Turn off display for deepstream-test1 app
Xavier
• DeepStream Version
6.0
4.6-b197
• TensorRT Version
8.0.1-1+cuda10.2
10.2
I am using deepstream-mrcnn-test app and my application doesn’t need display.
How can I turn off display?
But I need to use osd_sink_pad_buffer_probe.
How can I do that?
You can try with fakesink.
Changed my application to deepstream-test3-app.
Then this line is set as
sink = gst_element_factory_make ("fakesink", "nvvideo-renderer");
I have error as
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:dstest3-pipeline/GstNvInfer:primary-nvinference-engine:
streaming stopped, reason error (-5)
Please remove nvegltransform part for Jetson device.
Removing that have this error
One tegra element could not be created. Exiting.
Remove means comment out the line ?
//transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
Yes. all related with nvegltransform, not just this one. added to the pipeline, and linked to elements.
Yeah removing also have the same error
‘One tegra element could not be created. ‘
add GST_DEBUG=4 to app run and see which element not be created.
