I am using TX2EVM+OV5693 camera. Enable kernel trace and use v4l2-ctl do dump image file.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
nvidia@tegra-ubuntu:~$ sudo v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video0 --stream-to=ov5693.raw
[sudo] password for nvidia:
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.69 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.34 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.23 fps
I get follow trace message.
nvidia@tegra-ubuntu:~$ sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 539/539 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:0-4 [000] ...1 141.762044: rtos_queue_peek_from_isr_failed: tstamp:4786684864 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 141.762049: rtcpu_start: tstamp:4786685672
kworker/0:0-4 [000] ...1 141.814049: rtcpu_vinotify_handle_msg: tstamp:4788658134 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:493690288 data:0x00000001
kworker/0:0-4 [000] ...1 141.814055: rtcpu_vinotify_handle_msg: tstamp:4788658300 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:493690295 data:0x00000000
kworker/0:0-4 [000] ...1 141.814057: rtcpu_vinotify_handle_msg: tstamp:4788660672 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:1 vi_tstamp:493692964 data:0x08000000
kworker/0:0-4 [000] ...1 141.814060: rtcpu_vinotify_handle_msg: tstamp:4789419799 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:494451897 data:0x04370002
kworker/0:0-4 [000] ...1 141.814062: rtcpu_vinotify_handle_msg: tstamp:4789419943 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:494451938 data:0x00000000
kworker/0:0-4 [000] ...1 141.814065: rtcpu_vinotify_handle_msg: tstamp:4789699746 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:494731889 data:0x00000001
kworker/0:0-4 [000] ...1 141.814067: rtcpu_vinotify_handle_msg: tstamp:4789699941 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:494731897 data:0x00000000
kworker/0:0-4 [000] ...1 141.814070: rtcpu_vinotify_handle_msg: tstamp:4789703275 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:2 vi_tstamp:494735550 data:0x08000000
kworker/0:0-4 [000] ...1 141.866103: rtcpu_vinotify_handle_msg: tstamp:4790461419 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:495493499 data:0x04370002
kworker/0:0-4 [000] ...1 141.866109: rtcpu_vinotify_handle_msg: tstamp:4790461599 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:495493540 data:0x00000000
kworker/0:0-4 [000] ...1 141.866111: rtcpu_vinotify_handle_msg: tstamp:4790741374 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:495773491 data:0x00000001
kworker/0:0-4 [000] ...1 141.866114: rtcpu_vinotify_handle_msg: tstamp:4790741623 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:495773498 data:0x00000000
kworker/0:0-4 [000] ...1 141.866116: rtcpu_vinotify_handle_msg: tstamp:4790745932 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:3 vi_tstamp:495778193 data:0x08000000
kworker/0:0-4 [000] ...1 141.918089: rtcpu_vinotify_handle_msg: tstamp:4791503022 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:496535100 data:0x04370002
kworker/0:0-4 [000] ...1 141.918095: rtcpu_vinotify_handle_msg: tstamp:4791503201 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:496535141 data:0x00000000
kworker/0:0-4 [000] ...1 141.918100: rtos_queue_peek_from_isr_failed: tstamp:4791685761 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 141.918102: rtcpu_vinotify_handle_msg: tstamp:4791782950 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:496815092 data:0x00000001
kworker/0:0-4 [000] ...1 141.918104: rtcpu_vinotify_handle_msg: tstamp:4791783143 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:496815100 data:0x00000000
kworker/0:0-4 [000] ...1 141.918106: rtcpu_vinotify_handle_msg: tstamp:4791786055 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:4 vi_tstamp:496818327 data:0x08000000
kworker/0:0-4 [000] ...1 141.918108: rtcpu_vinotify_handle_msg: tstamp:4792544577 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:497576702 data:0x04370002
kworker/0:0-4 [000] ...1 141.918110: rtcpu_vinotify_handle_msg: tstamp:4792544682 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:497576743 data:0x00000000
kworker/0:0-4 [000] ...1 141.918112: rtcpu_vinotify_handle_msg: tstamp:4792824527 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:497856694 data:0x00000001
kworker/0:0-4 [000] ...1 141.918114: rtcpu_vinotify_handle_msg: tstamp:4792824673 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:497856702 data:0x00000000
kworker/0:0-4 [000] ...1 141.918116: rtcpu_vinotify_handle_msg: tstamp:4792827923 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:5 vi_tstamp:497860215 data:0x08000000
