Hi I’m using JPS with Jetpack 6.0(rev.2) on Nvidia Agx Orin board. I modified line number 111 from * (for all class) to cap (my specfic class) in ai_nvr/config/emdx-analytics/config.yaml
file. To see tripwire count for cap class only, but its not working. With *(count for all classes) it’s working fine.
I will check and feedback later.
Are you follow this guide for analysis specific class: Deployment Configuration — Metropolis on Jetson documentation 0.1.0 documentation? Can you share some video for easy to reproduce the issue?
Yes I’ve followed that link only. To reproduce the issue you can take default model of yolov8 as well and just change line number 111 of ai_nvr/config/emdx-analytics/config.yaml
file with some class name instead of “*”. This problem I didn’t faced with old metropolis. But with JPS this problem is occurring
Hi @kesong is there any update?
I checked in my side. It works fine when I set the class to “Person” or “car”. You can check the class by refer this guide: DeepStream Perception — Metropolis on Jetson documentation 0.1.0 documentation
