您好!
1.CSI 接口/dev/videoX 设备,可以输出raw图吗? isp输出的图片的格式可以配置吗?
2. 我们有个uvc设备,设备输出的是raw图,我怎么将这个raw图输入到isp中,获取isp后的图像?
hello 550399056,
>> Q1
please refer to Camera Architecture Stack.
you may using Applications Using V4L2 IOCTL Directly to dump the raw files.
>> Q2
it is USB interface, right?
according to Camera Architecture Stack, it only works with v4l2 interface.
是的,是USB接口, 我们有个需求,需要将这个USB获取的raw图,然后让nx ISP处理出RGB或者YUV图后再输出,这个能实现吗?
hello 550399056,
as you can see in the [Camera Architecture Stack], you’ll need camera connect to CSI interface to utilize Jetson ISP.
我们是否有研究如何使用endpoint 的方式将USB的raw 输出直接连接到 VI的输入,然后利用NX的这个ISP进行处理?
hello 550399056,
we only support camera connect to CSI interface if you would like to use Jetson ISP.
