Trying to Update the Bootloader Pinmux on Custom Carrier Board
We are going through the bring-up process on a custom carrier board for the Nvidia Jetson Nano 4GB module. We are using a module from the Dev Kit so it has an SD card for memory instead of eMMC.
Following the instructions listed under “Update Bootloader Pinmux” here: https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/adaptation_and_bringup_nano.html#wwpID0E0EQ0HA we have faced an issue where there were rootfs folders missing from the source files. We then tried using the folders from a Linux_for_Tegra folder generated by SDKManager get it working, but the flash script hangs and fails here:
door@door-desktop:~/Downloads/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-devkit mmcblk0p1
L4T BSP Information:
R32 , REVISION: 5.1
Target Board Information:
Name: jetson-nano-devkit, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/door/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0016 ] Generating RCM messages
[ 0.0024 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/door/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0030 ] RCM 0 is saved as rcm_0.rcm
[ 0.0034 ] RCM 1 is saved as rcm_1.rcm
[ 0.0034 ] List of rcm files are saved in rcm_list.xml
[ 0.0034 ]
[ 0.0034 ] Signing RCM messages
[ 0.0041 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0047 ] Assuming zero filled SBK key
[ 0.0099 ]
[ 0.0099 ] Copying signature to RCM mesages
[ 0.0107 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0117 ]
[ 0.0118 ] Boot Rom communication
[ 0.0124 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0132 ] RCM version 0X210001
[ 0.0587 ] Boot Rom communication completed
[ 1.0656 ]
[ 1.0658 ] dump EEPROM info
[ 1.0677 ] tegrarcm --oem platformdetails eeprom /home/door/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0689 ] Applet version 00.01.0000
[ 1.0850 ] Saved platform info in /home/door/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1614 ]
[ 1.1622 ] tegrarcm --reboot recovery
[ 1.1629 ] Applet version 00.01.0000
[ 1.1653 ]
Board ID(3448) version(400)
copying bctfile(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/door/Downloads/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/door/Downloads/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/door/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
Existing badpagefile(/home/door/Downloads/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/door/Downloads/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/door/Downloads/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/door/Downloads/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
Making system.img…
populating rootfs from /home/door/Downloads/Linux_for_Tegra/rootfs … done.
populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/door/Downloads/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/door/Downloads/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml… done.
copying flasher(/home/door/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/door/Downloads/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-b00.dtb”
saving flash command in /home/door/Downloads/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/door/Downloads/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0088 ] tegrasign --key None --getmode mode.txt
[ 0.0097 ] Assuming zero filled SBK key
[ 0.0127 ]
[ 0.0128 ] Generating RCM messages
[ 0.0147 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0162 ] RCM 0 is saved as rcm_0.rcm
[ 0.0182 ] RCM 1 is saved as rcm_1.rcm
[ 0.0182 ] List of rcm files are saved in rcm_list.xml
[ 0.0182 ]
[ 0.0183 ] Signing RCM messages
[ 0.0197 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0211 ] Assuming zero filled SBK key
[ 0.0263 ]
[ 0.0263 ] Copying signature to RCM mesages
[ 0.0279 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0293 ]
[ 0.0294 ] Parsing partition layout
[ 0.0387 ] tegraparser --pt flash.xml.tmp
[ 0.0412 ]
[ 0.0413 ] Creating list of images to be signed
[ 0.0430 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0726 ]
[ 0.0726 ] Generating signatures
[ 0.0743 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0760 ] Assuming zero filled SBK key
[ 0.1600 ]
[ 0.1601 ] Generating br-bct
[ 0.1744 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1762 ] Copying Sdram info from 2 to 3 set
[ 0.1798 ]
[ 0.1799 ] Updating boot device parameters
[ 0.1808 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1814 ] Warning: No sdram params
[ 0.1817 ]
[ 0.1817 ] Updating bl info
[ 0.1828 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1842 ]
[ 0.1843 ] Updating secondary storage information into bct
[ 0.1850 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.1858 ]
[ 0.1858 ] Updating Odmdata
[ 0.1866 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.1878 ] Warning: No sdram params
[ 0.1879 ]
[ 0.1879 ] Get Signed section of bct
[ 0.1889 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1936 ]
[ 0.1937 ] Signing BCT
[ 0.1987 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.2000 ] Assuming zero filled SBK key
[ 0.2000 ]
[ 0.2001 ] Updating BCT with signature
[ 0.2021 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.2043 ]
[ 0.2043 ] Copying signatures
[ 0.2051 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.2085 ]
[ 0.2086 ] Updating BFS information on BCT
[ 0.2094 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.2102 ]
[ 0.2103 ] Boot Rom communication
[ 0.2110 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.2116 ] BR_CID: 0x321010016445778410000000020284c0
[ 0.2126 ] RCM version 0X210001
[ 0.2287 ] Boot Rom communication completed
[ 1.2381 ]
[ 1.2382 ] Sending BCTs
[ 1.2401 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.2415 ] Applet version 00.01.0000
[ 1.2599 ] Sending bct
[ 1.2600 ] […] 100%
[ 1.4843 ]
[ 1.4867 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.4888 ]
[ 1.4905 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.4929 ]
[ 1.4944 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.4950 ] Assuming zero filled SBK key
[ 1.5091 ]
[ 1.5102 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.5116 ]
[ 1.5136 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
[ 1.5144 ]
[ 1.5152 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
[ 1.5172 ]
[ 1.5191 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
[ 1.5205 ] Assuming zero filled SBK key
[ 1.5272 ]
[ 1.5283 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 1.5293 ]
[ 1.5296 ] Sending bootloader and pre-requisite binaries
[ 1.5303 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
[ 1.5315 ] Applet version 00.01.0000
[ 1.5477 ] Sending ebt
[ 1.5479 ] […] 100%
[ 1.6553 ] Sending rp1
[ 1.6599 ] […] 100%
[ 1.7163 ]
[ 1.7181 ] tegrarcm --boot recovery
[ 1.7203 ] Applet version 00.01.0000
[ 1.7253 ]
[ 1.7253 ] Retrieving storage infomation
[ 1.7264 ] tegrarcm --oem platformdetails storage storage_info.bin
Any suggestions?
hello josh1,
is it complete logs? please attach the log messages with the code block, i.e. <code>LOGS</code>
you’re able to create your rootfs, please download L4T Sample Root File System via download center.
you may also refer to developer guide, Setting Up Your File System for reference,
thanks
Hey Jerry,
Using the Sample Root File System worked! We were able to flash the pinmux on the board. However, during further testing we found the board was still not able to recognize the Raspberry Pi V2.1 cameras connected via CSI. I will start another thread for that topic.
Do you have any suggestions for debugging a custom carrier board? We are able to share schematics of the custom carrier board directly with moderators but we cannot share schematics on the forum.
Best,
Josh
hello josh1,
if your board schematic differs from that for Jetson Nano Developer Kit carrier board, you must change the pinmux configuration applied by the software.
so, please review the board schematic to customize the pinmux spreadsheets.
you should update the device tree blob (i.e. tegra210-p3448-0000-p3449-0000-a02.dtb) by copying the generated .dtsi files and build the new device tree blob. and using that to flash the target.
please check developer guide for details, Jetson Nano Platform Adaptation and Bring-Up.
thanks
