When adapting the clear HDR mode of the sony imx662, it was found that the brightness of the image increased significantly when switching to clear HDR mode, and it did not look like the merged image. Here are the photos taken in linear mode:
hello ShaneCCC,
I am currently using Linux version 35.4.1 and Jpack version 5.1.2. I modified the isp file according to the reference article, and took the photos in linear mode and clear HDR mode under the same conditions.
Below is a photo taken in linear mode:
hello ShaneCCC,
I tried to use the camera to shoot different scenes, but in clear HDR mode, the picture still contained noise.I tried to change the gain of the two images by keeping the exposure time fixed when shooting the same scene, but this did not change the image too much, so I am not sure if the current output image is a composite of two frames.
yes, the isp digital gain is always set to 1. But the noise is still there. I would like to know whether the following parameters need to be configured in the device tree for clear HDR mode:
num_of_exposure = “”;
num_of_ignored_lines = “”;
num_of_lines_offset_0 = “”;
num_of_ignored_pixels = “”;
num_of_left_margin_pixels = “”;
num_of_right_margin_pixels = ““;
The clear hdr mode given by sony should be similar to the dol mode, and the clear hdr mode is the fusion of two frames with different gains. But I’m not sure how to configure the corresponding parameters.
Yes, I have configured it to DOL mode, but in the configuration provided by the sensor manufacturer, the output is 12bit, but the kernel does not support the dol mode output of 12 bits. How should I configure the kernel to support dol 12-bit output?
The following is a diagram of clear hdr, if it is considered as dol mode, how should the following parameters be configured?
I configured the clear hdr mode according to dol mode. When I previewed the mode with argus_camera, I found that the overall resolution and color of the image were not normal, and there would be black shadows when shooting the light source. The following is a comparison of the same scene shot in linear mode and clear HDR mode, hoping to help you make suggestions.
Linear mode:
The following parameters are set as follows:
num_of_exposure = “2”;
num_of_ignored_lines = “24”;
num_of_lines_offset_0 = “58”;
num_of_ignored_pixels = “8”;
num_of_left_margin_pixels = “8”;
num_of_right_margin_pixels = “8”;
When I captured the raw image, I found that the second frame of the captured image was completely black. Does this mean that the two images are not actually fused?Here is the raw image I captured: HDR.nvraw (8.1 MB)
Okay, I’ll double check that the drive gain, exposure control is correct. I also want to ask one more question, if you control the gain of two frames separately, the image will change in brightness, can you show that the preview image is the fused image?
Suppose that the preview has been fused, and I can control the gain of hg and lg channels, so that the brightness of the preview image will change when the gain of only one channel is modified, can it indicate that the preview image has been fused