kworker/0:0-4 [000] ...1 141.970048: rtcpu_vinotify_handle_msg: tstamp:4793586202 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:498618303 data:0x04370002
kworker/0:0-4 [000] ...1 141.970052: rtcpu_vinotify_handle_msg: tstamp:4793586343 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:498618344 data:0x00000000
kworker/0:0-4 [000] ...1 141.970054: rtcpu_vinotify_handle_msg: tstamp:4793866155 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:498898295 data:0x00000001
kworker/0:0-4 [000] ...1 141.970055: rtcpu_vinotify_handle_msg: tstamp:4793866348 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:498898302 data:0x00000000
kworker/0:0-4 [000] ...1 141.970056: rtcpu_vinotify_handle_msg: tstamp:4793869010 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:6 vi_tstamp:498901287 data:0x08000000
kworker/0:0-4 [000] ...1 141.970058: rtcpu_vinotify_handle_msg: tstamp:4794627798 tag:CHANSEL_PXL_EOF channel:0x00 frame:6 vi_tstamp:499659905 data:0x04370002
kworker/0:0-4 [000] ...1 141.970059: rtcpu_vinotify_handle_msg: tstamp:4794627938 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:499659945 data:0x00000000
kworker/0:0-4 [000] ...1 142.022056: rtcpu_vinotify_handle_msg: tstamp:4794907751 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:499939897 data:0x00000001
kworker/0:0-4 [000] ...1 142.022062: rtcpu_vinotify_handle_msg: tstamp:4794907947 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:499939904 data:0x00000000
kworker/0:0-4 [000] ...1 142.022064: rtcpu_vinotify_handle_msg: tstamp:4794910505 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:7 vi_tstamp:499942782 data:0x08000000
kworker/0:0-4 [000] ...1 142.022066: rtcpu_vinotify_handle_msg: tstamp:4795669398 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:500701506 data:0x04370002
kworker/0:0-4 [000] ...1 142.022067: rtcpu_vinotify_handle_msg: tstamp:4795669538 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:500701547 data:0x00000000
kworker/0:0-4 [000] ...1 142.022068: rtcpu_vinotify_handle_msg: tstamp:4795949352 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:500981498 data:0x00000001
kworker/0:0-4 [000] ...1 142.022070: rtcpu_vinotify_handle_msg: tstamp:4795949544 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:500981506 data:0x00000000
kworker/0:0-4 [000] ...1 142.022071: rtcpu_vinotify_handle_msg: tstamp:4795954448 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:8 vi_tstamp:500986725 data:0x08000000
kworker/0:0-4 [000] ...1 142.074055: rtos_queue_peek_from_isr_failed: tstamp:4796686267 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.074060: rtcpu_vinotify_handle_msg: tstamp:4796710997 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:501743107 data:0x04370002
kworker/0:0-4 [000] ...1 142.074061: rtcpu_vinotify_handle_msg: tstamp:4796711134 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:501743148 data:0x00000000
kworker/0:0-4 [000] ...1 142.074063: rtcpu_vinotify_handle_msg: tstamp:4796990931 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:502023100 data:0x00000001
kworker/0:0-4 [000] ...1 142.074064: rtcpu_vinotify_handle_msg: tstamp:4796991079 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:502023107 data:0x00000000
kworker/0:0-4 [000] ...1 142.074066: rtcpu_vinotify_handle_msg: tstamp:4796995837 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:9 vi_tstamp:502028132 data:0x08000000
kworker/0:0-4 [000] ...1 142.074067: rtcpu_vinotify_handle_msg: tstamp:4797752606 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:502784709 data:0x04370002
kworker/0:0-4 [000] ...1 142.074068: rtcpu_vinotify_handle_msg: tstamp:4797752746 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:502784750 data:0x00000000
kworker/0:0-4 [000] ...1 142.126058: rtcpu_vinotify_handle_msg: tstamp:4798032558 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:503064701 data:0x00000001
kworker/0:0-4 [000] ...1 142.126063: rtcpu_vinotify_handle_msg: tstamp:4798032751 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:503064708 data:0x00000000
kworker/0:0-4 [000] ...1 142.126065: rtcpu_vinotify_handle_msg: tstamp:4798035265 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:10 vi_tstamp:503067540 data:0x08000000
kworker/0:0-4 [000] ...1 142.126066: rtcpu_vinotify_handle_msg: tstamp:4798794209 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:503826310 data:0x04370002
kworker/0:0-4 [000] ...1 142.126067: rtcpu_vinotify_handle_msg: tstamp:4798794349 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:503826351 data:0x00000000
