hello Wiser.Kuo,
soctherm it’s used to monitor temperature.
since you’re able to run the use-case on the DevKits, please review your board design.
in addition, please access Carrier Board Specification, and check [Table 5-2. Interface Supply Current Capabilities] to check the max current for reference,
Note
this current-critical-limit-ma modification only for test purpose,
we don’t suggest to increase OC limit higher than default value for your all finalize products.
thanks
