I facing problem when Jetson nano immediately unplug a board , it can’t boot normally Got some Error in picture
Please help
Please dump the serial console log when you see such abnormal power off.
If you mean you are cutting power, then you shouldn’t do that. The filesystem has a journal, and instead of corrupting content will be lost. If enough unwritten data exists, then not even the journal will be enough and the filesystem will corrupt. Proper shutdown is mandatory except on systems running in synchronous mode (and this not only drastically slows the system, it wears out the solid state memory very fast).
How can I fix it , Can I recover the system or must be reinstall only
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x223cee
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.496] Csd NumOfBlocks=124735488
[0000.554] Using GPT Primary to query partitions
[0000.563] Loading Tboot-CPU binary
[0000.940] Verifying TBC in OdmNonSecureSBK mode
[0000.950] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.957] Bootloader downloaded successfully.
[0000.961] Downloaded Tboot-CPU binary to 0xa0000258
[0000.966] MAX77620_GPIO5 configured
[0000.969] CPU power rail is up
[0000.972] CPU clock enabled
[0000.976] Performing RAM repair
[0000.979] Updating A64 Warmreset Address to 0xa00002e9
[0000.984] Loading NvTbootBootloaderDTB
[0002.293] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.358] Bootloader DTB Load Address: 0x83000000
[0002.363] Loading NvTbootKernelDTB
[0003.672] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.737] Kernel DTB Load Address: 0x83100000
[0003.745] Loading cboot binary
[0005.426] Verifying EBT in OdmNonSecureSBK mode
[0005.468] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.475] Bootloader downloaded successfully.
[0005.667] Using BFS PT to query partitions
[0005.671] Next binary entry address: 0x92c00258
[0005.675] BoardId: 3448
[0005.680] Overriding pmu board id with proc board id
[0005.684] Display board id is not available
[0007.180] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.233] /bpmp deleted
[0007.235] SC7EntryFw header found loaded at 0xff700000
[0007.424] OVR2 PMIC
[0007.425] Bpmp FW successfully loaded
[0007.442] WB0 init successfully at 0xff780000
[0007.446] Set NvDecSticky Bits
[0007.449] GSC2 address ff53fffc value c0edbbcc
[0007.456] GSC MC Settings done
[0007.461] TOS Image length 53680
[0007.464] Monitor size 53680
[0007.467] OS size 0
[0007.628] Secure Os AES-CMAC Verification Success!
[0007.632] TOS image cipher info: plaintext
[0007.636] Loading and Validation of Secure OS Successful
[0007.652] SC7 Entry Firmware - 0xff700000, 0x4000
[0007.657] NvTbootPackSdramParams: start.
[0007.662] NvTbootPackSdramParams: done.
[0007.666] Tegraboot started after 53293 us
[0007.670] Basic modules init took 5772433 us
[0007.674] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0007.679] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0007.684] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0007.690] Storage Device Read Time = 6729 ms, Read Size = 2306 KB
[0007.696] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0007.701] Next stage binary read took 1527601 us
[0007.706] Carveout took -1539280 us
[0007.709] CPU initialization took 2036073 us
[0007.713] Total time taken by TegraBoot 7796827 us
[0007.718] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0007.840] RamCode = 0
[0007.845] LPDDR4 Training: Read DT: Number of tables = 2
[0007.850] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0007.863] EMC Training Successful
[0007.866] 408000 not found in DVFS table
[0007.872] RamCode = 0
[0007.876] DT Write: emc-table@204000 succeeded
[0007.881] DT Write: emc-table@1600000 succeeded
[0007.885] LPDDR4 Training: Write DT: Number of tables = 2
[0008.084]
[0008.085] Debug Init done
[0008.087] Marked DTB cacheable
[0008.090] Bootloader DTB loaded at 0x83000000
[0008.095] Marked DTB cacheable
[0008.098] Kernel DTB loaded at 0x83100000
[0008.102] DeviceTree Init done
[0008.118] Pinmux applied successfully
[0008.122] gicd_base: 0x50041000
[0008.125] gicc_base: 0x50042000
[0008.128] Interrupts Init done
[0008.133] Using base:0x60005090 & irq:208 for tick-timer
[0008.138] Using base:0x60005098 for delay-timer
[0008.142] platform_init_timer: DONE
[0008.146] Timer(tick) Init done
[0008.149] osc freq = 38400 khz
[0008.154]
[0008.155] Welcome to L4T Cboot
[0008.158]
[0008.159] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0008.164] calling constructors
[0008.167] initializing heap
[0008.169] initializing threads
[0008.172] initializing timers
[0008.175] creating bootstrap completion thread
[0008.180] top of bootstrap2()
[0008.182] CPU: ARM Cortex A57
[0008.185] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0008.190] initializing platform
[0008.198] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0008.202] ID LSB = 0x36, ID-CFI len = 194 bytes
[0008.207] Macronix QSPI chip present
[0008.210] SPI device register
[0008.213] init boot device
[0008.216] allocating memory for boot device(SPI)
[0008.220] registering boot device
[0008.230] sdmmc node status = okay
[0008.233] sdcard instance = 0
[0008.236] sdcard gpio handle 0x56
[0008.239] sdcard gpio pin 0xc9
[0008.242] sdcard gpio flags 0x0
[0008.245] vmmc-supply 0x99
[0008.247] Instance: 0
[0008.250] Allocating memory for context
[0008.253] enabling clock
[0008.256] sd card init
[0008.258] Check card present and stable
[0008.262] Send command 0
[0008.286] Send command 3
[0008.291] Set RCA for the card
[0008.294] Query card specific data by command 9
[0008.300] Parse CSD data
[0008.302] Send command 7
[0008.313] Calling sd device register
[0008.316] Init sdcard
[0008.318] Allocating memory for boot device
[0008.322] Registering user device
[0008.336] Enable APE clock
[0008.338] Un-powergate APE partition
[0008.342] of_register: registering tegra_udc to of_hal
[0008.347] of_register: registering inv20628-driver to of_hal
[0008.352] of_register: registering ads1015-driver to of_hal
[0008.358] of_register: registering lp8557-bl-driver to of_hal
[0008.364] of_register: registering bq2419x_charger to of_hal
[0008.369] of_register: registering bq27441_fuel_gauge to of_hal
[0008.381] gpio framework initialized
[0008.384] of_register: registering tca9539_gpio to of_hal
[0008.390] of_register: registering tca9539_gpio to of_hal
[0008.395] of_register: registering i2c_bus_driver to of_hal
[0008.401] of_register: registering i2c_bus_driver to of_hal
[0008.406] of_register: registering i2c_bus_driver to of_hal
[0008.412] pmic framework initialized
[0008.415] of_register: registering max77620_pmic to of_hal
[0008.421] regulator framework initialized
[0008.425] of_register: registering tps65132_bl_driver to of_hal
[0008.431] initializing target
[0008.436] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0008.445] board ID = D78, board SKU = 0
[0008.448] Skipping Z3!