kworker/0:0-4 [000] ...1 142.126069: rtcpu_vinotify_handle_msg: tstamp:4799074159 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:504106302 data:0x00000001
kworker/0:0-4 [000] ...1 142.126070: rtcpu_vinotify_handle_msg: tstamp:4799074359 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:504106310 data:0x00000000
kworker/0:0-4 [000] ...1 142.126072: rtcpu_vinotify_handle_msg: tstamp:4799077008 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:11 vi_tstamp:504109286 data:0x08000000
kworker/0:0-4 [000] ...1 142.178051: rtcpu_vinotify_handle_msg: tstamp:4799835810 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:504867912 data:0x04370002
kworker/0:0-4 [000] ...1 142.178056: rtcpu_vinotify_handle_msg: tstamp:4799835950 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:504867952 data:0x00000000
kworker/0:0-4 [000] ...1 142.178057: rtcpu_vinotify_handle_msg: tstamp:4800115761 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:505147904 data:0x00000001
kworker/0:0-4 [000] ...1 142.178058: rtcpu_vinotify_handle_msg: tstamp:4800115953 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:505147911 data:0x00000000
kworker/0:0-4 [000] ...1 142.178060: rtcpu_vinotify_handle_msg: tstamp:4800118601 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:12 vi_tstamp:505150873 data:0x08000000
kworker/0:0-4 [000] ...1 142.178061: rtcpu_vinotify_handle_msg: tstamp:4800877410 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:505909513 data:0x04370002
kworker/0:0-4 [000] ...1 142.178063: rtcpu_vinotify_handle_msg: tstamp:4800877551 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:505909554 data:0x00000000
kworker/0:0-4 [000] ...1 142.178064: rtcpu_vinotify_handle_msg: tstamp:4801157364 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:506189505 data:0x00000001
kworker/0:0-4 [000] ...1 142.178065: rtcpu_vinotify_handle_msg: tstamp:4801157560 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:506189512 data:0x00000000
kworker/0:0-4 [000] ...1 142.178067: rtcpu_vinotify_handle_msg: tstamp:4801160131 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:13 vi_tstamp:506192407 data:0x08000000
kworker/0:0-4 [000] ...1 142.230067: rtos_queue_peek_from_isr_failed: tstamp:4801686776 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.230072: rtcpu_vinotify_handle_msg: tstamp:4801919033 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:506951114 data:0x04370002
kworker/0:0-4 [000] ...1 142.230073: rtcpu_vinotify_handle_msg: tstamp:4801919175 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:506951156 data:0x00000000
kworker/0:0-4 [000] ...1 142.230075: rtcpu_vinotify_handle_msg: tstamp:4802198963 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:507231107 data:0x00000001
kworker/0:0-4 [000] ...1 142.230076: rtcpu_vinotify_handle_msg: tstamp:4802199158 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:507231114 data:0x00000000
kworker/0:0-4 [000] ...1 142.230078: rtcpu_vinotify_handle_msg: tstamp:4802201845 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:14 vi_tstamp:507234121 data:0x08000000
kworker/0:0-4 [000] ...1 142.282074: rtcpu_vinotify_handle_msg: tstamp:4802960615 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:507992716 data:0x04370002
kworker/0:0-4 [000] ...1 142.282078: rtcpu_vinotify_handle_msg: tstamp:4802960755 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:507992757 data:0x00000000
kworker/0:0-4 [000] ...1 142.282080: rtcpu_vinotify_handle_msg: tstamp:4803240565 tag:CHANSEL_PXL_SOF channel:0x00 frame:15 vi_tstamp:508272708 data:0x00000001
kworker/0:0-4 [000] ...1 142.282081: rtcpu_vinotify_handle_msg: tstamp:4803240757 tag:ATOMP_FS channel:0x00 frame:15 vi_tstamp:508272715 data:0x00000000
kworker/0:0-4 [000] ...1 142.282083: rtcpu_vinotify_handle_msg: tstamp:4803243223 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:15 vi_tstamp:508275500 data:0x08000000
kworker/0:0-4 [000] ...1 142.282085: rtcpu_vinotify_handle_msg: tstamp:4804002208 tag:CHANSEL_PXL_EOF channel:0x00 frame:15 vi_tstamp:509034318 data:0x04370002
kworker/0:0-4 [000] ...1 142.282086: rtcpu_vinotify_handle_msg: tstamp:4804002348 tag:ATOMP_FE channel:0x00 frame:15 vi_tstamp:509034358 data:0x00000000
kworker/0:0-4 [000] ...1 142.282088: rtcpu_vinotify_handle_msg: tstamp:4804282163 tag:CHANSEL_PXL_SOF channel:0x00 frame:16 vi_tstamp:509314309 data:0x00000001
kworker/0:0-4 [000] ...1 142.282089: rtcpu_vinotify_handle_msg: tstamp:4804282356 tag:ATOMP_FS channel:0x00 frame:16 vi_tstamp:509314317 data:0x00000000
kworker/0:0-4 [000] ...1 142.282091: rtcpu_vinotify_handle_msg: tstamp:4804284910 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:16 vi_tstamp:509317189 data:0x08000000
