Sorry for the confusion caused by the lack of detailed information.
I will answer on her behalf, as she will be traveling to Taiwan tomorrow to attend Jetson Partner Day and GTC.
- Patch 1 test result
Luna already tried applying Patch 1 based on your guidance.
However, the device connection status remains “none” in all cases, even when a device is connected.
Type-C hub: none
Host PC: none
Also, there is no dmesg output when the device is connected or disconnected. We do not see any reaction from the system.
- VBUS signal check
I also checked the schematics for both the AGX Orin Developer Kit and the AGX Thor Developer Kit.
Both developer kits have two Type-C ports, and it looks like only the flashing port is the OTG-capable port.
In both schematics, only the debug/flashing Type-C port has a VBUS detect signal, such as DBG_VBUS_DETECT. The other Type-C port does not appear to have an equivalent VBUS detect pin.
Because of this, we are not fully sure whether device tree modification alone is sufficient, or whether we may be missing another required change.
We would also like to rule out any possible hardware-related issue, so we checked the VBUS signal as well.
For this test, we removed the patch and used the pure BSP status.
We compared two devices:
Both were tested with the pure BSP.
The VBUS output results were the same as mentioned above.
If you have any additional guidance or information regarding the Patch 1 test, please let us know.
