Triton-server model load balancing
• Hardware Platform (Jetson / GPU) T4, RTX4000
• DeepStream Version 6.1.1
• TensorRT Version 8.1.2
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) questions
I am using triton-inference server on single GPU server and I cannot fully utilise my GPU due to one of model is slow.
is there a way to scale individual model in triton-server?
one of model is slow ==> do you run it with TensorRT? How did you find it’s slow?
scale individual model in triton-server ==> sorry, what do you mean by ‘scale’?
It is python pre-process model. I want to run multiple instance of same model. If supported, does triton-server manage number of request to any instance?
Hi @dilip.patel
Yes, it’s supported. For this, you can use batch inference mode also.
What backend will you use for Triton inference?
I will use python backend.
Pytorch bbackend supports dynamic batch, so you can build the model with max batch, and send request to Triton server/pytorch backend with any batch less than the max batch
