Start isaacsim on the server using virtual desktop, but the screen display is very fuzzy, heavily pixelated and smeared, try to modify the rendering method and use webrtc mode have no effect, what kind of method we use to troubleshoot
Version: isaac_sim-2023.1.1
Both the official environment scene model and your own scene model have the same problem
Hi @litao_bate - Can you share more info about your setup as well?
Hi. Which version of drivers are you running?
It looks like the A800 does not have RT cores. I’m not sure if that is the issue.
Try updating to the latest 525 or 535 drivers. You could also try disabling ECC too.
As far as I know, A800 is GPU for AI/HPC, not suitable for 3d rendering. It only has CUDA/Tensor cores, no RT core.
Yes. I’m afraid the A800 is not supported for Isaac Sim. We require an RTX capable GPU that has RT cores.
