I’m using jetson AGX Orin with JP5.1. I’m trying to install TF-GPU using official guide but we running “sudo pip3 install --extra-index-url Index of /compute/redist/jp/v51 tensorflow==2.11.0+nv23.03” below error generates
ERROR: Exception:
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 438, in _error_catcher
yield
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 561, in read
data = self._fp_read(amt) if not fp_closed else b""
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 527, in _fp_read
return self._fp.read(amt) if amt is not None else self._fp.read()
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/cachecontrol/filewrapper.py”, line 98, in read
data: bytes = self.__fp.read(amt)
File “/usr/lib/python3.8/http/client.py”, line 459, in read
n = self.readinto(b)
File “/usr/lib/python3.8/http/client.py”, line 503, in readinto
n = self.fp.readinto(b)
File “/usr/lib/python3.8/socket.py”, line 669, in readinto
return self._sock.recv_into(b)
File “/usr/lib/python3.8/ssl.py”, line 1241, in recv_into
return self.read(nbytes, buffer)
File “/usr/lib/python3.8/ssl.py”, line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/cli/base_command.py”, line 180, in exc_logging_wrapper
status = run_func(*args)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/cli/req_command.py”, line 245, in wrapper
return func(self, options, args)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/commands/install.py”, line 377, in run
requirement_set = resolver.resolve(
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/resolver.py”, line 95, in resolve
result = self._result = resolver.resolve(
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 546, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 397, in resolve
self._add_to_criteria(self.state.criteria, r, parent=None)
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/resolvelib/resolvers.py”, line 173, in _add_to_criteria
if not criterion.candidates:
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/resolvelib/structs.py”, line 156, in bool
return bool(self._sequence)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 155, in bool
return any(self)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 143, in
return (c for c in iterator if id(c) not in self._incompatible_ids)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/found_candidates.py”, line 47, in _iter_built
candidate = func()
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/factory.py”, line 211, in _make_candidate_from_link
self._link_candidate_cache[link] = LinkCandidate(
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 293, in init
super().init(
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 156, in init
self.dist = self._prepare()
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 225, in _prepare
dist = self._prepare_distribution()
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/resolution/resolvelib/candidates.py”, line 304, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/operations/prepare.py”, line 525, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/operations/prepare.py”, line 596, in _prepare_linked_requirement
local_file = unpack_url(
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/operations/prepare.py”, line 168, in unpack_url
file = get_http_url(
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/operations/prepare.py”, line 109, in get_http_url
from_path, content_type = download(link, temp_dir.path)
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/network/download.py”, line 147, in call
for chunk in chunks:
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/cli/progress_bars.py”, line 53, in _rich_progress_bar
for chunk in iterable:
File “/usr/local/lib/python3.8/dist-packages/pip/_internal/network/utils.py”, line 63, in response_chunks
for chunk in response.raw.stream(
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 622, in stream
data = self.read(amt=amt, decode_content=decode_content)
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 587, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File “/usr/lib/python3.8/contextlib.py”, line 131, in exit
self.gen.throw(type, value, traceback)
File “/usr/local/lib/python3.8/dist-packages/pip/_vendor/urllib3/response.py”, line 443, in _error_catcher
raise ReadTimeoutError(self._pool, None, “Read timed out.”)
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host=‘developer.download.nvidia.com’, port=443): Read timed out.