kworker/0:0-4 [000] ...1 142.334055: rtcpu_vinotify_handle_msg: tstamp:4805043813 tag:CHANSEL_PXL_EOF channel:0x00 frame:16 vi_tstamp:510075918 data:0x04370002
kworker/0:0-4 [000] ...1 142.334060: rtcpu_vinotify_handle_msg: tstamp:4805043953 tag:ATOMP_FE channel:0x00 frame:16 vi_tstamp:510075960 data:0x00000000
kworker/0:0-4 [000] ...1 142.334061: rtcpu_vinotify_handle_msg: tstamp:4805323763 tag:CHANSEL_PXL_SOF channel:0x00 frame:17 vi_tstamp:510355911 data:0x00000001
kworker/0:0-4 [000] ...1 142.334063: rtcpu_vinotify_handle_msg: tstamp:4805323958 tag:ATOMP_FS channel:0x00 frame:17 vi_tstamp:510355918 data:0x00000000
kworker/0:0-4 [000] ...1 142.334064: rtcpu_vinotify_handle_msg: tstamp:4805326787 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:17 vi_tstamp:510359063 data:0x08000000
kworker/0:0-4 [000] ...1 142.386064: rtcpu_vinotify_handle_msg: tstamp:4806085412 tag:CHANSEL_PXL_EOF channel:0x00 frame:17 vi_tstamp:511117521 data:0x04370002
kworker/0:0-4 [000] ...1 142.386069: rtcpu_vinotify_handle_msg: tstamp:4806085552 tag:ATOMP_FE channel:0x00 frame:17 vi_tstamp:511117561 data:0x00000000
kworker/0:0-4 [000] ...1 142.386071: rtcpu_vinotify_handle_msg: tstamp:4806365365 tag:CHANSEL_PXL_SOF channel:0x00 frame:18 vi_tstamp:511397512 data:0x00000001
kworker/0:0-4 [000] ...1 142.386072: rtcpu_vinotify_handle_msg: tstamp:4806365558 tag:ATOMP_FS channel:0x00 frame:18 vi_tstamp:511397519 data:0x00000000
kworker/0:0-4 [000] ...1 142.386074: rtcpu_vinotify_handle_msg: tstamp:4806368552 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:18 vi_tstamp:511400831 data:0x08000000
kworker/0:0-4 [000] ...1 142.386077: rtos_queue_peek_from_isr_failed: tstamp:4806687283 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.386079: rtcpu_vinotify_handle_msg: tstamp:4807127019 tag:CHANSEL_PXL_EOF channel:0x00 frame:18 vi_tstamp:512159122 data:0x04370002
kworker/0:0-4 [000] ...1 142.386080: rtcpu_vinotify_handle_msg: tstamp:4807127159 tag:ATOMP_FE channel:0x00 frame:18 vi_tstamp:512159163 data:0x00000000
kworker/0:0-4 [000] ...1 142.386082: rtcpu_vinotify_handle_msg: tstamp:4807406972 tag:CHANSEL_PXL_SOF channel:0x00 frame:19 vi_tstamp:512439114 data:0x00000001
kworker/0:0-4 [000] ...1 142.386083: rtcpu_vinotify_handle_msg: tstamp:4807407166 tag:ATOMP_FS channel:0x00 frame:19 vi_tstamp:512439121 data:0x00000000
kworker/0:0-4 [000] ...1 142.386085: rtcpu_vinotify_handle_msg: tstamp:4807409761 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:19 vi_tstamp:512442038 data:0x08000000
kworker/0:0-4 [000] ...1 142.438050: rtcpu_vinotify_handle_msg: tstamp:4808168621 tag:CHANSEL_PXL_EOF channel:0x00 frame:19 vi_tstamp:513200723 data:0x04370002
kworker/0:0-4 [000] ...1 142.438056: rtcpu_vinotify_handle_msg: tstamp:4808168761 tag:ATOMP_FE channel:0x00 frame:19 vi_tstamp:513200764 data:0x00000000
kworker/0:0-4 [000] ...1 142.438057: rtcpu_vinotify_handle_msg: tstamp:4808448572 tag:CHANSEL_PXL_SOF channel:0x00 frame:20 vi_tstamp:513480715 data:0x00000001
kworker/0:0-4 [000] ...1 142.438058: rtcpu_vinotify_handle_msg: tstamp:4808448766 tag:ATOMP_FS channel:0x00 frame:20 vi_tstamp:513480723 data:0x00000000
kworker/0:0-4 [000] ...1 142.438060: rtcpu_vinotify_handle_msg: tstamp:4808451363 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:20 vi_tstamp:513483639 data:0x08000000
kworker/0:0-4 [000] ...1 142.438061: rtcpu_vinotify_handle_msg: tstamp:4809210224 tag:CHANSEL_PXL_EOF channel:0x00 frame:20 vi_tstamp:514242325 data:0x04370002
kworker/0:0-4 [000] ...1 142.438063: rtcpu_vinotify_handle_msg: tstamp:4809210364 tag:ATOMP_FE channel:0x00 frame:20 vi_tstamp:514242365 data:0x00000000
kworker/0:0-4 [000] ...1 142.490046: rtcpu_vinotify_handle_msg: tstamp:4809490173 tag:CHANSEL_PXL_SOF channel:0x00 frame:21 vi_tstamp:514522316 data:0x00000001
kworker/0:0-4 [000] ...1 142.490051: rtcpu_vinotify_handle_msg: tstamp:4809490367 tag:ATOMP_FS channel:0x00 frame:21 vi_tstamp:514522324 data:0x00000000
kworker/0:0-4 [000] ...1 142.490053: rtcpu_vinotify_handle_msg: tstamp:4809492889 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:21 vi_tstamp:514525168 data:0x08000000
kworker/0:0-4 [000] ...1 142.490054: rtcpu_vinotify_handle_msg: tstamp:4810251827 tag:CHANSEL_PXL_EOF channel:0x00 frame:21 vi_tstamp:515283926 data:0x04370002
kworker/0:0-4 [000] ...1 142.490056: rtcpu_vinotify_handle_msg: tstamp:4810251967 tag:ATOMP_FE channel:0x00 frame:21 vi_tstamp:515283967 data:0x00000000
kworker/0:0-4 [000] ...1 142.490057: rtcpu_vinotify_handle_msg: tstamp:4810531786 tag:CHANSEL_PXL_SOF channel:0x00 frame:22 vi_tstamp:515563918 data:0x00000001
