I am using a custom carrier board with Orin NX 16G.
When doing the jetson_benchmarks,there are a bunch of
XXX-throttle-alert cooling state: 1 -> 0
XXX-throttle-alert cooling state: 0 -> 1
The XXX are include soc1, cpu and gpu.
And the jetson_benchmarks score are lower than expected.
Does this bunch of XXX-throttle-alert cooling state alert affect the performance and is this normal?
$ sudo nvpmodel -q
[sudo] password for a:
NV Power Mode: MAXN
0
$ sudo python3 benchmark.py --model_name unet --csv_file_path \
/home/a/jetson_benchmarks/benchmark_csv/orin-nx-16gb-benchmarks.csv \
--model_dir /home/a/jetson_benchmarks/models/ \
--jetson_clocks
Please close all other applications and Press Enter to continue...
Setting Jetson orin in max performance mode
Jetson clocks are Set
------------Executing unet-segmentation------------
---------------------- 85.45806499999998 0 0
Model Name: unet-segmentation
FPS:93.61
Wall Time for running model (secs): 969.5726177692413
sh: 1: cannot create /sys/devices/platform/pwm-fan: Is a directory
[ 931.283443] soc1-throttle-alert cooling state: 1 -> 0
[ 931.451222] soc1-throttle-alert cooling state: 0 -> 1
[ 931.458622] soc1-throttle-alert cooling state: 1 -> 0
[ 931.494839] soc1-throttle-alert cooling state: 0 -> 1
[ 931.504166] soc1-throttle-alert cooling state: 1 -> 0
[ 931.552316] soc1-throttle-alert cooling state: 0 -> 1
[ 931.558819] soc1-throttle-alert cooling state: 1 -> 0
[ 931.653481] soc1-throttle-alert cooling state: 0 -> 1
[ 931.660339] soc1-throttle-alert cooling state: 1 -> 0
[ 931.683410] soc1-throttle-alert cooling state: 0 -> 1
[ 931.693798] soc1-throttle-alert cooling state: 1 -> 0
[ 931.727101] soc1-throttle-alert cooling state: 0 -> 1
[ 931.734315] soc1-throttle-alert cooling state: 1 -> 0
[ 931.812122] soc1-throttle-alert cooling state: 0 -> 1
[ 931.818657] soc1-throttle-alert cooling state: 1 -> 0
[ 931.828193] soc1-throttle-alert cooling state: 0 -> 1
[ 931.837912] soc1-throttle-alert cooling state: 1 -> 0
[ 931.871888] soc1-throttle-alert cooling state: 0 -> 1
[ 931.880813] soc1-throttle-alert cooling state: 1 -> 0
[ 932.002971] soc1-throttle-alert cooling state: 0 -> 1
[ 932.009528] soc1-throttle-alert cooling state: 1 -> 0
[ 932.090320] soc1-throttle-alert cooling state: 0 -> 1
[ 932.097107] soc1-throttle-alert cooling state: 1 -> 0
[ 932.117893] soc1-throttle-alert cooling state: 0 -> 1
[ 932.124464] soc1-throttle-alert cooling state: 1 -> 0
[ 932.133960] soc1-throttle-alert cooling state: 0 -> 1
[ 932.142722] soc1-throttle-alert cooling state: 1 -> 0
[ 932.265042] soc1-throttle-alert cooling state: 0 -> 1
[ 932.271556] soc1-throttle-alert cooling state: 1 -> 0
[ 932.366241] soc1-throttle-alert cooling state: 0 -> 1
[ 932.374126] soc1-throttle-alert cooling state: 1 -> 0
[ 932.423669] soc1-throttle-alert cooling state: 0 -> 1
[ 932.430296] soc1-throttle-alert cooling state: 1 -> 0
[ 932.540978] soc1-throttle-alert cooling state: 0 -> 1
[ 932.547706] soc1-throttle-alert cooling state: 1 -> 0
[ 932.917989] soc1-throttle-alert cooling state: 0 -> 1
[ 932.924744] soc1-throttle-alert cooling state: 1 -> 0
[ 978.530614] cpu-throttle-alert cooling state: 0 -> 1
[ 978.655596] cpu-throttle-alert cooling state: 1 -> 0
[ 978.661674] cpu-throttle-alert cooling state: 0 -> 1
[ 978.686582] gpu-throttle-alert cooling state: 1 -> 0
[ 978.692016] gpu-throttle-alert cooling state: 0 -> 1