[0008.453] fixed regulator driver initialized
[0008.470] initializing OF layer
[0008.473] NCK carveout not present
[0008.477] Skipping dts_overrides
[0008.481] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.498] I2C Bus Init done
[0008.500] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.511] I2C Bus Init done
[0008.513] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.524] I2C Bus Init done
[0008.526] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.537] I2C Bus Init done
[0008.539] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.550] I2C Bus Init done
[0008.552] of_children_init: Ops found for compatible string maxim,max77620
[0008.563] max77620_init using irq 118
[0008.567] register ‘maxim,max77620’ pmic
[0008.572] gpio_driver_register: register ‘max77620-gpio’ driver
[0008.578] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0008.588] I2C Bus Init done
[0008.592] NCK carveout not present
[0008.602] Find /i2c@7000c000’s alias i2c0
[0008.606] get eeprom at 1-a0, size 256, type 0
[0008.615] Find /i2c@7000c500’s alias i2c2
[0008.618] get eeprom at 3-a0, size 256, type 0
[0008.623] get eeprom at 3-ae, size 256, type 0
[0008.627] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.633] I2C slave not started
[0008.636] I2C write failed
[0008.638] Writing offset failed
[0008.641] eeprom_init: EEPROM read failed
[0008.645] pm_ids_update: eeprom init failed
[0008.649] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.679] pm_ids_update: The pm board id is 3448-0000-400
[0008.686] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0008.694] pm_ids_update: pm id update successful
[0008.698] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.729] pm_ids_update: The pm board id is 3449-0000-400
[0008.735] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0008.743] pm_ids_update: pm id update successful
[0008.774] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.779] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0008.788] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0008.793] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0008.802] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:b2:e2
[0008.809] Plugin Manager: Parse ODM data 0x00084000
[0008.819] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0008.841] Find /i2c@7000c000’s alias i2c0
[0008.844] get eeprom at 1-a0, size 256, type 0
[0008.853] Find /i2c@7000c500’s alias i2c2
[0008.857] get eeprom at 3-a0, size 256, type 0
[0008.861] get eeprom at 3-ae, size 256, type 0
[0008.866] pm_ids_update: Updating 1,a0, size 256, type 0
[0008.871] I2C slave not started
[0008.874] I2C write failed
[0008.877] Writing offset failed
[0008.880] eeprom_init: EEPROM read failed
[0008.884] pm_ids_update: eeprom init failed
[0008.888] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.918] pm_ids_update: The pm board id is 3448-0000-400
[0008.925] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0008.931] pm_ids_update: pm id update successful
[0008.936] pm_ids_update: Updating 3,ae, size 256, type 0
[0008.966] pm_ids_update: The pm board id is 3449-0000-400
[0008.973] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0008.980] pm_ids_update: pm id update successful
[0009.010] Add serial number:1422819075066 as DT property
[0009.018] Applying platform configs
[0009.025] platform-init is not present. Skipping
[0009.029] calling apps_init()
[0009.054] Found 14 GPT partitions in “sd0”
[0009.058] Proceeding to Cold Boot
[0009.062] starting app android_boot_app
[0009.065] Device state: unlocked
[0009.068] display console init
[0009.077] could not find regulator
[0009.081] hdmi cable connected
[0009.096] edid read success
[0009.111] edid read success
[0009.114] widDT entry for leds-pwm not found
t[0009.121] h = 640, height = 480, frequency = 25174825
[0009.126] width = 640, height = 480, frequency = 25174825
[0009.132] width = 1920, height = 1080, frequency = 148500000
[0009.137] width = 1920, height = 1080, frequency = 148500000
[0009.143] width = 1920, height = 1080, frequency = 148351648
[0009.149] width = 1280, height = 720, frequency = 74175824
[0009.154] width = 720, height = 480, frequency = 26973026
[0009.160] width = 640, height = 480, frequency = 25174825
[0009.165] width = 720, height = 576, frequency = 26973026
[0009.170] width = 1920, height = 1080, frequency = 148351648
[0009.176] width = 1920, height = 1080, frequency = 148351648
[0009.182] width = 1280, height = 720, frequency = 74175824
[0009.187] Best mode Width = 1920, Height = 1080, freq = 148351648
[0009.195] tmds-config node not found
[0009.199] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltageps
[0009.214] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0009.221] could not find regulator
[0009.225] could not find regulator
[0009.228] could not find regulator
[0009.256] using default cmu settings
[0009.260] dc_hdmi_enable, starting HDMI initialisation
[0009.266] dc_hdmi_enable, HDMI initialisation complete
[0009.271] list and configure display window
[0009.280] display console init completed
[0009.291] subnode volume_up is not found !
[0009.295] subnode back is not found !
[0009.298] subnode volume_down is not found !
[0009.303] subnode menu is not found !
[0009.306] Gpio keyboard init success
[0009.350] found decompressor handler: lz4-legacy
[0009.364] decompressing blob (type 1)…
[0009.400] load_bmp_blob: panelresolution=1080 type=3
[0009.450] decompressor handler not found
[0009.454] load_firmware_blob: Firmware blob loaded, entries=2
[0009.460] -------> se_aes_verify_sbk_clear: 747
[0009.464] se_aes_verify_sbk_clear: Error
[0009.468] bl_battery_charging: connected to external power supply
[0009.476] xusb is supported
[0009.482] error while finding nvidia,portmap
[0009.986] xusb blob version 0 size 124416
[0009.990] firmware size 124416
[0009.995] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0010.005] xhci0: 64 bytes context size, 32-bit DMA
[0010.045] usbus0: 5.0Gbps Super Speed USB v3.0
[0010.065] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on u0
[0010.715] uhub0: 9 ports with 9 removable, self powered
[0011.715] failed to get HID devices
[0011.719] failed to init xhci or no usb device attached
[0011.729] device_query_partition_size: failed to open partition sd0:MSC !
[0011.736] MSC Partition not found
[0011.742] device_query_partition_size: failed to open partition sd0:USP !
[0011.749] USP partition read failed!
