• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6.2
I am trying to replicate this code using Gst.ElementFactory.make instead of Gst.parse_launch
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
import time
# Initialize GStreamer
Gst.init(None)
pipeline = Gst.parse_launch(
"uridecodebin uri=<rtsp-url> ! "
"nvvideoconvert ! video/x-raw(memory:NVMM), format=NV12 ! "
"m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 batched-push-timeout=40000 ! "
"nvinfer config-file-path=config-file.txt !"
"nvdsosd !"
"nvvideoconvert ! openh264enc ! h264parse ! "
"qtmux ! filesink location=output2.mp4"
# Start the pipeline
pipeline.set_state(Gst.State.PLAYING)
# Let the pipeline run for 10 seconds
time.sleep(60)
# Send EOS to gracefully end the pipeline
pipeline.send_event(Gst.Event.new_eos())
# Wait for the pipeline to finish processing the EOS
bus = pipeline.get_bus()
msg = bus.timed_pop_filtered(Gst.CLOCK_TIME_NONE, Gst.MessageType.EOS)
# Stop and clean up
pipeline.set_state(Gst.State.NULL)
The thing is that the program doesn’t stop running after 60 seconds when I try to replicate it.
I think I am getting the linkage between uridecodebin, nvvideoconvert and streammux wrong. How can I link these elements?
