Trouble with reinforcement learning task in Isaac Lab
Recently I managed to train neural networks to balance a double pendulum (including the swing up) using a naive and very simple evolutionary algorithm. I now want to compare training speed and results with more modern and robust RL algorithms such as the ones provided with Isaac Lab on the exact same task. I modified the cartpole example to turn it into a double pendulum and modified the reward terms accordingly.
However after a few hours of training no solution was found (using rl_games and skrl with 8192 envs).
I then tried to use a easier setup by using a very low gravity and high rotational damping on the poles but it was also unsuccessful.
I am currently unsure if the problem comes from
  • the reward function
  • the setup
  • the task in itself being too challenging
  • or if I just need to increase the number of envs or training time
Any insight would be very helpful!
Thanks,
Pezzza
Hi @pezzzas.work ,
Thank you for your post.
Could you please share your modification/patch about the cartpole so we can try it on our end?
Thanks,
-Todd
Thank you for your quick response.
I created a fork of the repo and put my changes in a branch called “double_pendulum_older” that you can checkout here https://github.com/johnBuffer/IsaacLab/tree/double_pendulum_older
I run the training using this command (replacing skrl with rl_games depending on the algorithm to test):
isaaclab.bat -p source\standalone\workflows\skrl\train.py --task Isaac-Cartpole-v0 --num_envs 4096 --headless
If you need any additional information don’t hesitate to ask!
Hi @pezzzas.work ,
The good news, we’ll have double pendulum task in the next release of isaac lab.
You can compare the implementation then.
Thanks,
-Todd
Hi Todd,
A few questions regarding this information:
  • Do you know if this includes the swing up?
  • Do you know when this next release will be available?
Thanks,
Jean
Hi @pezzzas.work ,
No, it doesn’t include swing up.
It’s about the 2nd of September.
Thanks,
-Todd
Hi Todd,
Thank you for your response. I will try the new release when it will be out and see if I can manage to add the swing up then.
Thanks,
Jean
