I setup a scene with a track and a train like this:
from omni.isaac.examples.base_sample import BaseSample
from omni.isaac.core.utils.nucleus import find_nucleus_server
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.prims.xform_prim import XFormPrim
import omni.kit.commands
from pxr import Sdf, Usd, Gf
class DsdTrain1(BaseSample):
def __init__(self) -> None:
super().__init__()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
result, nucleus_server = find_nucleus_server()
if result is False:
carb.log_error("Could not find nucleus server")
asset_path = nucleus_server + "/Projects/dsd-assets/assets/"
# Add track
add_reference_to_stage(usd_path=asset_path + "tracks/track_straight_1.usd",
prim_path="/World/track")
track = world.scene.add(XFormPrim(prim_path="/World/track", name="track"))
omni.kit.commands.execute('ChangeProperty',
prop_path=Sdf.Path('/World/track/Track/TrackColliderCurve.purpose'),
value='proxy',
prev=None)
# Add train
add_reference_to_stage(usd_path=asset_path + "vehicles/DB_BR_422_with_physics.usd",
prim_path="/World/train")
train = world.scene.add(XFormPrim(prim_path="/World/train", name="train"))
return
When the scene is loaded, I try to move the prim /World/train/ in the Isaac UI. I can actually move it, but get the following error output:
2021-12-02 16:18:55 [1,570,928ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Axle1
2021-12-02 16:18:55 [1,570,928ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Flange1
2021-12-02 16:18:55 [1,570,928ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Axle2
2021-12-02 16:18:55 [1,570,928ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Flange2
2021-12-02 16:18:55 [1,570,928ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Frame
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Axle1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Flange1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Axle2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Flange2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Frame
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Axle1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Flange1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Axle2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Flange2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Frame
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Axle1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Flange1
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Axle2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Flange2
2021-12-02 16:18:55 [1,570,929ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Frame
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Axle1
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Flange1
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Axle2
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Flange2
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Frame
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_2
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_3
2021-12-02 16:18:55 [1,570,930ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_4
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Axle1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Flange1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Axle2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Flange2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_1/Bogie/Frame
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Axle1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Flange1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Axle2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Flange2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_end_4/Bogie/Frame
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Axle1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Flange1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Axle2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Flange2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_1_2/Bogie/Frame
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Axle1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Flange1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Axle2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Flange2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_2_3/Bogie/Frame
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Axle1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Flange1
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Axle2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Flange2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/bogie_mickeymouse_mid_3_4/Bogie/Frame
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_2
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_3
2021-12-02 16:18:55 [1,570,931ms] [Error] [omni.physx.plugin] Transformation change on non-root links is not supported. Link: /World/train/Train/Carriage_4
Any advice apprecitated.
