Hello @marinak and @mehmetdeniz and thank you for your replies
Unfortunately neither solutions worked for me.
@mehmetdeniz you suggested upgrading my pip, but I cannot upgrade anything using pip (not even pip itself), since I get the same TimeoutError
@marinak I tried the solution with the proxies, using this code:
python3 -m pip --proxy http://user:pass@server:port install python3-opencv
From which I have gotten the following error:
Collecting python3-opencv Exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main status = self.run(options, args) File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run wb.build(autobuilding=True) File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build self.requirement_set.prepare_files(self.finder) File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files ignore_dependencies=self.ignore_dependencies)) File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file require_hashes File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link self.link = finder.find_requirement(self, upgrade) File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement all_candidates = self.find_all_candidates(req.name) File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates for page in self._get_pages(url_locations, project_name): File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages page = self._get_page(location) File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page return HTMLPage.get_page(link, session=self.session) File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page "Cache-Control": "max-age=600", File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/sessions.py", line 533, in get return self.request('GET', url, **kwargs) File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request return super(PipSession, self).request(method, url, *args, **kwargs) File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/sessions.py", line 520, in request resp = self.send(prep, **send_kwargs) File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/sessions.py", line 630, in send r = adapter.send(request, **kwargs) File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send resp = super(CacheControlAdapter, self).send(request, **kw) File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/adapters.py", line 405, in send conn = self.get_connection(request.url, proxies) File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/adapters.py", line 303, in get_connection proxy_manager = self.proxy_manager_for(proxy) File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/adapters.py", line 197, in proxy_manager_for **proxy_kwargs) File "/usr/share/python-wheels/urllib3-1.22-py2.py3-none-any.whl/urllib3/poolmanager.py", line 449, in proxy_from_url return ProxyManager(proxy_url=url, **kw) File "/usr/share/python-wheels/urllib3-1.22-py2.py3-none-any.whl/urllib3/poolmanager.py", line 394, in __init__ proxy = parse_url(proxy_url) File "/usr/share/python-wheels/urllib3-1.22-py2.py3-none-any.whl/urllib3/util/url.py", line 207, in parse_url raise LocationParseError(url) urllib3.exceptions.LocationParseError: Failed to parse: server:port
Any insights?
Thanks again!
