Hi All.
Seems like after i have setup the roi and tripwire i get no counts. (check video)
Anyone else experiencing these problems.
I am using a Jetson Orin Nano
JP6 (revision 2)
Hi All.
The counting works fine in my side. Can you check if Redis received the metadata from DeepStream by following this guide: DeepStream Perception — Metropolis on Jetson documentation 0.1.0 documentation?
Hi Kesong,
Thank you for the feedback. It seems to be picking up only people as i tried another stream with people in it. U can see below its working
It doesnt seem to count cars though.
Do you perhaps know where the config is to detect everything and not just people?
Thank you
Can you have a try with deploy YOLOv8: DeepStream Perception — Metropolis on Jetson documentation 0.1.0 documentation?
Hi Kesong,
Thank you, i will try that. I see the defaults for JPS use Peoplenet, thats why its not picking up cars etc.
Regards
Hi Kesong. Any update regarding this. Thank you
Yes, the release don’t include YOLOv8 for Orin Nano. Maybe you can modify compose_nano.yaml for YOLOv8.
