i have notice that, when i track h264 file and prob the track id, the id shown is not continuous, what can i do to make it continuous?
i want to know how to reset the track id with out restart pipeline?
Which DS version are you using and which low level tracker lib are you using? I would suggest to use DS 5.0 if you are using NvDCF tracker.
The discontinuity of IDs may happen if the tracker internally evaluates possibly for a few frames and discard some bbox. So, if you want to have a continus ID, then you can add a post-processing module that translates into a continuous ID.
Currently there’s no way to reset the track ID on-the-fly.
