Hi
Customer carrier board, tx2, JetPack 3.3.
If enable pcie x1 and x4, disable usb 3.0. Usb 2.0-2 don’t work.
If enable pcie x4 and usb 3.0. Usb 2.0-2 work.
Hi
Attach dts file.
extracted_proc.dts usb2.0-2 ok;
j33_proc.dts nok;
diff of dts.html is the diff file.
sorry, attach dts file fail.
this usb2.0-2 work
/dts-v1/;
model = "quill";
compatible = "nvidia,quill", "nvidia,tegra186";
nvidia,dtbbuildtime = "Jan 3 2019", "15:56:52";
serial-number = "0421318041407";
#address-cells = <0x2>;
nvidia,dtsfilename = "/data/git/JetPack-3.1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts";
#size-cells = <0x2>;
interrupt-parent = <0x1>;
mc {
reg = <0x0 0x2c10000 0x0 0x10000 0x0 0x2c20000 0x0 0x10000 0x0 0x2c30000 0x0 0x10000 0x0 0x2c40000 0x0 0x10000 0x0 0x2c50000 0x0 0x10000 0x0 0x2c60000 0x0 0x10000 0x0 0x2c70000 0x0 0x10000 0x0 0x2c80000 0x0 0x10000 0x0 0x2c90000 0x0 0x10000 0x0 0x2ca0000 0x0 0x10000>;
interrupts = <0x0 0xdf 0x4 0x0 0xe0 0x4>;
reg-ranges = <0x1>;
compatible = "nvidia,tegra-t18x-mc";
order-gpu-writes;
channels = <0x4>;
status = "okay";
int_count = <0x8>;
ecc_int_mask = <0x1c00>;
int_mask = <0xf3140>;
ahub {
reg = <0x0 0x2900800 0x0 0x800>;
compatible = "nvidia,tegra210-axbar";
clock-names = "ahub", "pll_a_out0", "apb2ape", "xbar.ape";
clocks = <0xd 0x57 0xd 0xf6 0xd 0x68 0xd 0x69>;
power-domains = <0x32>;
ranges = <0x2900000 0x0 0x2900000 0x20000>;
status = "okay";
#address-cells = <0x1>;
phandle = <0xca>;
#size-cells = <0x1>;
linux,phandle = <0xca>;
wakeup-disable;
i2s@2901000 {
reg = <0x2901000 0x100>;
pinctrl-0;
pinctrl-1;
compatible = "nvidia,tegra210-i2s";
clock-names = "i2s1", "pll_a_out0", "ext_audio_sync", "audio_sync";
fsync-width = <0x1f>;
clocks = <0xd 0x4f 0xd 0xf6 0xd 0x269 0xd 0xf7>;
nvidia,ahub-i2s-id = <0x0>;
status = "okay";
phandle = <0xcb>;
pinctrl-names = "dap_active", "dap_inactive";
linux,phandle = <0xcb>;
i2s@2901100 {
reg = <0x2901100 0x100>;
pinctrl-0;
pinctrl-1;
clock-names = "i2s2", "pll_a_out0", "ext_audio_sync", "audio_sync";
fsync-width = <0x0>;
clocks = <0xd 0x2a 0xd 0xf6 0xd 0x26a 0xd 0xf8>;
nvidia,ahub-i2s-id = <0x1>;
status = "okay";
phandle = <0xcd>;
linux,phandle = <0xcd>;
i2s@2901200 {
reg = <0x2901200 0x100>;
pinctrl-0 = <0xe6>;
pinctrl-1;
clock-names = "i2s3", "pll_a_out0", "ext_audio_sync", "audio_sync";
clocks = <0xd 0x2b 0xd 0xf6 0xd 0x26b 0xd 0xf9>;
nvidia,ahub-i2s-id = <0x2>;
nvidia,is-pinctrl = <0x1>;
status = "okay";
phandle = <0xcf>;
linux,phandle = <0xcf>;
i2s@2901300 {
reg = <0x2901300 0x100>;
pinctrl-0;
pinctrl-1;
clock-names = "i2s4", "pll_a_out0", "ext_audio_sync", "audio_sync";
clocks = <0xd 0x54 0xd 0xf6 0xd 0x26c 0xd 0xfa>;
nvidia,ahub-i2s-id = <0x3>;
status = "okay";
phandle = <0xd1>;
linux,phandle = <0xd1>;
i2s@2901400 {
reg = <0x2901400 0x100>;
pinctrl-0;
pinctrl-1;
clock-names = "i2s5", "pll_a_out0", "ext_audio_sync", "audio_sync";
clocks = <0xd 0x55 0xd 0xf6 0xd 0x26d 0xd 0xfb>;
nvidia,ahub-i2s-id = <0x4>;
status = "okay";
phandle = <0xd3>;
linux,phandle = <0xd3>;
i2s@2901500 {
reg = <0x2901500 0x100>;
pinctrl-0;
pinctrl-1;
clock-names = "i2s6", "pll_a_out0", "ext_audio_sync", "audio_sync";
clocks = <0xd 0x9a 0xd 0xf6 0xd 0x26e 0xd 0xfc>;
nvidia,ahub-i2s-id = <0x5>;
status = "okay";
phandle = <0xd5>;
linux,phandle = <0xd5>;
mvc@290a000 {
reg = <0x290a000 0x200>;
compatible = "nvidia,tegra210-mvc";
nvidia,ahub-mvc-id = <0x0>;
status = "okay";
mvc@290a200 {
reg = <0x290a200 0x200>;
nvidia,ahub-mvc-id = <0x1>;
status = "okay";
afc@2907000 {
reg = <0x2907000 0x100>;
compatible = "nvidia,tegra210-afc";
nvidia,ahub-afc-id = <0x0>;
status = "okay";
afc@2907100 {
reg = <0x2907100 0x100>;
nvidia,ahub-afc-id = <0x1>;
status = "okay";