[ 978.717684] cpu-throttle-alert cooling state: 1 -> 0
[ 978.723817] cpu-throttle-alert cooling state: 0 -> 1
[ 978.731539] cpu-throttle-alert cooling state: 1 -> 0
[ 978.737964] cpu-throttle-alert cooling state: 0 -> 1
[ 978.745237] cpu-throttle-alert cooling state: 1 -> 0
[ 978.752342] cpu-throttle-alert cooling state: 0 -> 1
[ 978.759139] cpu-throttle-alert cooling state: 1 -> 0
[ 978.765379] gpu-throttle-alert cooling state: 1 -> 0
[ 978.770874] cpu-throttle-alert cooling state: 0 -> 1
[ 978.780204] cpu-throttle-alert cooling state: 1 -> 0
[ 978.792983] gpu-throttle-alert cooling state: 0 -> 1
[ 978.804870] gpu-throttle-alert cooling state: 1 -> 0
[ 978.826334] gpu-throttle-alert cooling state: 0 -> 1
[ 978.832691] cpu-throttle-alert cooling state: 0 -> 1
[ 978.839201] cpu-throttle-alert cooling state: 1 -> 0
[ 978.845481] cpu-throttle-alert cooling state: 0 -> 1
[ 978.851975] cpu-throttle-alert cooling state: 1 -> 0
[ 979.863693] gpu-throttle-alert cooling state: 1 -> 0
[ 985.021066] gpu-throttle-alert cooling state: 0 -> 1
[ 986.039110] gpu-throttle-alert cooling state: 1 -> 0
[ 986.125477] gpu-throttle-alert cooling state: 0 -> 1
[ 986.131707] gpu-throttle-alert cooling state: 1 -> 0
[ 986.167090] gpu-throttle-alert cooling state: 0 -> 1
[ 986.173312] gpu-throttle-alert cooling state: 1 -> 0
[ 986.275274] gpu-throttle-alert cooling state: 0 -> 1
[ 986.281174] gpu-throttle-alert cooling state: 1 -> 0
[ 1015.583481] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.622952] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.629821] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.638662] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.647253] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.655590] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.672070] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.680912] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.689213] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.697419] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.712662] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.754439] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.760937] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.769523] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.778048] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.786277] cpu-throttle-alert cooling state: 0 -> 1
[ 1015.794575] cpu-throttle-alert cooling state: 1 -> 0
[ 1015.802285] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.822496] cpu-throttle-alert cooling state: 1 -> 0
[ 1016.843884] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.850740] cpu-throttle-alert cooling state: 1 -> 0
[ 1016.859169] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.867617] cpu-throttle-alert cooling state: 1 -> 0
[ 1016.875683] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.884104] cpu-throttle-alert cooling state: 1 -> 0
[ 1016.974890] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.981846] cpu-throttle-alert cooling state: 1 -> 0
[ 1016.990232] cpu-throttle-alert cooling state: 0 -> 1
[ 1016.998521] cpu-throttle-alert cooling state: 1 -> 0
[ 1017.119730] cpu-throttle-alert cooling state: 0 -> 1
[ 1017.126600] cpu-throttle-alert cooling state: 1 -> 0
[ 1017.135143] cpu-throttle-alert cooling state: 0 -> 1
[ 1017.143314] cpu-throttle-alert cooling state: 1 -> 0
