Two DGX Sparks over the ConnectX-7 direct link — setup notes, throughput numbers,and two questions (federated vs cluster, telemetry)
I couldn’t find many real-world notes on dual-Spark behavior when I added a second unit, so here’s a field report: sourcing the hardware in Canada, the setup path that worked, measured throughput, and two open questions — including how people measure what crossing the interconnect actually costs.
Getting the hardware in Canada — NVIDIA, please ship here
It would be genuinely nice if NVIDIA supplied the DGX Spark and its accessories in Canada. Right now:
  • The NVIDIA Marketplace sells the DGX Spark at US $3,999 — but it’s a US-only store. Worse, the country selector on the NVIDIA web store just routes Canadian visitors back to the USA store — there is no Canadian purchase path at all.
  • At today’s USDCAD (~1.418), US $3,999 converts to about CAD $5,670. But most Canadian retailers are selling around CAD $7,200 — that’s US $5,077, a ~27% premium (≈ US $1,080 per unit) over NVIDIA’s own price. The cheapest I found is CAD $6,567.95 at Fleet Network — still ~$900 over converted, and showing Canadian inventory out of stock. Across two units for a stacked setup, the Canada premium is over CAD $3,000 at typical street prices.
  • The stacking cable is worse: NVIDIA’s branded “DGX Spark Stacking DAC Cable” is sold at Micro Center — US only. In Canada the cable is hard to find and expensive, and importing meant unknown duties on a small accessory. I eventually found this 200G QSFP56 DAC at Memory Express, which worked perfectly.
For a product aimed at individual developers, having the official store, the official price, and the official accessory all inaccessible from Canada adds real cost and friction to a two-unit setup.
Setup — pairing the two units over ConnectX-7
The lowest-configuration path that worked:
1. Set the new DGX up with NVIDIA Sync.
2. Connect the two boxes with a single QSFP DAC directly between the CX-7 ports — no switch.
On the cable spec: NVIDIA’s Spark Stacking guide says to use “the approved QSFP/CX7 cable” but publishes no part number. The certified part appears to be Amphenol NJAAKK-N911 (QSFP112, 400 mm). My standard 200G QSFP56 passive DAC linked at 200 Gb/s immediately. Per the guide, use the same port on both units (both left or both right, viewed from the rear).
3. I let Claude Code do the network bring-up rather than configuring by hand. The prompt, roughly:
“Two DGX Sparks, connected directly with the QSFP cable between the ConnectX-7 ports. Join the new box to my tailnet, set up SSH keys between the boxes, then bring up the CX-7 link: detect the live ports, assign IPs on a dedicated subnet, make it persistent across reboots, enable and validate jumbo frames, add hosts aliases, and test connectivity and throughput. Verify it survives a reboot.”
One useful thing it discovered: both CX-7 ports on both machines sit in a single L2 domain via the NIC’s eSwitch, so exact port-to-port choice doesn’t matter in practice.
The resulting config, for anyone doing it by hand
  • Link: 200 Gb/s immediately; rdma link shows the RoCE devices ACTIVE.
  • Addressing: dedicated subnet, persistent via NetworkManager: nmcli con add type ethernet ifname enp1s0f0np0 con-name cx7-cluster ipv4.method manual ipv4.addresses 10.77.0.1/24 ipv6.method disabled connection.autoconnect yes (.2 on the other node), plus /etc/hosts aliases.
  • MTU 9000, validated with ping -M do -s 8972 to rule out a silent blackhole.
Measured expectations
  • Plain TCP (iperf3, 8 streams): ~16 Gb/s — that’s the Grace CPU pushing TCP, not the link. Jumbo frames didn’t change it.
  • The 200G is really there for RDMA/RoCE (NCCL, multi-node engines).
  • Ordinary file moves over ssh: ~600 MB/s — a 51 GB checkpoint ships between nodes in ~85 s, so we download models once and distribute over the fabric.
  • Management plane stays on Tailscale/LAN; the fabric carries only data.