afc@2907200 {
reg = <0x2907200 0x100>;
nvidia,ahub-afc-id = <0x2>;
status = "okay";
afc@2907300 {
reg = <0x2907300 0x100>;
nvidia,ahub-afc-id = <0x3>;
status = "okay";
afc@2907400 {
reg = <0x2907400 0x100>;
nvidia,ahub-afc-id = <0x4>;
status = "okay";
afc@2907500 {
reg = <0x2907500 0x100>;
nvidia,ahub-afc-id = <0x5>;
status = "okay";
ope@2908000 {
reg = <0x2908000 0x100 0x2908100 0x100 0x2908200 0x200>;
compatible = "nvidia,tegra210-ope";
nvidia,ahub-ope-id = <0x0>;
status = "okay";
mbdrc@2908200 {
status = "okay";
peq@2908100 {
status = "okay";
amixer@290bb00 {
reg = <0x290bb00 0x800>;
compatible = "nvidia,tegra210-amixer";
nvidia,ahub-amixer-id = <0x0>;
status = "okay";
sfc@2902000 {
reg = <0x2902000 0x200>;
compatible = "nvidia,tegra210-sfc";
nvidia,ahub-sfc-id = <0x0>;
status = "okay";
sfc@2902200 {
reg = <0x2902200 0x200>;
nvidia,ahub-sfc-id = <0x1>;
status = "okay";
sfc@2902400 {
reg = <0x2902400 0x200>;
nvidia,ahub-sfc-id = <0x2>;
status = "okay";
sfc@2902600 {
reg = <0x2902600 0x200>;
nvidia,ahub-sfc-id = <0x3>;
status = "okay";
dspk@2905000 {
reg = <0x2905000 0x100>;
nvidia,ahub-dspk-id = <0x0>;
compatible = "nvidia,tegra186-dspk";
clock-names = "dspk", "pll_a_out0", "sync_dspk";
clocks = <0xd 0x98 0xd 0xf6 0xd 0xfd>;
status = "okay";
phandle = <0xe1>;
linux,phandle = <0xe1>;
dspk@2905100 {
reg = <0x2905100 0x100 0x2431000 0x1f0>;
nvidia,ahub-dspk-id = <0x1>;
clocks = <0xd 0x99 0xd 0xf6 0xd 0xfe>;
status = "okay";
phandle = <0xe3>;
linux,phandle = <0xe3>;
prod-settings {
#prod-cells = <0x4>;
prod {
prod = <0x1 0x8 0xfff 0x441 0x1 0x0 0xfff 0x441>;
spdif@2906000 {
reg = <0x2906000 0x200>;
pinctrl-0;
pinctrl-1;
nvidia,ahub-spdif-id = <0x0>;
compatible = "nvidia,tegra210-spdif";
clock-names = "spdif_in", "spdif_out", "spdif_doubler", "sync_spdif", "pll_a_out0", "pll_p_out0";
clocks = <0xd 0x2c 0xd 0xee 0xd 0x2d 0xd 0x104 0xd 0xf6 0xd 0x10d>;
status = "okay";
phandle = <0xdf>;
linux,phandle = <0xdf>;
arad@290e400 {
reg = <0x290e400 0x400>;
compatible = "nvidia,tegra186-arad";
status = "disabled";
nvidia,ahub-arad-id = <0x0>;
admaif@290f000 {
reg = <0x290f000 0x1000>;
dmas = <0xe5 0x1 0xe5 0x1 0xe5 0x2 0xe5 0x2 0xe5 0x3 0xe5 0x3 0xe5 0x4 0xe5 0x4 0xe5 0x5 0xe5 0x5 0xe5 0x6 0xe5 0x6 0xe5 0x7 0xe5 0x7 0xe5 0x8 0xe5 0x8 0xe5 0x9 0xe5 0x9 0xe5 0xa 0xe5 0xa 0xe5 0xb 0xe5 0xb 0xe5 0xc 0xe5 0xc 0xe5 0xd 0xe5 0xd 0xe5 0xe 0xe5 0xe 0xe5 0xf 0xe5 0xf 0xe5 0x10 0xe5 0x10 0xe5 0x11 0xe5 0x11 0xe5 0x12 0xe5 0x12 0xe5 0x13 0xe5 0x13 0xe5 0x14 0xe5 0x14>;
dma-buffer-size = <0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000 0x8000>;
compatible = "nvidia,tegra210-admaif";
clock-names = "ahub";
clocks = <0xd 0x57>;
status = "okay";
dma-names = "rx1", "tx1", "rx2", "tx2", "rx3", "tx3", "rx4", "tx4", "rx5", "tx5", "rx6", "tx6", "rx7", "tx7", "rx8", "tx8", "rx9", "tx9", "rx10", "tx10", "rx11", "tx11", "rx12", "tx12", "rx13", "tx13", "rx14", "tx14", "rx15", "tx15", "rx16", "tx16", "rx17", "tx17", "rx18", "tx18", "rx19", "tx19", "rx20", "tx20";
ahc@290b900 {
reg = <0x290b900 0x200>;
interrupts = <0x0 0x38 0x4 0x0>;
compatible = "nvidia,tegra186-ahc";
status = "okay";
interrupt-parent = <0x47>;
adx@2903800 {
reg = <0x2903800 0x100>;
compatible = "nvidia,tegra210-adx";
nvidia,ahub-adx-id = <0x0>;
status = "okay";
adx@2903900 {
reg = <0x2903900 0x100>;
nvidia,ahub-adx-id = <0x1>;
status = "okay";
adx@2903a00 {
reg = <0x2903a00 0x100>;
nvidia,ahub-adx-id = <0x2>;
status = "okay";
adx@2903b00 {
reg = <0x2903b00 0x100>;
nvidia,ahub-adx-id = <0x3>;
status = "okay";
spkprot@2908c00 {
reg = <0x2908c00 0x400>;
compatible = "nvidia,tegra210-spkprot";
nvidia,ahub-spkprot-id = <0x0>;
status = "okay";
dmic@2904000 {
