NvDeepSort People Tracking For All Cameras
**• Hardware Platform : Ubuntu 20.04 x64 RTX4090
**• DeepStream Version: 6.3
**• TensorRT Version: Tao toolkit 5.2.0
**• NVIDIA GPU Driver Version : 530.41.03
**• Issue Type : Question
I am trying to run NvDeepSort on DS 6.3, my aim is to implement tracking through the PeopleNet model.
I can track it with NvSORT, but when people leave the camera, their IDs change.
I think more precise tracking can be done with NvDeepSort+Re-ID.
When I download the Re-ID model from this link, only the onnx or etlt file is available.
Deepsort configuration file expects the following files from me.
tltEncodedModel: “/opt/nvidia/deepstream/deepstream/samples/models/Tracker/resnet50_market1501.etlt”
tltModelKey: “nvidia_tao”
modelEngineFile: “/opt/nvidia/deepstream/deepstream/samples/models/Tracker/resnet50_market1501.etlt_b100_gpu0_fp16.engine”
I do not have a file with .engine extension.
Normally, I can create an engine file this way, but it requires an “int8 calibration file” and this file does not exist.
tao-converter /path/resnet50_market1501.etlt
-k nvidia_tlt
-c /path/int8_calibration.txt
-o output_bbox/BiasAdd,output_cov/Sigmoid
-d 3,416,736
-i nchw
-m 1
-t int8
-e /path/model.engine
When I run DS6.3 without the .engine file, it says the .engine file is being created.
But file not created and it gives an error.
Element: nvtracker, Lib File: libnvds_nvmultiobjecttracker.so
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
~~ CLOG[src/modules/ReID/ReID.cpp, loadTRTEngine() @line 583]: Engine file does not exist
[NvMultiObjectTracker] Load engine failed. Create engine again.
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage and speed up TensorRT initialization. See “Lazy Loading” section of CUDA documentation CUDA C++ Programming Guide
Process finished with exit code 139 (interrupted by signal 11:SIGSEGV)
I need is to test it on RTX4090 first and then run it on Orin Nano.
Can you setup model based on: Gst-nvtracker — DeepStream documentation 6.4 documentation
Hello, I am keeping this issue waiting, first of all I am trying to solve the following problem.
The topic in Orin Nano is closed already. Kindly let us know if you still need support here, otherwise we’ll close this topic, thank you.