[0011.752] blob_init: blob-partition USP header read failed
[0011.758] android_boot Unable to update recovery partition
[0011.763] kfs_getpartname: name = LNX
[0011.767] Loading kernel from LNX
[0011.865] load kernel from storage
[0011.877] decompressor handler not found
[0011.934] Successfully loaded kernel and ramdisk images
[0011.941] load_bmp_blob: panelresolution=1080 type=3
[0012.437] display bmp image done
[0012.440] NCK carveout not present
[0012.443] Skipping dts_overrides
[0012.446] NCK carveout not present
[0012.456] Find /i2c@7000c000’s alias i2c0
[0012.460] get eeprom at 1-a0, size 256, type 0
[0012.469] Find /i2c@7000c500’s alias i2c2
[0012.473] get eeprom at 3-a0, size 256, type 0
[0012.477] get eeprom at 3-ae, size 256, type 0
[0012.482] pm_ids_update: Updating 1,a0, size 256, type 0
[0012.487] I2C slave not started
[0012.490] I2C write failed
[0012.493] Writing offset failed
[0012.496] eeprom_init: EEPROM read failed
[0012.500] pm_ids_update: eeprom init failed
[0012.504] pm_ids_update: Updating 3,a0, size 256, type 0
[0012.534] pm_ids_update: The pm board id is 3448-0000-400
[0012.541] Adding plugin-manager/ids/3448-0000-400=/i2c@7000c500:module@0x50
[0012.548] pm_ids_update: pm id update successful
[0012.553] pm_ids_update: Updating 3,ae, size 256, type 0
[0012.583] pm_ids_update: The pm board id is 3449-0000-400
[0012.590] Adding plugin-manager/ids/3449-0000-400=/i2c@7000c500:module@0x57
[0012.597] pm_ids_update: pm id update successful
[0012.628] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.634] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0012.642] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0012.648] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0012.657] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:b2:e2
[0012.663] Plugin Manager: Parse ODM data 0x00084000
[0012.673] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootw
[0012.688] Add serial number:1422819075066 as DT property
[0012.697] “bpmp” doesn’t exist, creating
[0012.703] Updated bpmp info to DTB
[0012.708] Updated initrd info to DTB
[0012.711] “proc-board” doesn’t exist, creating
[0012.717] Updated board info to DTB
[0012.720] “pmu-board” doesn’t exist, creating
[0012.726] Updated board info to DTB
[0012.729] “display-board” doesn’t exist, creating
[0012.735] Updated board info to DTB
[0012.738] “reset” doesn’t exist, creating
[0012.743] Updated reset info to DTB
[0012.746] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0012.785] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console
[0012.797] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0012.810] Updated bootarg info to DTB
[0012.814] Adding uuid 00000001644608822400000014000080 to DT
[0012.820] Adding eks info 0 to DT
[0012.825] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0012.831] Updated memory info to DTB
[0012.840] set vdd_core voltage to 1075 mv
[0012.844] setting ‘vdd-core’ regulator to 1075000 micro volts
[0012.865] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 155 ms (3.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 287 ms (18.2 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1539 ms (21.2 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resizt
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776f0
Starting kernel …
[ 1.107154] tegradc tegradc.1: dpd enable lookup fail:-19 [ 1.272238] imx219 7-0010: imx219_board_setup: error during i2c read probe () [ 1.272266] imx219 7-0010: board setup failed [ 1.296058] imx219 8-0010: imx219_board_setup: error during i2c read probe () [ 1.296087] imx219 8-0010: board setup failed [ 2.009314] cgroup: cgroup2: unknown option "nsdelegate"Hi,
Are you able to login to serial console after all these logs printed?
I can’t login serial console because it’s stuck at the last line , but i can login if i press any key before auto boot.
Please remove the “quiet” keyword in /boot/extlinux/extlinux.conf, reboot and dump the serial console log again.
This time should have more log than before.
It won’t be known if this will help until the “quiet” keyword mentioned by @WayneWWW is removed and a full boot log is available (“quiet” removes logging so it looks better, but looking better means no ability to debug). It may be that the filesystem journal already recovered, but do avoid simply cutting power without a proper shutdown (not something you can easily do if boot fails). Even if the journal recovered we don’t know what was lost from replay of the journal.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2713) (gcc ve9
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_B
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_B
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nt
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id t
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible s
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb1000 s61592 r8192 d320
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa4
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M sect0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29396(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562224K/4159488K available (15230K kernel code, 2926K r)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 )
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 )
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 )
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 )
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 )
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a11b808 ( 2927 )
[ 0.000000] .bss : 0xffffff800a11b808 - 0xffffff800a1b3dbc ( 610 )
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 )
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 )
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 )
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /intr
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (p.
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398s
[ 0.001755] Console: colour dummy device 80x25
[ 0.002606] console [tty0] enabled
[ 0.002634] kmemleak: Kernel memory leak detector disabled
[ 0.002666] Calibrating delay loop (skipped), value calculated using timer f)
[ 0.002697] pid_max: default: 32768 minimum: 301
[ 0.003160] Security Framework initialized
[ 0.003394] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003414] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004687] ftrace: allocating 47001 entries in 184 pages
[ 0.178167] ASID allocator initialised with 65536 entries
[ 0.216176] tegra-id: chipid=22117.
[ 0.216260] tegra-id: opt_subrevision=0.
[ 0.216290] Tegra Speedo/IDDQ fuse revision 4
[ 0.216305] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216322] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.216338] Tegra: CPU Speedo Value 2018, SoC Speedo Value 1916, GPU Speedo 4
[ 0.216358] Tegra: CPU IDDQ Value 1704, SoC IDDQ Value 1884, GPU IDDQ Value 0
[ 0.216392] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.216418] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9s
[ 0.216453] DTB Build time: Dec 9 2019 22:51:55
[ 0.265069] CPU1: Booted secondary processor [411fd071]
[ 0.297004] CPU2: Booted secondary processor [411fd071]
[ 0.328967] CPU3: Booted secondary processor [411fd071]
[ 0.329061] Brought up 4 CPUs
[ 0.329122] SMP: Total of 4 processors activated.
[ 0.329142] CPU features: detected feature: 32-bit EL0 Support
[ 0.329421] CPU: All CPU(s) started at EL2
[ 0.329454] alternatives: patching kernel code
[ 0.337858] devtmpfs: initialized
[ 0.375697] Initilizing CustomIPI irq domain
[ 0.376134] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[ 0.376178] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.387671] pinctrl core: initialized pinctrl subsystem
[ 0.388401] OS set in device tree is not L4T.
[ 0.388843] regulator-dummy: no parameters
[ 0.389202] Initializing plugin-manager
[ 0.389334] Plugin module not found
[ 0.389571] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.390153] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.391969] node /plugin-manager/fragement@10 match with board >=3448-0000-30
[ 0.394342] node /plugin-manager/fragement@11 match with board >=3448-0000-30
[ 0.398008] NET: Registered protocol family 16
[ 0.399370] pstore: using zlib compression
[ 0.400043] console [pstore-1] enabled
[ 0.400060] pstore: Registered ramoops as persistent store backend
[ 0.400079] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417089] cpuidle: using governor menu
[ 0.421601] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423272] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44)
[ 0.423317] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425660] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atoms
[ 0.428360] tegra_powergate_init: DONE
[ 0.428402] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9s
[ 0.428441] DTB Build time: Dec 9 2019 22:51:55
[ 0.430315] Tegra reboot handler registered.