reg = <0x2904000 0x100>;
nvidia,ahub-dmic-id = <0x0>;
pinctrl-0 = <0xe7>;
pinctrl-1;
compatible = "nvidia,tegra210-dmic";
clock-names = "dmic1", "pll_a_out0", "sync_dmic1";
clocks = <0xd 0x7a 0xd 0xf6 0xd 0xff>;
status = "okay";
phandle = <0xd7>;
linux,phandle = <0xd7>;
dmic@2904100 {
reg = <0x2904100 0x100>;
nvidia,ahub-dmic-id = <0x1>;
pinctrl-0 = <0xe8>;
pinctrl-1;
clock-names = "dmic2", "pll_a_out0", "sync_dmic2";
clocks = <0xd 0x7b 0xd 0xf6 0xd 0x100>;
status = "okay";
phandle = <0xd9>;
linux,phandle = <0xd9>;
dmic@2904200 {
reg = <0x2904200 0x100 0xc303000 0x1f0>;
nvidia,ahub-dmic-id = <0x2>;
pinctrl-0 = <0xe9>;
pinctrl-1 = <0xea>;
clock-names = "dmic3", "pll_a_out0", "sync_dmic3";
clocks = <0xd 0x96 0xd 0xf6 0xd 0x101>;
status = "okay";
phandle = <0xdb>;
linux,phandle = <0xdb>;
prod-settings {
prod {
prod = <0x1 0x28 0xffff 0x6441 0x1 0x30 0xffff 0x6441>;
dmic@2904300 {
reg = <0x2904300 0x100>;
nvidia,ahub-dmic-id = <0x3>;
pinctrl-0 = <0xeb>;
pinctrl-1;
clock-names = "dmic4", "pll_a_out0", "sync_dmic4";
clocks = <0xd 0x97 0xd 0xf6 0xd 0x103>;
status = "okay";
phandle = <0xdd>;
linux,phandle = <0xdd>;
iqc@290e000 {
reg = <0x290e000 0x200>;
compatible = "nvidia,tegra210-iqc";
clock-names = "iqc";
clocks = <0xd 0x6a>;
nvidia,ahub-iqc-id = <0x0>;
status = "okay";
amx@2903000 {
reg = <0x2903000 0x100>;
compatible = "nvidia,tegra210-amx";
nvidia,ahub-amx-id = <0x0>;
status = "okay";
amx@2903100 {
reg = <0x2903100 0x100>;
nvidia,ahub-amx-id = <0x1>;
status = "okay";
amx@2903200 {
reg = <0x2903200 0x100>;
nvidia,ahub-amx-id = <0x2>;
status = "okay";
amx@2903300 {
reg = <0x2903300 0x100>;
nvidia,ahub-amx-id = <0x3>;
status = "okay";
asrc@2910000 {
reg = <0x2910000 0x2000>;
compatible = "nvidia,tegra186-asrc";
status = "okay";
nvidia,ahub-asrc-id = <0x0>;
bpmp {
reg = <0x0 0xd000000 0x0 0x800000 0x0 0x3004e000 0x0 0x1000 0x0 0x3004f000 0x0 0x1000>;
compatible = "nvidia,tegra186-bpmp";
carveout-size = <0x200000>;
carveout-start = <0x77800000>;
status = "okay";
phandle = <0x79>;
#stream-id-cells = <0x1>;
linux,phandle = <0x79>;
bpmpthermal {
#thermal-sensor-cells = <0x1>;
compatible = "nvidia,tegra186-bpmp-thermal";
status = "okay";
phandle = <0x34>;
linux,phandle = <0x34>;
cpus {
#size-cells = <0x0>;
denver_crossover_thresholds {
compatible = "nvidia,tegra186-cpuidle-denver-thresholds";
thresholds {
crossover_c1_c6 = <0x3e8>;
crossover_cc1_cc6 = <0x1388>;
crossover_cc1_cc7 = <0x4e20>;
a57_cluster_power_states {
compatible = "nvidia,tegra186-cpuidle-a57-cluster";
cc1 {
power = <0x41>;
state-name = "Cluster clock gated";
status = "okay";
wakeup-latency-us = <0x1>;
min-residency-us = <0x1>;
pmstate = <0x1>;
cc6 {
power = <0x13>;
state-name = "Cluster powergate";
status = "okay";
wakeup-latency-us = <0x15e>;
min-residency-us = <0x1388>;
pmstate = <0x6>;
cc7 {
power = <0x5>;
state-name = "Cluster railgate";
wakeup-latency-us = <0x50>;
min-residency-us = <0x320>;
pmstate = <0x7>;
l2-cache0 {
compatible = "cache";
cache-level = <0x2>;
phandle = <0x6>;
cache-unified;
linux,phandle = <0x6>;
l2-cache1 {
phandle = <0x4>;
cache-unified;
linux,phandle = <0x4>;
cpu@0 {
reg = <0x0 0x0>;
cpu-ipc = <0x400>;
next-level-cache = <0x4>;
compatible = "nvidia,denver", "arm,armv8";
enable-method = "psci";
device_type = "cpu";
cpu-idle-states = <0x2 0x3>;
status = "okay";
phandle = <0x7>;
linux,phandle = <0x7>;
cpu@1 {
reg = <0x0 0x1>;
cpu-ipc = <0x400>;
status = "okay";
phandle = <0x8>;
linux,phandle = <0x8>;
cpu@2 {
reg = <0x0 0x100>;
cpu-ipc = <0x2f0>;
next-level-cache = <0x6>;
compatible = "arm,cortex-a57-64bit", "arm,armv8";
cpu-idle-states = <0x5>;
status = "okay";
phandle = <0x9>;
linux,phandle = <0x9>;
cpu@3 {