The questions
1. Where do you draw the federated-vs-cluster line? Specifically for models that would fit on one Spark: does anyone run them 2-node (TP/EP) anyway, and how bad is the single-stream latency hit vs the extra KV/context headroom you gain? Our default is federated — each Spark serves its own models at full local memory bandwidth, and multi-node is reserved for models that genuinely don’t fit in 128 GB — but that’s a prior, not a measurement, and I’d like to see numbers that argue either way.
2. What telemetry do you collect on a cluster that you wouldn’t bother with on a single box? Ours, beyond per-node basics (node-exporter + DCGM — which works fine on GB10, including XID error and PCIe replay counters):
  • Per-link fabric counters (throughput, retransmits on the CX-7 interfaces) — scraped over the fabric itself so monitoring survives LAN/WiFi flaps.
  • “Cluster tax” — multi-node throughput ÷ sum of the same nodes run independently: one number for what the interconnect costs.
  • Engine-level metrics per node — tokens/s, TTFT, KV-cache utilization from the serving engines’ /metrics.
  • One alerting lesson: static “low free memory” thresholds are wrong for inference nodes — an engine that reserves 95% of unified memory up front leaves ~9 GB free by design and is healthy. We moved OOM alerting to PSI (pressure stall) + swap-out rate, which catches real contention instead of paging you about a working reservation.
What’s on your list? Anyone measuring interconnect efficiency for 2-8 node EP setups (accept rates, per-token fabric hops)?
Mark
If your aim is to only serve small models then a federate design makes sense. You have ofcourse wasted 40% of your investment at that point as the ConnectX-7 ports are unused.
You can compare benchmarks between 1/2/4/8 nodes here: https://spark-arena.com/
2 nodes are for serving models like Deepseek v4 Flash, Minimax M2.7 and similar, not small dense ones.
I monitor the 200G links and they are used, although never at 100% load, this is from starting up DSv4:
I have not had any errors clocking up on any interfaces.
Did you search this forum? There are 100s of discussions about the set up from last year. Plenty folks confirmed what cables were useful, etc.
It should be very straightforward if you follow the networking guide of the community docker
Adding a mixed-vendor GB10 data point in case it helps others validate what healthy throughput looks like.
I tested one QSFP112 direct connection between a Gigabyte AI TOP ATOM and an ASUS Ascent GX10. On this pair, the connected physical port appeared as two active mappings:
rocep1s0f1 port 1 ==> enp1s0f1np1
roceP2p1s0f1 port 1 ==> enP2p1s0f1np1
For this test I assigned each path its own point-to-point subnet and used MTU 9000 on all four endpoints:
enp1s0f1np1:   192.168.200.13/24 <-> 192.168.200.12/24
enP2p1s0f1np1: 192.168.201.13/24 <-> 192.168.201.12/24
Jumbo pings with ping -M do -s 8972 completed with zero loss in both directions. Both RoCE devices were ACTIVE. show_gids exposed the IPv4 RoCE v2 entries at index 3 on this image, so I used the discovered index rather than assuming it would be universal.
The measured ib_write_bw results were:
Rail 1 alone: 109.28 Gbit/s
Rail 2 alone: 109.25 Gbit/s
Both rails, Gigabyte to ASUS: 98.02 + 98.02 = 196.04 Gbit/s
Both rails, ASUS to Gigabyte: 98.02 + 98.02 = 196.04 Gbit/s
There were zero RX errors, RX drops, TX errors, or TX drops on the active interfaces. The normal LAN management routes remained unchanged.
One confusing detail matched what others have described here: both logical interfaces reported 200000 Mb/s, but that does not mean the cable provides 400 Gbit/s. The two host paths together serve the single physical 200 Gbit/s connection.
The complete reproducible configuration, including Netplan, per-rail commands, reverse-direction checks, reboot verification, and rollback steps, is here:
The useful part of this result for me was confirming that approximately 196 Gbit/s aggregate was achievable across two different GB10 system vendors, not only between two identical DGX Spark units.
For running the Larger Models, are yall running kubernetes on the DGX Spark (GB10)? Or are you setting it up with Docker Compose files on each DGX Spark?