[ 0.435019] iommu: Adding device tegra-carveouts to group 0
[ 0.435195] platform tegra-carveouts: domain=ffffffc0f942c318 allocates as[08
[ 0.435581] iommu: Adding device smmu_test to group 1
[ 0.435654] platform smmu_test: domain=ffffffc0f942c558 allocates as[0]=ffff0
[ 0.436509] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.436586] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.436651] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.436674] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436712] mc-err: mcerr ops are set to t21x
[ 0.446607] iommu: Adding device 70090000.xusb to group 2
[ 0.446935] iommu: Adding device 70006000.serial to group 3
[ 0.447031] platform 70006000.serial: domain=ffffffc0f94ca618 allocates as[08
[ 0.447506] iommu: Adding device 70006040.serial to group 4
[ 0.447798] iommu: Adding device 70006200.serial to group 5
[ 0.448050] iommu: Adding device sound to group 6
[ 0.448119] platform sound: domain=ffffffc0f94cab58 allocates as[0]=ffffffc00
[ 0.448717] iommu: Adding device 7000d400.spi to group 7
[ 0.448996] iommu: Adding device 7000d600.spi to group 8
[ 0.449335] iommu: Adding device 70410000.spi to group 9
[ 0.449669] iommu: Adding device 50000000.host1x to group 10
[ 0.449963] iommu: Adding device 54080000.vi to group 11
[ 0.450380] iommu: Adding device 54600000.isp to group 12
[ 0.450655] iommu: Adding device 54680000.isp to group 13
[ 0.450984] iommu: Adding device tegradc.0 to group 14
[ 0.451060] platform tegradc.0: domain=ffffffc0f94d7a98 allocates as[0]=ffff8
[ 0.455274] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.455689] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456031] iommu: Adding device tegradc.1 to group 15
[ 0.456098] platform tegradc.1: domain=ffffffc0f94d7cd8 allocates as[0]=ffff0
[ 0.460418] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.460825] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.461121] iommu: Adding device 54340000.vic to group 16
[ 0.461359] iommu: Adding device 544c0000.nvenc to group 17
[ 0.461590] iommu: Adding device 54500000.tsec to group 18
[ 0.461811] iommu: Adding device 54100000.tsecb to group 19
[ 0.462026] iommu: Adding device 54480000.nvdec to group 20
[ 0.462266] iommu: Adding device 54380000.nvjpg to group 21
[ 0.463323] iommu: Adding device 546c0000.i2c to group 22
[ 0.463681] iommu: Adding device 57000000.gpu to group 23
[ 0.463752] platform 57000000.gpu: domain=ffffffc0f94e6cd8 allocates as[0]=f8
[ 0.463809] platform 57000000.gpu: domain=ffffffc0f94e6cd8 allocates as[1]=f0
[ 0.463869] platform 57000000.gpu: domain=ffffffc0f94e6cd8 allocates as[2]=f8
[ 0.463923] platform 57000000.gpu: domain=ffffffc0f94e6cd8 allocates as[3]=f0
[ 0.464879] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency .
[ 0.464919] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.464946] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.464966] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.464984] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.517183] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registerd
[ 0.517223] tegra-pmc: Clear bootloader IO dpd settings
[ 0.517260] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.517341] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reses
[ 0.517656] iommu: Adding device 70012000.se to group 24
[ 0.518453] iommu: Adding device 7000c000.i2c to group 25
[ 0.518713] iommu: Adding device 7000c400.i2c to group 26
[ 0.518994] iommu: Adding device 7000c500.i2c to group 27
[ 0.519265] iommu: Adding device 7000c700.i2c to group 28
[ 0.519569] iommu: Adding device 7000d000.i2c to group 29
[ 0.519831] iommu: Adding device 7000d100.i2c to group 30
[ 0.520135] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.520209] platform sdhci-tegra.0: domain=ffffffc0f9579e58 allocates as[0]=8
[ 0.521087] iommu: Adding device 700d0000.xudc to group 32
[ 0.524346] vdd-ac-bat: 5000 mV
[ 0.524739] vdd-5v0-sys: 5000 mV
[ 0.525723] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.525815] vdd-5v0-hdmi: 5000 mV
[ 0.526254] vdd-1v8-sys: 1800 mV
[ 0.526659] vdd-fan: supplied by vdd-5v0-sys
[ 0.526708] vdd-fan: 5000 mV
[ 0.527112] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.527190] vdd-usb-vbus: 5000 mV
[ 0.527764] vdd-usb-vbus2: 5000 mV
[ 0.558185] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.560889] gpio gpiochip0: gpio-line-names specifies 240 line names but thep
[ 0.562002] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.562039] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.562091] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.562500] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochi)
[ 0.570531] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.570928] SCSI subsystem initialized
[ 0.571564] usbcore: registered new interface driver usbfs
[ 0.571652] usbcore: registered new interface driver hub
[ 0.571755] usbcore: registered new device driver usb
[ 0.575814] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.580222] random: fast init done
[ 0.580415] vdd-core: 600 ↔ 1162 mV at 1125 mV
[ 0.581461] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.584229] vdd-ddr-1v1: 1150 mV
[ 0.588395] vdd-pre-reg-1v35: 1350 mV
[ 0.592225] vdd-1v8: 1800 mV
[ 0.596225] avdd-sys-1v2: 1200 mV
[ 0.600225] vdd-pex-1v0: 1050 mV
[ 0.600898] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.601456] max77620-ldo3: at 3100 mV
[ 0.604236] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.604791] max77620-ldo5: at 3100 mV
[ 0.608233] vddio-sdmmc3-ap: 1800 ↔ 3300 mV at 2800 mV
[ 0.612229] avdd-1v05-pll: 1050 mV
[ 0.616225] avdd-io-hdmi-dp: 1050 mV
[ 0.618919] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.619224] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpioc)
[ 0.619544] max77620 4-003c: max77620 probe successful
[ 0.622365] media: Linux media interface: v0.10
[ 0.622445] Linux video capture interface: v2.00
[ 0.623387] pps_core: LinuxPPS API ver. 1 registered
[ 0.623414] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[ 0.623453] PTP clock support registered
[ 0.627415] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.633875] tegra210-emc 7001b000.external-memory-controller: validated EMC e
[ 0.634851] Advanced Linux Sound Architecture Driver Initialized.
[ 0.635549] Bluetooth: Core ver 2.22
[ 0.635622] NET: Registered protocol family 31
[ 0.635643] Bluetooth: HCI device and connection manager initialized
[ 0.635674] Bluetooth: HCI socket layer initialized
[ 0.635697] Bluetooth: L2CAP socket layer initialized
[ 0.635738] Bluetooth: SCO socket layer initialized
[ 0.637536] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.637576] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.637636] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.637664] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.640971] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering pe
[ 0.642234] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.642323] vdd-3v3-sys: 3300 mV
[ 0.642601] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.645151] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.645665] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.645752] vdd-3v3-sd: 3300 mV
[ 0.646816] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.646879] avdd-io-edp-1v05: 1050 mV
[ 0.647330] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.647387] vdd-usb-hub-en: 5000 mV
[ 0.648881] camchar: rtcpu character device driver loaded
[ 0.649652] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.651034] clocksource: Switched to clocksource arch_sys_counter
[ 0.691720] VFS: Disk quotas dquot_6.6.0
[ 0.691886] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.692396] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.692843] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vp0
[ 0.692897] dma-vpr: heap size is not multiple of cma_chunk_size heap_info-)
[ 0.693118] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.693142] dma_declare_coherent_resizable_cma_memory:373: resizable cma heal
[ 0.693168] tegra-carveouts tegra-carveouts: assigned reserved memory node vt
[ 0.693212] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 8
[ 0.693238] tegra-carveouts tegra-carveouts: assigned reserved memory node it
[ 0.693269] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.693292] nvmap_page_pool_init: Total RAM pages: 1009340
[ 0.693310] nvmap_page_pool_init: nvmap page pool size: 126167 pages (492 MB)
[ 0.693410] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.693960] misc nvmap: created heap iram base 0x0000000040001000 size (252K)
[ 0.695020] misc nvmap: created heap vpr base 0x00000000d7000000 size (40960)
[ 0.703240] thermal thermal_zone0: Registering thermal zone thermal_zone0 fom
[ 0.703699] thermal thermal_zone1: Registering thermal zone thermal_zone1 fom
[ 0.703970] thermal thermal_zone2: Registering thermal zone thermal_zone2 fom
[ 0.704202] thermal thermal_zone3: Registering thermal zone thermal_zone3 fom
[ 0.704398] thermal thermal_zone4: Registering thermal zone thermal_zone4 foe
[ 0.704692] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.704715] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.705179] NET: Registered protocol family 2
[ 0.706182] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[ 0.706422] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.706978] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.707216] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.707322] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.707754] NET: Registered protocol family 1
[ 0.708509] RPC: Registered named UNIX socket transport module.