reg = <0x0 0x101>;
cpu-ipc = <0x2f0>;
status = "okay";
phandle = <0xa>;
linux,phandle = <0xa>;
cpu@4 {
reg = <0x0 0x102>;
cpu-ipc = <0x2f0>;
status = "okay";
phandle = <0xb>;
linux,phandle = <0xb>;
cpu@5 {
reg = <0x0 0x103>;
cpu-ipc = <0x2f0>;
status = "okay";
phandle = <0xc>;
linux,phandle = <0xc>;
a57_core_power_states {
compatible = "nvidia,tegra186-cpuidle-a57";
c1 {
power = <0x46>;
state-name = "Clock gated";
status = "okay";
pmstate = <0x1>;
c7 {
power = <0x3c>;
arm,psci-suspend-param = <0x40000007>;
state-name = "Core powergate";
status = "okay";
wakeup-latency-us = <0x82>;
phandle = <0x5>;
min-residency-us = <0xffffffff>;
pmstate = <0x7>;
linux,phandle = <0x5>;
a57_crossover_thresholds {
compatible = "nvidia,tegra186-cpuidle-a57-thresholds";
thresholds {
crossover_cc1_cc7 = <0x2bc>;
denver_core_power_states {
compatible = "nvidia,tegra186-cpuidle-denver";
c1 {
power = <0x46>;
status = "okay";
pmstate = <0x1>;
c6 {
power = <0x3c>;
arm,psci-suspend-param = <0x6>;
state-name = "Virtual core powergate";
status = "okay";
wakeup-latency-us = <0xbe>;
phandle = <0x2>;
pmstate = <0x6>;
linux,phandle = <0x2>;
c7 {
power = <0x3c>;
status = "okay";
wakeup-latency-us = <0x230>;
phandle = <0x3>;
pmstate = <0x7>;
linux,phandle = <0x3>;
denver_cluster_power_states {
compatible = "nvidia,tegra186-cpuidle-denver-cluster";
cc1 {
power = <0x41>;
status = "okay";
pmstate = <0x1>;
cc6 {
power = <0x13>;
status = "okay";
wakeup-latency-us = <0x1c2>;
pmstate = <0x6>;
cc7 {
power = <0x5>;
pmstate = <0x7>;
pfsd {
tach_period = <0x3e8>;
step_time = <0x64>;
state_cap_lookup = <0x2 0x2 0x2 0x2 0x3 0x3 0x3 0x4 0x4 0x4>;
active_rpm = <0x0 0x3e8 0x7d0 0xbb8 0xfa0 0x1388 0x1770 0x1b58 0x2710 0x2af8>;
active_rrd = <0x28 0x2 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x1>;
active_rru = <0x28 0x2 0x1 0x1 0x1 0x1 0x1 0x1 0x1 0x1>;
num_resources = <0x0>;
pwm_gpio = <0x1c 0x16 0x1>;
rpm_diff_tolerance = <0x2>;
pwm_id = <0x3>;
secret = <0x2f>;
status = "okay";
active_pwm_max = <0x100>;
state_cap = <0x7>;
active_steps = <0xa>;
phandle = <0x106>;
pwm_period = <0xb116>;
linux,phandle = <0x106>;
psci {
cpu_off = <0x84000002>;
compatible = "arm,psci-1.0";
cpu_suspend = <0xc4000001>;
cpu_on = <0xc4000003>;
method = "smc";
status = "okay";
xotg {
phys = <0x94 0x10>;
interrupts = <0x0 0xa7 0x4>;
#extcon-cells = <0x1>;
compatible = "nvidia,tegra186-xotg";
phy-names = "otg-usb2";
adp-disable;
status = "okay";
phandle = <0x97>;
otg-rev = <0x300>;
extcon-cables = <0x95 0x1 0x95 0x0>;
linux,phandle = <0x97>;
extcon-cable-names = "id", "vbus";
tegra-pmc-blink-pwm {
compatible = "nvidia,tegra210-pmc-blink-pwm";
bpmp_i2c {
compatible = "nvidia,tegra186-bpmp-i2c";
adapter = <0x5>;
status = "okay";
spmic@3c {
reg = <0x3c>;
interrupts = <0x0 0xd1 0x0>;
#thermal-sensor-cells = <0x0>;
pinctrl-0 = <0x2c>;
#gpio-cells = <0x2>;
compatible = "maxim,max77620";
#interrupt-cells = <0x2>;
maxim,system-pmic-power-off;
maxim,avoid-power-off-commands;
phandle = <0x18>;
maxim,enable-clock32k-out;
maxim,hot-die-threshold-temp = <0x1adb0>;
interrupt-controller;
gpio-controller;
pinctrl-names = "default";
linux,phandle = <0x18>;
interrupt-parent = <0x2b>;
fps {
fps0 {
maxim,shutdown-fps-time-period-us = <0x280>;
maxim,fps-event-source = <0x0>;
fps1 {
maxim,fps-event-source = <0x1>;
maxim,device-state-on-disabled-event = <0x0>;
fps2 {
maxim,shutdonw-fps-time-period-us = <0x280>;
spmic_gpio_input {
gpios = <0x5 0x0 0x6 0x0>;
input;
label = "spmic_gpio_input_5", "spmic_gpio_input_6";
gpio-hog;
pinmux@0 {
phandle = <0x2c>;
linux,phandle = <0x2c>;
pin_gpio0 {
pins = "gpio0";
function = "gpio";
pin_gpio1 {
pins = "gpio1";
function = "fps-out";
maxim,active-fps-power-down-slot = <0x3>;