kworker/0:0-4 [000] ...1 142.490059: rtcpu_vinotify_handle_msg: tstamp:4810531979 tag:ATOMP_FS channel:0x00 frame:22 vi_tstamp:515563926 data:0x00000000
kworker/0:0-4 [000] ...1 142.490060: rtcpu_vinotify_handle_msg: tstamp:4810534494 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:22 vi_tstamp:515566771 data:0x08000000
kworker/0:0-4 [000] ...1 142.542097: rtcpu_vinotify_handle_msg: tstamp:4811293425 tag:CHANSEL_PXL_EOF channel:0x00 frame:22 vi_tstamp:516325527 data:0x04370002
kworker/0:0-4 [000] ...1 142.542103: rtcpu_vinotify_handle_msg: tstamp:4811293565 tag:ATOMP_FE channel:0x00 frame:22 vi_tstamp:516325568 data:0x00000000
kworker/0:0-4 [000] ...1 142.542105: rtcpu_vinotify_handle_msg: tstamp:4811573376 tag:CHANSEL_PXL_SOF channel:0x00 frame:23 vi_tstamp:516605520 data:0x00000001
kworker/0:0-4 [000] ...1 142.542107: rtcpu_vinotify_handle_msg: tstamp:4811573572 tag:ATOMP_FS channel:0x00 frame:23 vi_tstamp:516605527 data:0x00000000
kworker/0:0-4 [000] ...1 142.542110: rtcpu_vinotify_handle_msg: tstamp:4811576270 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:23 vi_tstamp:516608547 data:0x08000000
kworker/0:0-4 [000] ...1 142.542115: rtos_queue_peek_from_isr_failed: tstamp:4811687791 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.542117: rtcpu_vinotify_handle_msg: tstamp:4812335028 tag:CHANSEL_PXL_EOF channel:0x00 frame:23 vi_tstamp:517367129 data:0x04370002
kworker/0:0-4 [000] ...1 142.542119: rtcpu_vinotify_handle_msg: tstamp:4812335204 tag:ATOMP_FE channel:0x00 frame:23 vi_tstamp:517367169 data:0x00000000
kworker/0:0-4 [000] ...1 142.594084: rtcpu_vinotify_handle_msg: tstamp:4812614977 tag:CHANSEL_PXL_SOF channel:0x00 frame:24 vi_tstamp:517647121 data:0x00000001
kworker/0:0-4 [000] ...1 142.594090: rtcpu_vinotify_handle_msg: tstamp:4812615171 tag:ATOMP_FS channel:0x00 frame:24 vi_tstamp:517647128 data:0x00000000
kworker/0:0-4 [000] ...1 142.594091: rtcpu_vinotify_handle_msg: tstamp:4812618950 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:24 vi_tstamp:517651229 data:0x08000000
kworker/0:0-4 [000] ...1 142.594093: rtcpu_vinotify_handle_msg: tstamp:4813376627 tag:CHANSEL_PXL_EOF channel:0x00 frame:24 vi_tstamp:518408730 data:0x04370002
kworker/0:0-4 [000] ...1 142.594094: rtcpu_vinotify_handle_msg: tstamp:4813376767 tag:ATOMP_FE channel:0x00 frame:24 vi_tstamp:518408772 data:0x00000000
kworker/0:0-4 [000] ...1 142.594095: rtcpu_vinotify_handle_msg: tstamp:4813656578 tag:CHANSEL_PXL_SOF channel:0x00 frame:25 vi_tstamp:518688722 data:0x00000001
kworker/0:0-4 [000] ...1 142.594097: rtcpu_vinotify_handle_msg: tstamp:4813656770 tag:ATOMP_FS channel:0x00 frame:25 vi_tstamp:518688730 data:0x00000000
kworker/0:0-4 [000] ...1 142.594099: rtcpu_vinotify_handle_msg: tstamp:4813659435 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:25 vi_tstamp:518691712 data:0x08000000
kworker/0:0-4 [000] ...1 142.646108: rtcpu_vinotify_handle_msg: tstamp:4814418229 tag:CHANSEL_PXL_EOF channel:0x00 frame:25 vi_tstamp:519450331 data:0x04370002
kworker/0:0-4 [000] ...1 142.646114: rtcpu_vinotify_handle_msg: tstamp:4814418369 tag:ATOMP_FE channel:0x00 frame:25 vi_tstamp:519450373 data:0x00000000
kworker/0:0-4 [000] ...1 142.646116: rtcpu_vinotify_handle_msg: tstamp:4814698180 tag:CHANSEL_PXL_SOF channel:0x00 frame:26 vi_tstamp:519730324 data:0x00000001
kworker/0:0-4 [000] ...1 142.646117: rtcpu_vinotify_handle_msg: tstamp:4814698372 tag:ATOMP_FS channel:0x00 frame:26 vi_tstamp:519730331 data:0x00000000
kworker/0:0-4 [000] ...1 142.646119: rtcpu_vinotify_handle_msg: tstamp:4814701127 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:26 vi_tstamp:519733405 data:0x08000000
kworker/0:0-4 [000] ...1 142.646121: rtcpu_vinotify_handle_msg: tstamp:4815459830 tag:CHANSEL_PXL_EOF channel:0x00 frame:26 vi_tstamp:520491933 data:0x04370002
kworker/0:0-4 [000] ...1 142.646123: rtcpu_vinotify_handle_msg: tstamp:4815459970 tag:ATOMP_FE channel:0x00 frame:26 vi_tstamp:520491974 data:0x00000000
kworker/0:0-4 [000] ...1 142.646124: rtcpu_vinotify_handle_msg: tstamp:4815739782 tag:CHANSEL_PXL_SOF channel:0x00 frame:27 vi_tstamp:520771925 data:0x00000001
kworker/0:0-4 [000] ...1 142.646126: rtcpu_vinotify_handle_msg: tstamp:4815739974 tag:ATOMP_FS channel:0x00 frame:27 vi_tstamp:520771932 data:0x00000000
kworker/0:0-4 [000] ...1 142.646128: rtcpu_vinotify_handle_msg: tstamp:4815742701 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:27 vi_tstamp:520774978 data:0x08000000
kworker/0:0-4 [000] ...1 142.698091: rtcpu_vinotify_handle_msg: tstamp:4816501432 tag:CHANSEL_PXL_EOF channel:0x00 frame:27 vi_tstamp:521533534 data:0x04370002
