_sample works fine with this rig-file.
Could you share your sample_radar_replay command and its output for our reference? Thanks.
This is the command and output on my host-pc with recorded radar data and playback with can-utils.
./sample_radar_replay --protocol=radar.custom  --params=decoder-path=/home/nvidia/dw_samples/build/src/sensors/plugins/radar_plugin_ars408/libradar_plugin_ars408.so,device=vcan0,dbc-path=/home/nvidia/dw_samples/ars408.dbc
[21-10-2021 15:44:33] Platform: Detected Generic x86 Platform
[21-10-2021 15:44:33] TimeSource: monotonic epoch time offset is 1634829945207093
[21-10-2021 15:44:33] Platform: number of GPU devices detected 1
[21-10-2021 15:44:33] Platform: currently selected GPU device discrete ID 0
[21-10-2021 15:44:33] SDK: Resources mounted from /usr/local/driveworks/data/
[21-10-2021 15:44:33] Initialize DriveWorks SDK v2.2.3136
[21-10-2021 15:44:33] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[21-10-2021 15:44:33] SensorFactory::createSensor() -> radar.custom, decoder-path=/home/nvidia/dw_samples/build/src/sensors/plugins/radar_plugin_ars408/libradar_plugin_ars408.so,device=vcan0,dbc-path=/home/nvidia/dw_samples/dbc-and-can/ARS408/dbc/ars408.dbc
[21-10-2021 15:44:33] SensorFactory::createSensor() -> can.socket, device=vcan0
[21-10-2021 15:44:33] CANSocket: Cannot get current state of hardware time stamping: ioctl(SIOCGHWTSTAMP, vcan0) -> No such file or directory
[21-10-2021 15:44:33] CANSocket: software based timestamps will be used for vcan0
[21-10-2021 15:44:33] DBC Parser: Ignoring message 'VECTOR__INDEPENDENT_SIG_MSG' at line 39 (dummy message, unused signals):
BO_ 3221225472 VECTOR__INDEPENDENT_SIG_MSG: 0 Vector__XXX
CAN DBC parsed results:
numMessages: 17
numSignals: 137
numSignalsExtendedValueType: 0
numIgnoredMessages: 1
numInvalidMessages: 0
numInvalidSignals: 1
numInvalidSignalsExtendedValueType: 0
[21-10-2021 15:44:33] Initialize DriveWorks VisualizationSDK v2.2.3136
[21-10-2021 15:44:33] Initialize DriveWorksGL SDK v2.2.3136
[21-10-2021 15:44:33] GL-SDK: initialize OpenGL
[21-10-2021 15:44:33] CANSocket: ioctl(SIOCSHWTSTAMP, vcan0) failed -> No such file or directory. Cannot enable HW timestamps, try with root user.
[21-10-2021 15:44:33] CANSocket: use SW based timestamps for vcan0
[21-10-2021 15:44:33] CANSocket: started vcan0
Timing results:
Thread main:
-onProcess                CPU:   171us, std=11901       | GPU:   158us, std=11978       | samples=2558
-onRender                 CPU:   413us, std=2477       | GPU:   255us, std=2591       | samples=159
[21-10-2021 15:44:41] Sensor statistics for: can.socket, device=vcan0
[21-10-2021 15:44:41] Events: 0
Errors: 0
Drops: 0
minDelta: 2.0000000
maxDelta: 66036.0000000
meanDelta: 860.925049
Standard deviation: 5804.131836
Inconsistent timestamps skipped: 210
Before looking into this log, may I know if sample_radar_replay also works with the relevant settings on your target system?
Yes, sample_radar_replay works properly.
Please try with recorder (/usr/local/driveworks/doc/nvsdk_html/dwx_recorder_textui_tool.html) first and see if it works. Thanks.
