We have two products of PGI. one is PGI Accelerator Server and other is PGI-Cluster Development Kit. We installed everything successfully. Firstly We tried to start the license server daemon - PGI Accelerator Server running successfully. Secondly we tried to start the license server daemon - PGI Cluster Development Kit but is not running. The two product of both of them are same hostname, same mac address and same port. The PGI Accelerator Server location on our cluster through NFS i.e., /home/pkg/lic/pgi/pgi-accelerator-server/ contains license file, flexlm log and bin directory. Other product - PGI Cluster Development Kit location on our cluster through NFS i.e., /home/pkg/lic/pgi-cdk/ contains license file, flexlm log and bin directory.
Second license file, I changed the port number from 27000 to 28000 and pgroupd added the port 28005 then license server daemon failed to open the TCP-PORT.
Because pgroupd is already running the first license, so the second license will not run.
I tried to combine the license file then run the license server daemon, it is not running of both of them.
How to fix the problem?
Thanks in advance,
Ashok Vignesh.
