We are working on developing a prototype based on the tokkio workflow. We managed to customize a bunch on the services deployed already but are hitting a wall when trying to change the behavior of the ds-visionai component.
We extracted the graph, manifest and libraries from the ds-visionai container in order to understand how it is built, and tried to recreate the graph in graph composer using the deepstream-test5, deepstream-runtime-src-add-del, and some of the tao sample graphs.
As a side note here, we experienced a lot of issues/instabilities with deepstream 6.3 but managed to get something working using deepstream 7.0 instead (nvcr.io/nvidia/deepstream:7.0-gc-triton-devel) and the tao5.3_ds7.0ga branch of deepstream_tao_apps.
We managed to get a container built from the composer which can receive stream and inject additional analytics in the output messages but we are struggling to find how to handle the message payload when adding rtsp streams to the graph. Right now when deploying the graph by modifying the container used by the ds-visionai service in the tokkio helm chart it goes to running state properly but crashes when someone accesses the ui because the rtsp stream url is not properly interpreted by the graph and a stream with an empty url is added to the pipeline making it go in a crashloop.
In the tokkio workflow prebuilt services, the event available in the redis timeseries is shaped like this which corresponds to the latest update to the tokkio workflow documentation:
"alert_type": "camera_status_change",
"created_at": "2024-12-09T13:45:44Z",
"event":
"camera_id": ...,
"camera_name": ...,
"camera_url": ...,
"change": "camera_streaming",
"metadata":
{ "codec": "h264", "framerate": 30, "resolution": "1280x720" },
"source": "vst",
When building new graphs from the samples present in deepstream, the payload used is a bit different and contains less information:
"sensor": {
"id": ...,
"uri": ...
By grepping the containers contents, we found that the only reference to a camera_url string is in one of the .so files used by the graph, which lead us to believe that maybe a custom version of one of the components is used in the ds-visionai graphs rather than the base blocks provided in the deepstream samples.
I do not have extensive experience using the graph composer but from my understanding the NvDsMultiSrcConnection component is receiving an action from the HttpServer component and extracts the stream url to add it to the pipeline.
Here is my question:
- Is there a way to access the source graph and container_builder files used for building the ds-visionai container ? We are using tokkio 24.08 right now which contains one graph for the bulk of the vision processing and one graph used as a controller (we digged in 24.10 but the structure and models used vastly differs)
- If the sources to the ds-visionai, where can we find guidance on how to setup the payload scheme between the redis-timeseries and vision graph ?
Thank you.