maxim,active-fps-power-up-slot = <0x1>;
maxim,active-fps-source = <0x0>;
pin_gpio2 {
pins = "gpio2";
maxim,active-fps-power-down-slot = <0x1>;
maxim,active-fps-power-up-slot = <0x7>;
maxim,active-fps-source = <0x1>;
pin_gpio3 {
pins = "gpio3";
maxim,active-fps-power-down-slot = <0x7>;
pin_gpio4 {
pins = "gpio4";
function = "32k-out1";
drive-push-pull = <0x1>;
pin_gpio5 {
pins = "gpio5";
function = "gpio";
drive-push-pull = <0x0>;
pin_gpio6 {
pins = "gpio6";
function = "gpio";
pin_gpio7 {
pins = "gpio7";
function = "gpio";
watchdog {
maxim,wdt-timeout = <0x10>;
maxim,wdt-clear-time = <0xd>;
phandle = <0x10d>;
linux,phandle = <0x10d>;
regulators {
in-ldo6-supply = <0xe>;
in-ldo7-8-supply = <0x2d>;
in-ldo4-supply = <0xe>;
sd0 {
regulator-name = "vddio-ddr";
regulator-init-mode = <0x2>;
maxim,active-fps-power-down-slot = <0x2>;
regulator-always-on;
regulator-disable-ramp-delay = <0x255a8>;
maxim,ramp-rate-setting = <0x6b6c>;
maxim,active-fps-power-up-slot = <0x5>;
phandle = <0xa3>;
regulator-boot-on;
regulator-enable-ramp-delay = <0x116>;
regulator-ramp-delay = <0xf5a>;
linux,phandle = <0xa3>;
sd1 {
regulator-name = "avdd_dsi_csi";
regulator-min-microvolt = <0x124f80>;
regulator-disable-ramp-delay = <0x9c40>;
maxim,active-fps-power-up-slot = <0x3>;
regulator-max-microvolt = <0x124f80>;
phandle = <0x2d>;
regulator-boot-on;
regulator-enable-ramp-delay = <0xd3>;
regulator-ramp-delay = <0x157c>;
linux,phandle = <0x2d>;
sd2 {
regulator-name = "vdd-1v8";
regulator-min-microvolt = <0x1b7740>;
regulator-disable-ramp-delay = <0x5208>;
maxim,active-fps-power-up-slot = <0x0>;
regulator-max-microvolt = <0x1b7740>;
phandle = <0xe>;
regulator-boot-on;
regulator-enable-ramp-delay = <0xfa0>;
regulator-ramp-delay = <0x1c2>;
linux,phandle = <0xe>;
sd3 {
regulator-name = "vdd-3v3-sys";
regulator-min-microvolt = <0x325aa0>;
maxim,active-fps-power-up-slot = <0x6>;
regulator-max-microvolt = <0x325aa0>;
phandle = <0xf>;
regulator-boot-on;
regulator-enable-ramp-delay = <0x23e>;
linux,phandle = <0xf>;
ldo0 {
regulator-name = "spmic-ldo0";
maxim,ramp-rate-setting = <0x186a0>;
maxim,active-fps-source = <0x3>;
phandle = <0x117>;
regulator-enable-ramp-delay = <0x3e8>;
regulator-ramp-delay = <0x186a0>;
linux,phandle = <0x117>;
ldo1 {
regulator-name = "spmic-ldo1";
maxim,active-fps-source = <0x4>;
ldo2 {
regulator-name = "vddio-3v3";
regulator-disable-ramp-delay = <0x36b0>;
phandle = <0xa4>;
regulator-boot-on;
regulator-enable-ramp-delay = <0x98>;
regulator-ramp-delay = <0x4e20>;
linux,phandle = <0xa4>;
ldo3 {
regulator-name = "vddio-sdmmc1";
regulator-disable-ramp-delay = <0x3e80>;
maxim,ramp-rate-setting = <0x1388>;
phandle = <0x13>;
regulator-enable-ramp-delay = <0xa0>;
regulator-ramp-delay = <0x3e8>;
linux,phandle = <0x13>;
ldo4 {
regulator-name = "vdd-rtc";
regulator-disable-ramp-delay = <0x672>;
regulator-boot-on;
regulator-enable-ramp-delay = <0x1a>;
regulator-ramp-delay = <0x80e8>;
ldo5 {
regulator-name = "avdd-ts-hv";
phandle = <0x11>;
regulator-enable-ramp-delay = <0x135>;
regulator-ramp-delay = <0x20e>;
linux,phandle = <0x11>;
ldo6 {
regulator-name = "spmic-ldo6";
phandle = <0x115>;
regulator-boot-on;
linux,phandle = <0x115>;
ldo7 {
regulator-name = "vdd-pex-1v05";
regulator-min-microvolt = <0xf4240>;
regulator-disable-ramp-delay = <0x3a98>;
maxim,active-fps-power-up-slot = <0x4>;
regulator-max-microvolt = <0xf4240>;
phandle = <0xbf>;
regulator-boot-on;
regulator-enable-ramp-delay = <0x5f>;
regulator-ramp-delay = <0x2710>;
linux,phandle = <0xbf>;
ldo8 {
regulator-name = "dvdd-pex";
phandle = <0x116>;
linux,phandle = <0x116>;
backup-battery {
maxim,backup-battery-charging-current = <0x64>;
