看门狗重启
Sep 21 02:49:18 iking kernel: [ 0.602964] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
Sep 21 02:49:18 iking kernel: [ 0.605453] tegra_dc_assign_hw_data: no matching compatible node
Sep 21 02:49:18 iking kernel: [ 0.611471] tegradccommon module_init failed
Sep 21 02:49:18 iking kernel: [ 0.615739] tegradc module_init failed
Sep 21 02:49:18 iking kernel: [ 0.619728] EINJ: ACPI disabled.
Sep 21 02:49:18 iking kernel: [ 0.621295] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Sep 21 02:49:18 iking kernel: [ 0.621300] tegra-pmc: ### PMC reset source: BCCPLEXWDT
Sep 21 02:49:18 iking kernel: [ 0.621302] tegra-pmc: ### PMC reset level: L1
Sep 21 02:49:18 iking kernel: [ 0.621303] tegra-pmc: ### PMC reset status reg: 0x9
Sep 21 02:49:18 iking kernel: [ 0.622521] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Sep 21 02:49:18 iking kernel: [ 0.624126] printk: console [ttyTCU0] enabled
Sep 21 02:49:18 iking kernel: [ 0.624656] arm-smmu 12000000.iommu: probing hardware configuration…
Sep 21 02:49:18 iking kernel: [ 0.624659] arm-smmu 12000000.iommu: SMMUv2 with:
Sep 21 02:49:18 iking kernel: [ 0.624661] arm-smmu 12000000.iommu: stage 1 translation
Sep 21 02:49:18 iking kernel: [ 0.624662] arm-smmu 12000000.iommu: stage 2 translation
Sep 21 02:49:18 iking kernel: [ 0.624663] arm-smmu 12000000.iommu: nested translation
Sep 21 02:49:18 iking kernel: [ 0.624668] arm-smmu 12000000.iommu: stream matching with 128 register groups
Sep 21 02:49:18 iking kernel: [ 0.624671] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
Sep 21 02:49:18 iking kernel: [ 0.626695] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
kern.log (50.0 MB)
这个怎么排查啊,偶现的
orin nx 16G , jetpack5.1.4
我们的设备在客户现场,没办法接调试串口
Could this issue be reproduced with specific steps?
Happen rate?
偶现的,没有复现步骤。我也不太清楚怎么能复现问题。有没有什么调试手段,在出现问题的时候能看到相应日志。 或者打开内核的什么log调试?
/sys/fs/pstore/
Is there any console-ramoops-0 node in above path?
If there is, check it right after your issue is reproduced.
内核有什么开关打开可以增加一些调试信息的输出吗?
