After burning UEFI with the development kit, the customer’s carrier board cannot boot properly. How to remove the UEFI built-in in the module
You reflash the QSPI through USB when the module is in recovery mode. Then use a UEFI that is configured for you custom carrier board.
Hi HW1234,
Are you using the devkit or custom board?
I’m not clear about what you’ve done.
How do you get the UEFI binary? How do you flash the UEFI?
UEFI is located in the partition(A_cpu-bootloader, B_cpu-bootloader) inside QSPI.
It is required for the booting and it can not be removed.