[ 0.708540] RPC: Registered udp transport module.
[ 0.708557] RPC: Registered tcp transport module.
[ 0.708574] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.708814] Trying to unpack rootfs image as initramfs…
[ 0.942165] Freeing initrd memory: 5356K
[ 0.952585] host1x 50000000.host1x: initialized
[ 0.954604] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[ 0.958021] audit: initializing netlink subsys (disabled)
[ 0.958144] audit: type=2000 audit(0.803:1): initialized
[ 0.958955] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.969085] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.970599] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.971460] 9p: Installing v9fs 9p2000 file system support
[ 0.974732] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.974904] io scheduler noop registered
[ 0.975403] io scheduler cfq registered (default)
[ 0.978188] gic 702f9000.agic: GIC IRQ controller registered
[ 0.981236] iommu: Adding device 702ef000.adsp to group 33
[ 0.990134] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.990310] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.990931] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 =0
[ 0.990962] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT4
[ 0.992830] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane =b
[ 0.992980] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane =b
[ 0.993096] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane =b
[ 0.993313] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane =1
[ 0.993430] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane =4
[ 0.993552] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane =4
[ 0.993665] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane =4
[ 0.993772] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane =4
[ 0.993881] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane =b
[ 0.993986] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane =b
[ 1.000420] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.002245] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.004269] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.005598] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.005974] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.007209] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.007601] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:e
[ 1.007843] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0
[ 1.008116] Adding domain tsec-pd to PM domain host1x-pd
[ 1.011542] tsec 54500000.tsec: initialized
[ 1.012902] tsec 54100000.tsecb: initialized
[ 1.013634] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.017217] nvdec 54480000.nvdec: initialized
[ 1.018312] Adding domain vic03-pd to PM domain host1x-pd
[ 1.018518] Adding domain msenc-pd to PM domain host1x-pd
[ 1.018693] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.022802] falcon 54340000.vic: initialized
[ 1.024141] falcon 544c0000.nvenc: initialized
[ 1.025465] falcon 54380000.nvjpg: initialized
[ 1.030156] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015F7
[ 1.030232] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.030258] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.030312] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.030378] display board info: id 0x0, fab 0x0
[ 1.030457] generic_infoframe_type: 0x87
[ 1.030613] tegradc tegradc.0: DT parsed successfully
[ 1.030622] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.030627] tegra_cec 70015000.tegra_cec: probed
[ 1.030711] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with i0
[ 1.031370] tegradc tegradc.0: Bootloader disp_param detected. Detected mode1
[ 1.038426] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 chs
[ 1.039008] tegradc tegradc.0: probed
[ 1.045238] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 chas
[ 1.046795] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initd
[ 1.047294] kfuse 7000fc00.kfuse: initialized
[ 1.048936] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-suppe
[ 1.050064] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.051701] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.051755] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.052252] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator regid
[ 1.054068] vdd-gpu: applied init 1000000uV constraint
[ 1.054103] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.054567] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator regid
[ 1.059298] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.059575] No Device Node present for smmu client: serial8250 !!
[ 1.059612] platform serial8250: No iommus property found in DT node, got sw)
[ 1.059699] iommu: Adding device serial8250 to group 35
[ 1.063536] console [ttyS0] disabled
[ 1.063706] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud =a
[ 1.542338] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.946837] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.043051] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.043056] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.350849] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.352865] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.459109] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.459119] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.459124] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.459129] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pr]
[ 2.459135] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.459537] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reg
[ 2.479179] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.479184] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.479194] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64b]
[ 2.479214] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64b]
[ 2.479232] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.479244] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.479250] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.479256] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.479660] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.479664] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.498864] console [ttyS0] enabled
[ 3.499507] Console: switching to colour frame buffer device 240x67
[ 3.509471] tegradc tegradc.0: fb registered
[ 3.510622] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baudT
[ 3.510937] serial-tegra 70006200.serial: RX in PIO mode
[ 3.511082] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baudT
[ 3.512089] [drm] Initialized
[ 3.534964] brd: module loaded
[ 3.545424] loop: module loaded
[ 3.548736] tegra_profiler: version: 1.139, samples/io: 47/27
[ 3.550883] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mod.
[ 3.550926] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hm
[ 3.551434] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.551445] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.577530] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.577535] Extcon AUX1(HDMI) enable
[ 3.578511] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.578587] tegradc tegradc.1: No lt-data, using default setting
[ 3.578618] tegradc tegradc.1: No hpd-gpio in DT
[ 3.578652] tegradc tegradc.1: DT parsed successfully
[ 3.578713] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with i1
[ 3.579049] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:14
[ 3.579964] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.590962] tegradc tegradc.1: probed
[ 3.642639] tegradc tegradc.1: fb registered
[ 3.642729] tegra_profiler: auth: init
[ 3.643269] THERMAL EST: found 2 subdevs
[ 3.643273] THERMAL EST num_resources: 0
[ 3.643276] [THERMAL EST subdev 0]
[ 3.643280] [THERMAL EST subdev 1]
[ 3.643593] thermal thermal_zone5: Registering thermal zone thermal_zone5 fot
[ 3.643595] THERMAL EST: thz register success.
[ 3.643694] THERMAL EST: end of probe, return err: 0
[ 3.644342] hisi_sas: driver version v1.6
[ 3.647873] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.648728] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.648735] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (40
[ 3.650720] libphy: Fixed MDIO Bus: probed
[ 3.651259] tun: Universal TUN/TAP device driver, 1.6
[ 3.651261] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.655329] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.655331] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.655376] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.655378] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.655420] igbvf: Intel(R) Gigabit Virtual Function Network Driver - versiok
[ 3.655421] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.655461] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.655464] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.660020] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.660039] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.674559] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalide
[ 3.674635] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found ve
[ 3.675067] r8168: This product is covered by one or more of the following p.
