Troubleshooting Nsight Compute Display Issues with OptiX 7.1 Profiling
I am using Nsight Compute 2024.2 for profiling OptiX 7.1. Recently, after updating Nsight Compute due to a driver issue, the display for raygen__** in Nsight Compute changed to NVIDIA Internal(optixLaunch), and I can no longer view the source code. I have set module_compile_options.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_LINEINFO; and included --lineinfo in the OptiX build. Please tell me what I should check to resolve this issue.
Hi, @tommyecguitar
Can you please update to the latest R555 driver to see if your user kernel is visible ?
Please refer restrictions for Optix
https://docs.nvidia.com/nsight-compute/ReleaseNotes/topics/library-support-optix.html?highlight=optix#optix
Also suggest you to use non-interactive, as there are some known issues with interactive profile
Thank you, @veraj .
My driver version is already 555.99 on RTX 2070 super.
In non-interactice profile, raygen is not displayed. I can see only “NVIDIA internal(optixLaunch)”.
Hi, @tommyecguitar
We can see the raygen_** related info in our test. We are using optixPathtracer.exe from Optix 7.6 package.
@veraj
Thank you.
Can you tell me what the profile settings are like? In my environment, I only have Import Source set to Yes.
Also, could the CUDA version of the application be relevant? My application has been developed with CUDA 11.
@tommyecguitar
We use the default setting of non interactive profile.
I’m not sure if CUDA will be relevant in this case, but as CUDA 11 is relative old, I would suggest you to update to latest CUDA and Optix.
@veraj
After setting CBL1 to OPTIX_FORCE_DEPRECATED_LAUNCHER, the Source was displayed.
Is it safe?
You can use CBL1.
@veraj
Thank you.
I will use CBL1 for a while.