maxim,backup-battery-output-resister = <0x64>;
maxim,backup-battery-charging-voltage = <0x2dc6c0>;
pmc-iopower {
vddio-sys-supply = <0x2e>;
vddio-ddr0-supply = <0xa3>;
vddio-audio-supply = <0x2e>;
pad-names = "ufs", "dbg", "spi", "audio-hv", "ao-hv", "dmic-hv", "sdmmc1-hv", "sdmmc2-hv", "sdmmc3-hv", "dsia", "dsib", "dsic", "dsid", "hdmi-dp0", "hdmi-dp1";
vddio-ao-supply = <0x2e>;
compatible = "nvidia,tegra186-pmc-iopower";
vddio-sdmmc4-supply = <0x2e>;
vddio-audio-hv-supply = <0x2e>;
vddio-sdmmc3-hv-supply = <0x11>;
vddio-sdmmc2-hv-supply = <0xf>;
vddio-cam-supply = <0x2e>;
vddio-ao-hv-supply = <0xa4>;
vddio-ufs-supply = <0x2e>;
vddio-ddr1-supply = <0xa3>;
vddio-edp-supply = <0x2e>;
status = "okay";
vddio-uart-supply = <0x2e>;
vddio-dmic-hv-supply = <0x2e>;
pad-controllers = <0x10 0x34 0xa 0x29 0x1 0x35 0xd 0x24 0x25 0x27 0xf 0x10 0x11 0x12 0x18 0x19>;
vddio-sdmmc1-hv-supply = <0x13>;
vddio-dbg-supply = <0x2e>;
vddio-spi-supply = <0x2e>;
vddio-pex-ctrl-supply = <0x2e>;
vddio-mipi-bias-supply = <0x2d>;
vddio-conn-supply = <0x2e>;
pwm-fan {
pwms = <0x105 0x0 0xb116>;
compatible = "pwm-fan";
vdd-fan-supply = <0x107>;
active_pwm = <0x0 0x50 0x78 0xa0 0xff 0xff 0xff 0xff 0xff 0xff>;
#pwm-cells = <0x1>;
status = "okay";
shared_data = <0x106>;
xudc@3550000 {
reg = <0x0 0x3550000 0x0 0x8000 0x0 0x3558000 0x0 0x1000>;
phys = <0x94 0x10>;
interrupts = <0x0 0xa6 0x4>;
otg-controller = <0x97>;
compatible = "nvidia,tegra186-xudc";
clock-names = "pll_u_480M", "dev", "ss", "pll_e";
avdd-usb-supply = <0xf>;
phy-names = "usb2";
clocks = <0xd 0x215 0xd 0x70 0xd 0x72 0xd 0x200>;
status = "okay";
emc-frequency = <0x8f0d180>;
phandle = <0x71>;
extcon-cables = <0x95 0x0>;
charger-detector = <0x98>;
linux,phandle = <0x71>;
extcon-cable-names = "vbus";
pinmux@2430000 {
reg = <0x0 0x2430000 0x0 0x15000 0x0 0xc300000 0x0 0x4000>;
pinctrl-0 = <0x15>;
compatible = "nvidia,tegra186-pinmux";
status = "okay";
phandle = <0xc8>;
#gpio-range-cells = <0x3>;
linux,phandle = <0xc8>;
vbus_en1_default {
phandle = <0xa1>;
linux,phandle = <0xa1>;
usb_vbus_en1_pl5 {
nvidia,enable-input = <0x1>;
nvidia,function = "rsvd1";
nvidia,pins = "usb_vbus_en1_pl5";
nvidia,io-high-voltage = <0x1>;
i2s3_dap_active {
phandle = <0xe6>;
linux,phandle = <0xe6>;
i2s3_dmic2_clk_pm3 {
nvidia,function = "i2s3";
nvidia,pins = "dmic2_clk_pm3";
i2s3_dmic2_dat_pm2 {
nvidia,pins = "dmic2_dat_pm2";
i2s3_dmic1_clk_pm1 {
nvidia,pins = "dmic1_clk_pm1";
i2s3_dmic1_dat_pm0 {
nvidia,pins = "dmic1_dat_pm0";
vbus_en1_oc_tristate {
phandle = <0x9d>;
linux,phandle = <0x9d>;
usb_vbus_en1_pl5 {
nvidia,tristate = <0x1>;
nvidia,function = "usb";
devslp_active {
phandle = <0x16>;
linux,phandle = <0x16>;
sata {
nvidia,enable-input = <0x0>;
nvidia,function = "sata";
nvidia,lpdr = <0x1>;
nvidia,pins = "pex_l2_clkreq_n_pa6";
nvidia,pull = <0x0>;
vbus_en0_default {
phandle = <0xa0>;
linux,phandle = <0xa0>;
usb_vbus_en0_pl4 {
nvidia,pins = "usb_vbus_en0_pl4";
common {
phandle = <0x15>;
linux,phandle = <0x15>;
gpio_edp2_pp5 {
nvidia,pins = "gpio_edp2_pp5";
nvidia,pull = <0x2>;
status = "okay";
gpio_edp3_pp6 {
nvidia,tristate = <0x0>;
nvidia,pins = "gpio_edp3_pp6";
status = "okay";
dmic1_dap_active {
phandle = <0xe7>;
linux,phandle = <0xe7>;
dmic_dmic1_clk_pm1 {
nvidia,function = "dmic1";
dmic_dmic1_dat_pm0 {
vbus_en1_oc_passthrough {
phandle = <0x9f>;
linux,phandle = <0x9f>;
usb_vbus_en1_pl5 {
dmic2_dap_active {
phandle = <0xe8>;
linux,phandle = <0xe8>;
dmic_dmic2_clk_pm3 {
nvidia,function = "dmic2";
dmic_dmic2_dat_pm2 {
devslp_pullup {
phandle = <0x17>;
linux,phandle = <0x17>;
sata {
dmic3_dap_active {
phandle = <0xe9>;
linux,phandle = <0xe9>;
dmic_can_gpio0_paa0 {
nvidia,function = "dmic3";