kworker/0:0-4 [000] ...1 142.698095: rtcpu_vinotify_handle_msg: tstamp:4816501578 tag:ATOMP_FE channel:0x00 frame:27 vi_tstamp:521533576 data:0x00000000
kworker/0:0-4 [000] ...1 142.698098: rtos_queue_peek_from_isr_failed: tstamp:4816688297 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.698100: rtcpu_vinotify_handle_msg: tstamp:4816781385 tag:CHANSEL_PXL_SOF channel:0x00 frame:28 vi_tstamp:521813526 data:0x00000001
kworker/0:0-4 [000] ...1 142.698101: rtcpu_vinotify_handle_msg: tstamp:4816781578 tag:ATOMP_FS channel:0x00 frame:28 vi_tstamp:521813534 data:0x00000000
kworker/0:0-4 [000] ...1 142.698102: rtcpu_vinotify_handle_msg: tstamp:4816784162 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:28 vi_tstamp:521816438 data:0x08000000
kworker/0:0-4 [000] ...1 142.750070: rtcpu_vinotify_handle_msg: tstamp:4817543034 tag:CHANSEL_PXL_EOF channel:0x00 frame:28 vi_tstamp:522575136 data:0x04370002
kworker/0:0-4 [000] ...1 142.750075: rtcpu_vinotify_handle_msg: tstamp:4817543187 tag:ATOMP_FE channel:0x00 frame:28 vi_tstamp:522575177 data:0x00000000
kworker/0:0-4 [000] ...1 142.750077: rtcpu_vinotify_handle_msg: tstamp:4817822985 tag:CHANSEL_PXL_SOF channel:0x00 frame:29 vi_tstamp:522855128 data:0x00000001
kworker/0:0-4 [000] ...1 142.750078: rtcpu_vinotify_handle_msg: tstamp:4817823181 tag:ATOMP_FS channel:0x00 frame:29 vi_tstamp:522855136 data:0x00000000
kworker/0:0-4 [000] ...1 142.750080: rtcpu_vinotify_handle_msg: tstamp:4817825870 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:29 vi_tstamp:522858149 data:0x08000000
kworker/0:0-4 [000] ...1 142.750081: rtcpu_vinotify_handle_msg: tstamp:4818584642 tag:CHANSEL_PXL_EOF channel:0x00 frame:29 vi_tstamp:523616738 data:0x04370002
kworker/0:0-4 [000] ...1 142.750083: rtcpu_vinotify_handle_msg: tstamp:4818584782 tag:ATOMP_FE channel:0x00 frame:29 vi_tstamp:523616778 data:0x00000000
kworker/0:0-4 [000] ...1 142.750085: rtcpu_vinotify_handle_msg: tstamp:4818864590 tag:CHANSEL_PXL_SOF channel:0x00 frame:30 vi_tstamp:523896730 data:0x00000001
kworker/0:0-4 [000] ...1 142.750086: rtcpu_vinotify_handle_msg: tstamp:4818864783 tag:ATOMP_FS channel:0x00 frame:30 vi_tstamp:523896737 data:0x00000000
kworker/0:0-4 [000] ...1 142.750088: rtcpu_vinotify_handle_msg: tstamp:4818867633 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:30 vi_tstamp:523899912 data:0x08000000
kworker/0:0-4 [000] ...1 142.802078: rtcpu_vinotify_handle_msg: tstamp:4819626215 tag:CHANSEL_PXL_EOF channel:0x00 frame:30 vi_tstamp:524658339 data:0x04370002
kworker/0:0-4 [000] ...1 142.802083: rtcpu_vinotify_handle_msg: tstamp:4819626323 tag:ATOMP_FE channel:0x00 frame:30 vi_tstamp:524658380 data:0x00000000
kworker/0:0-4 [000] ...1 142.802085: rtcpu_vinotify_handle_msg: tstamp:4819906202 tag:CHANSEL_PXL_SOF channel:0x00 frame:31 vi_tstamp:524938330 data:0x00000001
kworker/0:0-4 [000] ...1 142.802086: rtcpu_vinotify_handle_msg: tstamp:4819906396 tag:ATOMP_FS channel:0x00 frame:31 vi_tstamp:524938338 data:0x00000000
kworker/0:0-4 [000] ...1 142.802087: rtcpu_vinotify_handle_msg: tstamp:4819909067 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:31 vi_tstamp:524941343 data:0x08000000
kworker/0:0-4 [000] ...1 142.802088: rtcpu_vinotify_handle_msg: tstamp:4820667836 tag:CHANSEL_PXL_EOF channel:0x00 frame:31 vi_tstamp:525699940 data:0x04370002
kworker/0:0-4 [000] ...1 142.802090: rtcpu_vinotify_handle_msg: tstamp:4820667977 tag:ATOMP_FE channel:0x00 frame:31 vi_tstamp:525699981 data:0x00000000
kworker/0:0-4 [000] ...1 142.854094: rtcpu_vinotify_handle_msg: tstamp:4820947788 tag:CHANSEL_PXL_SOF channel:0x00 frame:32 vi_tstamp:525979932 data:0x00000001
kworker/0:0-4 [000] ...1 142.854099: rtcpu_vinotify_handle_msg: tstamp:4820947980 tag:ATOMP_FS channel:0x00 frame:32 vi_tstamp:525979940 data:0x00000000
kworker/0:0-4 [000] ...1 142.854100: rtcpu_vinotify_handle_msg: tstamp:4820950888 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:32 vi_tstamp:525983167 data:0x08000000
kworker/0:0-4 [000] ...1 142.854104: rtos_queue_peek_from_isr_failed: tstamp:4821688803 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 142.854106: rtcpu_vinotify_handle_msg: tstamp:4821709429 tag:CHANSEL_PXL_EOF channel:0x00 frame:32 vi_tstamp:526741542 data:0x04370002
kworker/0:0-4 [000] ...1 142.854107: rtcpu_vinotify_handle_msg: tstamp:4821709565 tag:ATOMP_FE channel:0x00 frame:32 vi_tstamp:526741582 data:0x00000000
kworker/0:0-4 [000] ...1 142.854109: rtcpu_vinotify_handle_msg: tstamp:4821989392 tag:CHANSEL_PXL_SOF channel:0x00 frame:33 vi_tstamp:527021534 data:0x00000001
kworker/0:0-4 [000] ...1 142.854110: rtcpu_vinotify_handle_msg: tstamp:4821989588 tag:ATOMP_FS channel:0x00 frame:33 vi_tstamp:527021541 data:0x00000000