[ 3.675099] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@rea
[ 3.675099] This program comes with ABSOLUTELY NO WARRANTY; for details, pl
[ 3.675099] This is free software, and you are welcome to redistribute it u
[ 3.675503] PPP generic driver version 2.4.2
[ 3.675633] PPP BSD Compression module registered
[ 3.675635] PPP Deflate Compression module registered
[ 3.675650] PPP MPPE Compression module registered
[ 3.675653] NET: Registered protocol family 24
[ 3.675702] usbcore: registered new interface driver r8152
[ 3.675744] usbcore: registered new interface driver asix
[ 3.675783] usbcore: registered new interface driver ax88179_178a
[ 3.675817] usbcore: registered new interface driver cdc_ether
[ 3.675852] usbcore: registered new interface driver net1080
[ 3.675885] usbcore: registered new interface driver cdc_subset
[ 3.675917] usbcore: registered new interface driver zaurus
[ 3.675963] usbcore: registered new interface driver cdc_ncm
[ 3.676083] VFIO - User Level meta-driver version: 0.3
[ 3.677022] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.677032] ehci-pci: EHCI PCI platform driver
[ 3.677069] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.677075] ohci-pci: OHCI PCI platform driver
[ 3.677111] ohci-platform: OHCI generic platform driver
[ 3.678967] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.679519] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.680564] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f96e8400 id
[ 3.681968] usbcore: registered new interface driver uas
[ 3.682017] usbcore: registered new interface driver usb-storage
[ 3.682081] usbcore: registered new interface driver usbserial
[ 3.682980] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:5e
[ 3.683008] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.683061] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus n1
[ 3.683779] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100
[ 3.683812] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.683961] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.683966] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 3.683970] usb usb1: Product: xHCI Host Controller
[ 3.683973] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.683976] usb usb1: SerialNumber: 70090000.xusb
[ 3.684406] hub 1-0:1.0: USB hub found
[ 3.684442] hub 1-0:1.0: 5 ports detected
[ 3.684945] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.684954] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus n2
[ 3.685020] usb usb2: We don’t know the algorithms for LPM for this host, di.
[ 3.685111] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.685115] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 3.685118] usb usb2: Product: xHCI Host Controller
[ 3.685122] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 3.685125] usb usb2: SerialNumber: 70090000.xusb
[ 3.686907] hub 2-0:1.0: USB hub found
[ 3.686937] hub 2-0:1.0: 4 ports detected
[ 3.687456] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.688382] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.688390] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.688702] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.688928] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.689058] mousedev: PS/2 mouse device common for all mice
[ 3.689120] usbcore: registered new interface driver xpad
[ 3.787087] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.803926] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as 0
[ 3.806107] rtc rtc1: alarm rtc device
[ 3.806120] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.806145] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.806493] i2c /dev entries driver
[ 3.807861] i2c i2c-6: Added multiplexed i2c bus 7
[ 3.808197] i2c i2c-6: Added multiplexed i2c bus 8
[ 3.808201] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 3.808697] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.831978] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.832053] imx219 7-0010: imx219_board_setup: error during i2c read probe ()
[ 3.832084] imx219 7-0010: board setup failed
[ 3.832147] imx219: probe of 7-0010 failed with error -121
[ 3.832539] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.855794] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.855862] imx219 8-0010: imx219_board_setup: error during i2c read probe ()
[ 3.855894] imx219 8-0010: board setup failed
[ 3.855945] imx219: probe of 8-0010 failed with error -121
[ 3.856710] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.858671] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.858676] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.858971] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.858983] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.858990] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when C
[ 3.859145] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.859154] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.859160] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when C
[ 3.859301] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.859308] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down whenC
[ 3.859312] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot tee
[ 3.859482] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.860022] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.860065] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.860085] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.860101] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.860109] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.860881] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.860895] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device’d
[ 3.861041] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.861063] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling devd
[ 3.861414] parse_throttle_dt_data: Num cap clks = 6
[ 3.861419] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.861425] parse_throttle_dt_data: clk=gpu type=4
[ 3.861443] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.861459] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.861476] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.861479] parse_throttle_dt_data: clk=emc type=3
[ 3.861763] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.861853] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 3.861955] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.862522] FAN dev name: pwm-fan
[ 3.862565] FAN:gpio request success.
[ 3.862614] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.862842] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.862950] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.862956] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.863086] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, s2
[ 3.863090] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2,2
[ 3.863094] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=12
[ 3.863098] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=12
[ 3.863102] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=13
[ 3.863106] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=13
[ 3.863110] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=13
[ 3.863113] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=14
[ 3.863117] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=4
[ 3.863121] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=4
[ 3.864120] device-mapper: uevent: version 1.0.3
[ 3.864528] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-m
[ 3.867244] tegra210-cpufreq cpufreq: probe()…completed
[ 3.867962] sdhci: Secure Digital Host Controller Interface driver
[ 3.867963] sdhci: Copyright(c) Pierre Ossman
[ 3.867964] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.868446] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.868802] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.868922] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.873632] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.874179] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.875409] usbcore: registered new interface driver usbhid
[ 3.875411] usbhid: USB HID core driver
[ 3.877565] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.877733] tegra21x_actmon 6000c800.actmon: initialization Completed for thl
[ 3.879604] nvpmodel: initialized successfully
[ 3.880531] usbcore: registered new interface driver snd-usb-audio
[ 3.880585] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.880590] platform snd-soc-dummy: No iommus property found in DT node, got)
[ 3.880609] iommu: Adding device snd-soc-dummy to group 36
[ 3.903533] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/ca0
[ 3.908644] OPE platform probe
[ 3.908722] OPE platform probe successful
[ 3.909049] OPE platform probe
[ 3.909129] OPE platform probe successful
[ 3.919241] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADr
[ 3.935698] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 3.935825] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 3.935947] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 3.936071] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 3.936190] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 3.936314] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 3.936435] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 3.936554] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 3.936674] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 3.936795] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 3.948800] u32 classifier
[ 3.948801] Actions configured
[ 3.948874] Initializing XFRM netlink socket
[ 3.949579] NET: Registered protocol family 10
[ 3.950267] NET: Registered protocol family 17
[ 3.950277] NET: Registered protocol family 15
[ 3.950349] bridge: filtering via arp/ip/ip6tables is no longer available by.
