gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-7.1/lib/libnvds_nvmultiobjecttracker.so
[NvTrackerParams::getConfigRoot()] !!![WARNING] File doesn’t exist. Will go ahead with default values
[NvMultiObjectTracker] Initialized
Got this error when running trackers like NvDCF_accuracy and NvDeepSORT even though I have the reid model .etlt file and every file path is specicified correctly.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Are you follow this guide to setup ReID model: Gst-nvtracker — DeepStream documentation . Please share the full log when you got the fail during starting the deepstream application.
• Hardware Platform - GPU • DeepStream Version -7.1 • TensorRT Version -10.3 • NVIDIA GPU Driver Version - 580.88
I Followed the tutorial to set up reID exactly
shengyu@HC-HW-88100100:/opt/nvidia/deepstream/deepstream-7.1$ deepstream-app -c pipeline.txt
Failed to query video capabilities: Inappropriate ioctl for device
0:00:01.290711422 1044 0x5b98642ed4d0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b4_gpu0_fp16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT input_1:0 3x544x960 min: 1x3x544x960 opt: 4x3x544x960 Max: 4x3x544x960
1 OUTPUT kFLOAT output_cov/Sigmoid:0 4x34x60 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT output_bbox/BiasAdd:0 16x34x60 min: 0 opt: 0 Max: 0
0:00:01.290823444 1044 0x5b98642ed4d0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/samples/models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b4_gpu0_fp16.engine
0:00:01.297178833 1044 0x5b98642ed4d0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-7.1/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:291>: Pipeline ready
** INFO: <bus_callback:277>: Pipeline running
Above already show the “PERF” log, so the deepstream-app is running. What is the issue now? Can you share your pipeline.txt file or can you test with DeepStream release configure file?