kworker/0:0-4 [000] ...1 142.854112: rtcpu_vinotify_handle_msg: tstamp:4821992591 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:33 vi_tstamp:527024867 data:0x08000000
kworker/0:0-4 [000] ...1 142.906064: rtcpu_vinotify_handle_msg: tstamp:4822751041 tag:CHANSEL_PXL_EOF channel:0x00 frame:33 vi_tstamp:527783143 data:0x04370002
kworker/0:0-4 [000] ...1 142.906069: rtcpu_vinotify_handle_msg: tstamp:4822751185 tag:ATOMP_FE channel:0x00 frame:33 vi_tstamp:527783184 data:0x00000000
kworker/0:0-4 [000] ...1 142.906071: rtcpu_vinotify_handle_msg: tstamp:4823030993 tag:CHANSEL_PXL_SOF channel:0x00 frame:34 vi_tstamp:528063135 data:0x00000001
kworker/0:0-4 [000] ...1 142.906072: rtcpu_vinotify_handle_msg: tstamp:4823031185 tag:ATOMP_FS channel:0x00 frame:34 vi_tstamp:528063143 data:0x00000000
kworker/0:0-4 [000] ...1 142.906074: rtcpu_vinotify_handle_msg: tstamp:4823033720 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:34 vi_tstamp:528065997 data:0x08000000
kworker/0:0-4 [000] ...1 142.906075: rtcpu_vinotify_handle_msg: tstamp:4823792643 tag:CHANSEL_PXL_EOF channel:0x00 frame:34 vi_tstamp:528824744 data:0x04370002
kworker/0:0-4 [000] ...1 142.906077: rtcpu_vinotify_handle_msg: tstamp:4823792806 tag:ATOMP_FE channel:0x00 frame:34 vi_tstamp:528824786 data:0x00000000
kworker/0:0-4 [000] ...1 142.958096: rtcpu_vinotify_handle_msg: tstamp:4824072593 tag:CHANSEL_PXL_SOF channel:0x00 frame:35 vi_tstamp:529104737 data:0x00000001
kworker/0:0-4 [000] ...1 142.958101: rtcpu_vinotify_handle_msg: tstamp:4824072789 tag:ATOMP_FS channel:0x00 frame:35 vi_tstamp:529104744 data:0x00000000
kworker/0:0-4 [000] ...1 142.958102: rtcpu_vinotify_handle_msg: tstamp:4824075509 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:35 vi_tstamp:529107788 data:0x08000000
kworker/0:0-4 [000] ...1 142.958104: rtcpu_vinotify_handle_msg: tstamp:4824834241 tag:CHANSEL_PXL_EOF channel:0x00 frame:35 vi_tstamp:529866346 data:0x04370002
kworker/0:0-4 [000] ...1 142.958105: rtcpu_vinotify_handle_msg: tstamp:4824834381 tag:ATOMP_FE channel:0x00 frame:35 vi_tstamp:529866387 data:0x00000000
kworker/0:0-4 [000] ...1 142.958106: rtcpu_vinotify_handle_msg: tstamp:4825114194 tag:CHANSEL_PXL_SOF channel:0x00 frame:36 vi_tstamp:530146338 data:0x00000001
kworker/0:0-4 [000] ...1 142.958108: rtcpu_vinotify_handle_msg: tstamp:4825114388 tag:ATOMP_FS channel:0x00 frame:36 vi_tstamp:530146345 data:0x00000000
kworker/0:0-4 [000] ...1 142.958109: rtcpu_vinotify_handle_msg: tstamp:4825117071 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:36 vi_tstamp:530149351 data:0x08000000
kworker/0:0-4 [000] ...1 143.010067: rtcpu_vinotify_handle_msg: tstamp:4825875846 tag:CHANSEL_PXL_EOF channel:0x00 frame:36 vi_tstamp:530907947 data:0x04370002
kworker/0:0-4 [000] ...1 143.010071: rtcpu_vinotify_handle_msg: tstamp:4825875992 tag:ATOMP_FE channel:0x00 frame:36 vi_tstamp:530907988 data:0x00000000
kworker/0:0-4 [000] ...1 143.010072: rtcpu_vinotify_handle_msg: tstamp:4826155795 tag:CHANSEL_PXL_SOF channel:0x00 frame:37 vi_tstamp:531187939 data:0x00000001
kworker/0:0-4 [000] ...1 143.010073: rtcpu_vinotify_handle_msg: tstamp:4826155992 tag:ATOMP_FS channel:0x00 frame:37 vi_tstamp:531187947 data:0x00000000
kworker/0:0-4 [000] ...1 143.010074: rtcpu_vinotify_handle_msg: tstamp:4826158688 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:37 vi_tstamp:531190968 data:0x08000000
kworker/0:0-4 [000] ...1 143.010076: rtos_queue_peek_from_isr_failed: tstamp:4826689308 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 143.010077: rtcpu_vinotify_handle_msg: tstamp:4826917447 tag:CHANSEL_PXL_EOF channel:0x00 frame:37 vi_tstamp:531949548 data:0x04370002
kworker/0:0-4 [000] ...1 143.010078: rtcpu_vinotify_handle_msg: tstamp:4826917588 tag:ATOMP_FE channel:0x00 frame:37 vi_tstamp:531949590 data:0x00000000
kworker/0:0-4 [000] ...1 143.010079: rtcpu_vinotify_handle_msg: tstamp:4827197372 tag:CHANSEL_PXL_SOF channel:0x00 frame:38 vi_tstamp:532229541 data:0x00000001
kworker/0:0-4 [000] ...1 143.010080: rtcpu_vinotify_handle_msg: tstamp:4827197519 tag:ATOMP_FS channel:0x00 frame:38 vi_tstamp:532229548 data:0x00000000
kworker/0:0-4 [000] ...1 143.010081: rtcpu_vinotify_handle_msg: tstamp:4827199845 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:38 vi_tstamp:532232141 data:0x08000000
kworker/0:0-4 [000] ...1 143.062061: rtcpu_vinotify_handle_msg: tstamp:4827959024 tag:CHANSEL_PXL_EOF channel:0x00 frame:38 vi_tstamp:532991150 data:0x04370002
kworker/0:0-4 [000] ...1 143.062064: rtcpu_vinotify_handle_msg: tstamp:4827959129 tag:ATOMP_FE channel:0x00 frame:38 vi_tstamp:532991191 data:0x00000000