[ 3.950397] Bluetooth: RFCOMM socket layer initialized
[ 3.950406] Bluetooth: RFCOMM ver 1.11
[ 3.950411] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.950415] Bluetooth: HIDP socket layer initialized
[ 3.950432] 9pnet: Installing 9P2000 support
[ 3.950471] Key type dns_resolver registered
[ 3.951057] Registered cp15_barrier emulation handler
[ 3.951066] Registered setend emulation handler
[ 3.952344] registered taskstats version 1
[ 3.952917] Adding domain ve2-pd to PM domain host1x-pd
[ 3.953154] Adding domain ve-pd to PM domain host1x-pd
[ 4.019489] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.057474] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 4.057477] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.057480] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 4.057482] usb 1-2: Manufacturer: Generic
[ 4.061007] hub 1-2:1.0: USB hub found
[ 4.062081] hub 1-2:1.0: 4 ports detected
[ 4.122193] mmc0: Applying tuning correction
[ 4.122206] mmc0: Tap value after applying correction 55
[ 4.122223] mmc0: hw tuning done …
[ 4.122253] mmc0: new ultra high speed SDR104 SDXC card at address e624
[ 4.122556] mmcblk0: mmc0:e624 SN64G 59.5 GiB
[ 4.126993] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.355086] usb 1-2.3: new high-speed USB device number 3 using tegra-xusb
[ 4.402424] usb 1-2.3: New USB device found, idVendor=05e3, idProduct=0610
[ 4.402428] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumbe0
[ 4.402431] usb 1-2.3: Product: USB2.1 Hub
[ 4.402433] usb 1-2.3: Manufacturer: GenesysLogic
[ 4.405531] hub 1-2.3:1.0: USB hub found
[ 4.409263] hub 1-2.3:1.0: 4 ports detected
[ 4.515084] usb 1-2.4: new full-speed USB device number 4 using tegra-xusb
[ 4.538113] usb 1-2.4: New USB device found, idVendor=1e4e, idProduct=0100
[ 4.538116] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[ 4.538119] usb 1-2.4: Product: PureThermal (fw:v1.2.2)
[ 4.538121] usb 1-2.4: Manufacturer: GroupGets
[ 4.538123] usb 1-2.4: SerialNumber: 8001000f-5119-3138-3931-383900000000
[ 4.791083] usb 1-2.3.1: new full-speed USB device number 5 using tegra-xusb
[ 4.817242] usb 1-2.3.1: New USB device found, idVendor=045e, idProduct=07b2
[ 4.817245] usb 1-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNum0
[ 4.817248] usb 1-2.3.1: Product: Microsoft�® 2.4GHz Transceiver v8.0
[ 4.817250] usb 1-2.3.1: Manufacturer: Microsoft
[ 4.821361] input: Microsoft Microsoft�® 2.4GHz Transceiver v8.0 as /devices1
[ 4.879538] hid-generic 0003:045E:07B2.0001: input,hidraw0: USB HID v1.11 Ke0
[ 4.884302] input: Microsoft Microsoft�® 2.4GHz Transceiver v8.0 as /devices2
[ 4.884586] hid-generic 0003:045E:07B2.0002: input,hidraw1: USB HID v1.11 Mo1
[ 4.900325] input: Microsoft Microsoft�® 2.4GHz Transceiver v8.0 as /devices3
[ 4.959411] hid-generic 0003:045E:07B2.0003: input,hidraw2: USB HID v1.11 De2
[ 5.075084] usb 1-2.3.4: new full-speed USB device number 6 using tegra-xusb
[ 5.099185] usb 1-2.3.4: New USB device found, idVendor=2341, idProduct=0043
[ 5.099189] usb 1-2.3.4: New USB device strings: Mfr=1, Product=2, SerialNum0
[ 5.099191] usb 1-2.3.4: Manufacturer: Arduino (www.arduino.cc)
[ 5.099193] usb 1-2.3.4: SerialNumber: 557353032343517012E1
[ 5.204445] tegradc tegradc.0: blank - powerdown
[ 5.207546] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.207549] hpd: switching from state 7 (Takeover from bootloader) to state )
[ 5.207554] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.208672] isp 54600000.isp: initialized
[ 5.209469] isp 54680000.isp: initialized
[ 5.219675] last reset is due to power on reset
[ 5.219678] KERNEL: PMC reset status reg: 0x0
[ 5.219749] BL: PMC reset status reg: 0x0
[ 5.219750] BL: PMIC poweroff Event Recorder: 0x40
[ 5.221177] clk_cbus_recalc_rate: no gbus parent
[ 5.221181] clk_cbus_round_rate: no gbus parent
[ 5.221182] clk_cbus_round_rate: no gbus parent
[ 5.221189] clk_cbus_recalc_rate: no gbus parent
[ 5.221294] clk_cbus_recalc_rate: no gbus parent
[ 5.221296] clk_cbus_round_rate: no gbus parent
[ 5.221298] clk_cbus_round_rate: no gbus parent
[ 5.221301] clk_cbus_recalc_rate: no gbus parent
[ 5.221314] tegra_dvfs: GPU-cap: registered
[ 5.221370] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200d
[ 5.221372] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 1250d
[ 5.221374] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000d
[ 5.222807] tegra_dvfs: vdd-gpu-vts: registered
[ 5.223538] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cd
[ 5.224191] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap coolid
[ 5.224716] input: gpio-keys as /devices/gpio-keys/input/input4
[ 5.246253] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.246255] Extcon AUX1(HDMI) disable
[ 5.257917] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00)
[ 5.258941] vi 54080000.vi: vi_probe: ++
[ 5.262203] vi 54080000.vi: initialized
[ 5.264277] vi 54080000.vi: subdev nvcsi–2 bound
[ 5.264375] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.264628] mmcblk mmc0:e624: Card claimed for testing.
[ 5.265951] Disable partitions left on by BL
[ 5.265953] disb
[ 5.265998] bwmgr: missing cdev-type property
[ 5.266120] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -210
[ 5.266126] DRAM derating cdev registered.
[ 5.267137] vdd-fan: disabling
[ 5.267139] vdd-usb-vbus: disabling
[ 5.267141] vdd-usb-vbus2: disabling
[ 5.267150] vddio-sdmmc3-ap: disabling
[ 5.267235] avdd-io-edp-1v05: disabling
[ 5.267237] vdd-usb-hub-en: disabling
[ 5.267324] ALSA device list:
[ 5.267326] #0: tegra-hda at 0x70038000 irq 83
[ 5.267327] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.274940] tegradc tegradc.0: unblank
[ 5.311645] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:10
[ 5.311696] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hm
[ 5.312687] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 5.312693] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.347395] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.347397] Extcon AUX1(HDMI) enable
[ 5.347661] tegradc tegradc.0: sync windows ret = 250
[ 5.751683] tegradc tegradc.1: blank - powerdown
[ 5.758060] extcon-disp-state extcon:disp-state: cable 44 state 0 already se.
[ 5.758061] Extcon DP: HPD disabled
[ 5.758063] hpd: hpd_switch 0
[ 5.758066] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.758108] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.758112] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.802153] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 5.802155] Extcon HDMI: HPD enabled
[ 5.802167] tegradc tegradc.0: hdmi: plugged
[ 5.824421] Freeing unused kernel memory: 8576K
[ 5.851190] Root device found: mmcblk0p1
[ 5.857832] Found dev node: /dev/mmcblk0p1
[ 5.968280] EXT4-fs (mmcblk0p1): recovery complete
[ 5.976690] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. )
[ 5.987179] Rootfs mounted over mmcblk0p1
[ 5.999885] usb 1-2.4: USB disconnect, device number 4
[ 6.015349] Switching from initrd to actual rootfs
[ 6.192450] systemd[1]: System time before build time, advancing clock.