nvidia,pins = "can_gpio0_paa0";
dmic_can_gpio1_paa1 {
nvidia,pins = "can_gpio1_paa1";
vbus_en0_oc_passthrough {
phandle = <0x9e>;
linux,phandle = <0x9e>;
usb_vbus_en0_pl4 {
dmic3_dap_inactive {
phandle = <0xea>;
linux,phandle = <0xea>;
nvidia,function = "dmic5";
dmic4_dap_active {
phandle = <0xeb>;
linux,phandle = <0xeb>;
dmic_dmic4_clk_pm5 {
nvidia,function = "dmic4";
nvidia,pins = "dmic4_clk_pm5";
dmic_dmic4_dat_pm4 {
nvidia,pins = "dmic4_dat_pm4";
vbus_en0_oc_tristate {
phandle = <0x9c>;
linux,phandle = <0x9c>;
usb_vbus_en0_pl4 {
efuse@3820000 {
reg = <0x0 0x3820000 0x0 0x600>;
compatible = "nvidia,tegra186-efuse", "nvidia,tegra210-efuse";
clock-names = "fuse";
clocks = <0xd 0x0>;
status = "okay";
efuse-burn {
compatible = "nvidia,tegra186-efuse-burn";
clock-names = "clk_m";
nvidia,temp-range = <0x7148 0x18a88>;
clocks = <0xd 0x261>;
status = "okay";
nvidia,tz = <0x102>;
gpio@c2f0000 {
reg = <0x0 0xc2f0000 0x0 0x1000 0x0 0xc2f1000 0x0 0x1000>;
interrupts = <0x0 0x3c 0x4>;
reg-names = "security", "gpio";
compatible = "nvidia,tegra186-gpio-aon";
status = "okay";
phandle = <0x1c>;
gpio-ranges = <0xc8 0x0 0x90 0x8 0xc8 0x8 0xa0 0x18 0xc8 0x20 0xc8 0x10 0xc8 0x30 0xf0 0x10>;
gpio-controller;
linux,phandle = <0x1c>;
camera-control-output-high {
wifi-wake-ap {
gpios = <0x3b 0x0>;
input;
label = "wifi-wake-ap";
gpio-hog;
camera-control-output-low {
camera-control-input {
cpuidle {
compatible = "nvidia,tegra18x-cpuidle";
status = "okay";
etf@8030000 {
reg = <0x0 0x8030000 0x0 0x1000>;
compatible = "arm,coresight-tmc", "arm,primecell";
clock-names = "apb_pclk";
clocks = <0xd 0xc4>;
status = "okay";
coresight-default-sink;
ports {
port@0 {
reg = <0x0>;
endpoint {
slave-mode;
remote-endpoint = <0xfc>;
phandle = <0xf5>;
linux,phandle = <0xf5>;
port@1 {
reg = <0x0>;
endpoint {
remote-endpoint = <0xfd>;
phandle = <0xfb>;
linux,phandle = <0xfb>;
pwm@3280000 {
reg = <0x0 0x3280000 0x0 0x10000>;
compatible = "nvidia,tegra186-pwm";
clock-names = "pwm", "parent";
reset-names = "pwm";
clocks = <0xd 0xbb 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x63>;
status = "okay";
phandle = <0x1b>;
linux,phandle = <0x1b>;
pwm@3290000 {
reg = <0x0 0x3290000 0x0 0x10000>;
clocks = <0xd 0xbc 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x64>;
status = "okay";
gps_wake {
compatible = "gps-wake";
gps-wakeup-gpio = <0x12 0x85 0x0>;
gps-enable-gpio = <0x103 0x8 0x0>;
pwm@c340000 {
reg = <0x0 0xc340000 0x0 0x10000>;
clock-names = "pwm";
clocks = <0xd 0xe1>;
#pwm-cells = <0x2>;
resets = <0xd 0x66>;
status = "okay";
phandle = <0x105>;
linux,phandle = <0x105>;
external-connection {
compatible = "simple-bus";
device_type = "external-connection";
extcon@1 {
reg = <0x1>;
gpios = <0x12 0x9f 0x0 0x18 0x0 0x0>;
compatible = "extcon-gpio-states";
wakeup-source;
extcon-gpio,wait-for-gpio-scan = <0x0>;
extcon-gpio,out-cable-names = <0x1 0x2 0x0>;
phandle = <0x95>;
extcon-gpio,cable-states = <0x3 0x0 0x0 0x2 0x1 0x2 0x2 0x1>;
extcon-gpio,out-cable-name-strings = "USB", "USB-Host";
linux,phandle = <0x95>;
extcon-gpio,name = "VBUS";
adsp_audio {
interrupts = <0x0 0xa 0x4 0x4 0x0 0xb 0x4 0x4 0x0 0xc 0x4 0x4 0x0 0xd 0x4 0x4 0x0 0xe 0x4 0x4 0x0 0xf 0x4 0x4 0x0 0x10 0x4 0x4 0x0 0x11 0x4 0x4 0x0 0x12 0x4 0x4 0x0 0x13 0x4 0x4>;
compatible = "nvidia,tegra210-adsp-audio";
clock-names = "ahub", "ape", "apb2ape";
compr-ops = <0x1>;
clocks = <0xd 0x57 0xd 0x69 0xd 0x68>;
power-domains = <0xec>;
status = "okay";
phandle = <0x73>;
num-plugin = <0x5>;
linux,phandle = <0x73>;
wakeup-disable;
plugin-info-1 {
plugin-name = "mp3-dec1";
widget-name = "MP3-DEC1";
firmware-name = "nvmp3dec.elf";
plugin-info-2 {
plugin-name = "spkprot";
widget-name = "SPKPROT-SW";