kworker/0:0-4 [000] ...1 143.062065: rtcpu_vinotify_handle_msg: tstamp:4828238974 tag:CHANSEL_PXL_SOF channel:0x00 frame:39 vi_tstamp:533271142 data:0x00000001
kworker/0:0-4 [000] ...1 143.062065: rtcpu_vinotify_handle_msg: tstamp:4828239122 tag:ATOMP_FS channel:0x00 frame:39 vi_tstamp:533271149 data:0x00000000
kworker/0:0-4 [000] ...1 143.062066: rtcpu_vinotify_handle_msg: tstamp:4828241351 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:39 vi_tstamp:533273647 data:0x08000000
kworker/0:0-4 [000] ...1 143.114055: rtcpu_vinotify_handle_msg: tstamp:4829000624 tag:CHANSEL_PXL_EOF channel:0x00 frame:39 vi_tstamp:534032751 data:0x04370002
kworker/0:0-4 [000] ...1 143.114058: rtcpu_vinotify_handle_msg: tstamp:4829000729 tag:ATOMP_FE channel:0x00 frame:39 vi_tstamp:534032793 data:0x00000000
kworker/0:0-4 [000] ...1 143.114058: rtcpu_vinotify_handle_msg: tstamp:4829280578 tag:CHANSEL_PXL_SOF channel:0x00 frame:40 vi_tstamp:534312743 data:0x00000001
kworker/0:0-4 [000] ...1 143.114059: rtcpu_vinotify_handle_msg: tstamp:4829280725 tag:ATOMP_FS channel:0x00 frame:40 vi_tstamp:534312752 data:0x00000000
kworker/0:0-4 [000] ...1 143.114060: rtcpu_vinotify_handle_msg: tstamp:4829282803 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:40 vi_tstamp:534315099 data:0x08000000
kworker/0:0-4 [000] ...1 143.114061: rtcpu_vinotify_handle_msg: tstamp:4830042225 tag:CHANSEL_PXL_EOF channel:0x00 frame:40 vi_tstamp:535074353 data:0x04370002
kworker/0:0-4 [000] ...1 143.114061: rtcpu_vinotify_handle_msg: tstamp:4830042330 tag:ATOMP_FE channel:0x00 frame:40 vi_tstamp:535074394 data:0x00000000
kworker/0:0-4 [000] ...1 143.114062: rtcpu_vinotify_handle_msg: tstamp:4830322180 tag:CHANSEL_PXL_SOF channel:0x00 frame:41 vi_tstamp:535354345 data:0x00000001
kworker/0:0-4 [000] ...1 143.114063: rtcpu_vinotify_handle_msg: tstamp:4830322328 tag:ATOMP_FS channel:0x00 frame:41 vi_tstamp:535354352 data:0x00000000
kworker/0:0-4 [000] ...1 143.114064: rtcpu_vinotify_handle_msg: tstamp:4830324509 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:41 vi_tstamp:535356805 data:0x08000000
kworker/0:0-4 [000] ...1 143.166072: rtcpu_vinotify_handle_msg: tstamp:4831083828 tag:CHANSEL_PXL_EOF channel:0x00 frame:41 vi_tstamp:536115954 data:0x04370002
kworker/0:0-4 [000] ...1 143.166076: rtcpu_vinotify_handle_msg: tstamp:4831083933 tag:ATOMP_FE channel:0x00 frame:41 vi_tstamp:536115995 data:0x00000000
kworker/0:0-4 [000] ...1 143.166077: rtcpu_vinotify_handle_msg: tstamp:4831363781 tag:CHANSEL_PXL_SOF channel:0x00 frame:42 vi_tstamp:536395946 data:0x00000001
kworker/0:0-4 [000] ...1 143.166078: rtcpu_vinotify_handle_msg: tstamp:4831363928 tag:ATOMP_FS channel:0x00 frame:42 vi_tstamp:536395953 data:0x00000000
kworker/0:0-4 [000] ...1 143.166079: rtcpu_vinotify_handle_msg: tstamp:4831366069 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:42 vi_tstamp:536398365 data:0x08000000
kworker/0:0-4 [000] ...1 143.166081: rtos_queue_peek_from_isr_failed: tstamp:4831689795 queue:0x0b4a3c58
kworker/0:0-4 [000] ...1 143.218069: rtcpu_vinotify_handle_msg: tstamp:4832125431 tag:CHANSEL_PXL_EOF channel:0x00 frame:42 vi_tstamp:537157556 data:0x04370002
kworker/0:0-4 [000] ...1 143.218074: rtcpu_vinotify_handle_msg: tstamp:4832125536 tag:ATOMP_FE channel:0x00 frame:42 vi_tstamp:537157597 data:0x00000000
kworker/0:0-4 [000] ...1 143.218076: rtcpu_vinotify_handle_msg: tstamp:4832405382 tag:CHANSEL_PXL_SOF channel:0x00 frame:43 vi_tstamp:537437548 data:0x00000001
kworker/0:0-4 [000] ...1 143.218077: rtcpu_vinotify_handle_msg: tstamp:4832405532 tag:ATOMP_FS channel:0x00 frame:43 vi_tstamp:537437556 data:0x00000000
kworker/0:0-4 [000] ...1 143.218079: rtcpu_vinotify_handle_msg: tstamp:4832407989 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:43 vi_tstamp:537440280 data:0x08000000
kworker/0:0-4 [000] ...1 143.218080: rtcpu_vinotify_handle_msg: tstamp:4833167029 tag:CHANSEL_PXL_EOF channel:0x00 frame:43 vi_tstamp:538199157 data:0x04370002
kworker/0:0-4 [000] ...1 143.218082: rtcpu_vinotify_handle_msg: tstamp:4833167134 tag:ATOMP_FE channel:0x00 frame:43 vi_tstamp:538199198 data:0x00000000
kworker/0:0-4 [000] ...1 143.218083: rtcpu_vinotify_handle_msg: tstamp:4833447006 tag:CHANSEL_PXL_SOF channel:0x00 frame:44 vi_tstamp:538479150 data:0x00000001
kworker/0:0-4 [000] ...1 143.218085: rtcpu_vinotify_handle_msg: tstamp:4833447200 tag:ATOMP_FS channel:0x00 frame:44 vi_tstamp:538479157 data:0x00000000
kworker/0:0-4 [000] ...1 143.218088: rtcpu_vinotify_handle_msg: tstamp:4833449968 tag:CHANSEL_LOAD_FRAMED ch
I can seem some of rtos_queue_peek_from_isr_failed error message does that mean something is wrong?