[ 6.221035] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.240103] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.258007] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SE)
[ 6.283031] usb 1-2.4: new full-speed USB device number 7 using tegra-xusb
[ 6.292697] systemd[1]: Detected architecture arm64.
[ 6.314012] usb 1-2.4: New USB device found, idVendor=1e4e, idProduct=0100
[ 6.322888] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[ 6.332191] usb 1-2.4: Product: PureThermal (fw:v1.2.2)
[ 6.339407] usb 1-2.4: Manufacturer: GroupGets
[ 6.345837] usb 1-2.4: SerialNumber: 8001000f-5119-3138-3931-383900000000
[ 6.372168] systemd[1]: No hostname configured.
[ 6.378700] systemd[1]: Set hostname to .
[ 6.484547] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 co.
[ 6.503327] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warn)
[ 6.640222] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.650588] systemd[1]: Created slice System Slice.
[ 6.659914] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.668781] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 6.679645] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.689160] systemd[1]: Created slice User and Session Slice.
[ 6.699301] systemd[1]: Reached target Slices.
[ 7.138428] systemd-journald[2041]: Received request to flush runtime journa1
[ 7.876196] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 7.883824] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 7.895481] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO)
[ 8.046437] random: crng init done
[ 8.051754] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.199481] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.236046] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.244880] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.258316] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.264976] usb 2-1: Manufacturer: Generic
[ 8.275722] hub 2-1:1.0: USB hub found
[ 8.282319] hub 2-1:1.0: 4 ports detected
[ 8.448707] uvcvideo: Found UVC 1.00 device PureThermal (fw:v1.2.2) (1e4e:01)
[ 8.476293] uvcvideo 1-2.4:1.0: Entity type for entity Extension 3 was not i!
[ 8.499185] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not !
[ 8.527086] uvcvideo 1-2.4:1.0: Entity type for entity Extension 4 was not i!
[ 8.540099] uvcvideo 1-2.4:1.0: Entity type for entity Extension 5 was not i!
[ 8.550151] uvcvideo 1-2.4:1.0: Entity type for entity Extension 6 was not i!
[ 8.561060] uvcvideo 1-2.4:1.0: Entity type for entity Extension 7 was not i!
[ 8.576161] cdc_acm 1-2.3.4:1.0: ttyACM0: USB ACM device
[ 8.576855] usbcore: registered new interface driver cdc_acm
[ 8.576858] cdc_acm: USB Abstract Control Model driver for USB modems and ISs
[ 8.604221] usb 2-1.2: new SuperSpeed USB device number 3 using tegra-xusb
[ 8.614262] uvcvideo 1-2.4:1.0: Entity type for entity Extension 21 was not !
[ 8.625321] usb 2-1.2: New USB device found, idVendor=8086, idProduct=0b3a
[ 8.625325] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[ 8.625328] usb 2-1.2: Product: Intel(R) RealSense™ Depth Camera 435i
[ 8.625330] usb 2-1.2: Manufacturer: Intel(R) RealSense™ Depth Camera 435i
[ 8.625333] usb 2-1.2: SerialNumber: 908323050427
[ 8.626686] uvcvideo: Unknown video format 00000050-0000-0010-8000-00aa003891
[ 8.626693] uvcvideo: Unknown video format 00000032-0000-0010-8000-00aa003891
[ 8.626914] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Cam)
[ 8.628780] uvcvideo: Unable to create debugfs 2-3 directory.
[ 8.628910] uvcvideo 2-1.2:1.0: Entity type for entity Intel(R) RealSense(TM!
[ 8.628914] uvcvideo 2-1.2:1.0: Entity type for entity Processing 2 was not !
[ 8.628918] uvcvideo 2-1.2:1.0: Entity type for entity Intel(R) RealSense(TM!
[ 8.628921] uvcvideo 2-1.2:1.0: Entity type for entity Camera 1 was not init!
[ 8.629193] input: Intel(R) RealSense™ Depth Ca as /devices/70090000.xusb5
[ 8.630181] uvcvideo: Unknown video format 36315752-1a66-a242-9065-d01814a8ea
[ 8.630189] uvcvideo: Found UVC 1.50 device Intel(R) RealSense™ Depth Cam)
[ 8.631079] uvcvideo: Unable to create debugfs 2-3 directory.
[ 8.631218] uvcvideo 2-1.2:1.3: Entity type for entity Processing 7 was not !
[ 8.631226] uvcvideo 2-1.2:1.3: Entity type for entity Extension 8 was not i!
[ 8.631230] uvcvideo 2-1.2:1.3: Entity type for entity Camera 6 was not init!
[ 8.732483] usb 2-1.3: new SuperSpeed USB device number 4 using tegra-xusb
[ 8.835050] usb 2-1.3: New USB device found, idVendor=05e3, idProduct=0626
[ 8.835054] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumbe0
[ 8.835057] usb 2-1.3: Product: USB3.1 Hub
[ 8.835059] usb 2-1.3: Manufacturer: GenesysLogic
[ 8.862310] hub 2-1.3:1.0: USB hub found
[ 8.868287] hub 2-1.3:1.0: 4 ports detected
[ 8.886929] uvcvideo 1-2.4:1.0: Entity type for entity Extension 254 was not!
[ 8.897098] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not init!
[ 8.907106] input: PureThermal (fw:v1.2.2) as /devices/70090000.xusb/usb1/1-6
[ 8.919000] usbcore: registered new interface driver uvcvideo
[ 8.926768] USB Video Class driver (1.1.1)
[ 9.211565] usb 2-1.3.3: new SuperSpeed USB device number 5 using tegra-xusb
[ 9.240145] usb 2-1.3.3: New USB device found, idVendor=0781, idProduct=5583
[ 9.240149] usb 2-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNum3
[ 9.240152] usb 2-1.3.3: Product: Ultra Fit
[ 9.240154] usb 2-1.3.3: Manufacturer: SanDisk
[ 9.240157] usb 2-1.3.3: SerialNumber: 4C530001240408103054
[ 9.241151] usb-storage 2-1.3.3:1.0: USB Mass Storage device detected
[ 9.249491] scsi host0: usb-storage 2-1.3.3:1.0
[ 9.592461] input: BRLTTY 5.5 Linux Screen Driver Keyboard as /devices/virtu7
[ 10.268126] scsi 0:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 P6
[ 10.278838] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.)
[ 10.289475] sd 0:0:0:0: [sda] Write Protect is off
[ 10.296855] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doA
[ 10.316045] sda: sda1
[ 10.323117] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 11.043106] usb 2-1.2: usb_suspend_both: status 0
[ 11.051057] usb 1-2.4: usb_suspend_both: status 0
I see the log seems hang here. Does it hang here in every reboot?
Yes it hang here every reboot?
HI,
- Do you have any USB device connected to your board? Could you remove it and see if it can boot up?
- Would you mind reflashing your board? The data would be erased though.
One of these might not correctly handle suspend:
In particular I would wonder about whether extra firmware is required for the Microsoft transceiver. If removing these helps boot, then I would center on the wireless device and see if it requires third party firmware.