firmware-name = "nvspkprot.elf";
plugin-info-3 {
plugin-name = "src";
widget-name = "SRC";
firmware-name = "nvsrc.elf";
plugin-info-4 {
plugin-name = "aac-dec1";
widget-name = "AAC-DEC1";
firmware-name = "nvaacdec.elf";
plugin-info-5 {
plugin-name = "aec";
widget-name = "AEC";
firmware-name = "nvoice.elf";
timer@3020000 {
reg = <0x0 0x3010000 0x0 0xe0000>;
interrupts = <0x0 0x0 0x4 0x0 0x1 0x4 0x0 0x2 0x4 0x0 0x3 0x4 0x0 0x4 0x4 0x0 0x5 0x4 0x0 0x6 0x4>;
compatible = "nvidia,tegra186-timer";
wdt-count = <0x3>;
clock-frequency = <0x124f800>;
tmr-count = <0xa>;
status = "okay";
chipid@100000 {
reg = <0x0 0x100000 0x0 0x10000>;
compatible = "nvidia,tegra186-chipid";
bthrot_cdev {
compatible = "nvidia,tegra18x-balanced-throttle";
clock-names = "mcpu", "bcpu", "gpu", "emc";
clocks = <0xd 0x242 0xd 0x243 0xd 0x136 0xd 0x3a>;
skin_balanced {
throttle_table = <0x1d8760 0x1d8760 0x1314c4 0xffffffff 0x1d2658 0x1d2658 0x12cf9c 0xffffffff 0x1cc550 0x1cc550 0x128a74 0xffffffff 0x1c6448 0x1c6448 0x12454c 0xffffffff 0x1c0340 0x1c0340 0x120025 0xffffffff 0x1ba238 0x1ba238 0x11bafd 0xffffffff 0x1b4130 0x1b4130 0x1175d5 0xffffffff 0x1ae028 0x1ae028 0x1130ad 0xffffffff 0x1a7f20 0x1a7f20 0x10eb85 0xffffffff 0x1a1e18 0x1a1e18 0x10a65d 0xffffffff 0x19bd10 0x19bd10 0x106136 0xffffffff 0x195c08 0x195c08 0x101c0e 0xffffffff 0x18fb00 0x18fb00 0xfd6e6 0xffffffff 0x1899f8 0x1899f8 0xf91be 0xffffffff 0x1838f0 0x1838f0 0xf4c96 0xffffffff 0x17d7e8 0x17d7e8 0xf076e 0xffffffff 0x1776e0 0x1776e0 0xec246 0xffffffff 0x1715d8 0x1715d8 0xe7d1f 0xffffffff 0x16b4d0 0x16b4d0 0xe37f7 0xffffffff 0x1653c8 0x1653c8 0xdf2cf 0xffffffff 0x15f2c0 0x15f2c0 0xdada7 0xffffffff 0x1591b8 0x1591b8 0xd687f 0xffffffff 0x1530b0 0x1530b0 0xd2357 0xffffffff 0x14cfa8 0x14cfa8 0xcde30 0xffffffff 0x146ea0 0x146ea0 0xc9908 0xffffffff 0x140d98 0x140d98 0xc53e0 0xffffffff 0x13ac90 0x13ac90 0xc0eb8 0xffffffff 0x134b88 0x134b88 0xbc990 0xffffffff 0x12ea80 0x12ea80 0xb8468 0xffffffff 0x128978 0x128978 0xb3f40 0xffffffff 0x122870 0x122870 0xafa19 0xffffffff 0x11c768 0x11c768 0xab4f1 0xffffffff 0x116660 0x116660 0xa6fc9 0xffffffff 0x110558 0x110558 0xa2aa1 0xffffffff 0x10a450 0x10a450 0x9e579 0xffffffff 0x104348 0x104348 0x9a051 0xffffffff 0xfe240 0xfe240 0x95b2a 0xffffffff 0xf8138 0xf8138 0x91602 0xffffffff 0xf2030 0xf2030 0x8d0da 0xffffffff 0xebf28 0xebf28 0x88bb2 0xffffffff 0xe5e20 0xe5e20 0x8468a 0xffffffff 0xdfd18 0xdfd18 0x80162 0xffffffff 0xd9c10 0xd9c10 0x7bc3a 0xffffffff 0xd3b08 0xd3b08 0x77713 0xffffffff 0xcda00 0xcda00 0x731eb 0xffffffff 0xc78f8 0xc78f8 0x6ecc3 0xffffffff 0xc17f0 0xc17f0 0x6a79b 0xffffffff 0xbb6e8 0xbb6e8 0x66273 0xffffffff 0xb55e0 0xb55e0 0x61d4b 0xffffffff 0xaf4d8 0xaf4d8 0x5d824 0xffffffff 0xa93d0 0xa93d0 0x592fc 0xffffffff 0xa32c8 0xa32c8 0x54dd4 0xffffffff 0x9d1c0 0x9d1c0 0x508ac 0xffffffff 0x970b8 0x970b8 0x4c384 0xffffffff 0x90fb0 0x90fb0 0x47e5c 0xffffffff 0x8aea8 0x8aea8 0x43934 0xffffffff 0x84da0 0x84da0 0x3f40d 0xffffffff 0x7ec98 0x7ec98 0x3aee5 0xffffffff 0x78b90 0x78b90 0x369bd 0xffffffff 0x72a88 0x72a88 0x32495 0xffffffff 0x6c980 0x6c980 0x2df6d 0xffffffff 0x66878 0x66878 0x29a45 0xffffffff 0x60770 0x60770 0x2551e 0xffffffff 0x5a668 0x5a668 0x20ff6 0xffffffff 0x54560 0x54560 0x1cace 0xffffffff 0x4e458 0x4e458 0x185a6 0xffffffff>;
cooling-min-state = <0x0>;
#cooling-cells = <0x2>;
cdev-type = "skin-balanced";
cooling-max-state = <0x42>;
cpu_balanced {
throttle_table = <0x1d8760 0x1d8760 0xffffffff 0xffffffff 0x1d2658 0x1d2658 0xffffffff 0xffffffff 0x1cc550 0x1cc550 0xffffffff 0xffffffff 0x1c6448 0x1c6448 0xffffffff 0xffffffff 0x1c0340 0x1c0340 0xffffffff 0xffffffff 0x1ba238 0x1ba238 0xffffffff 0xffffffff 0x1b4130 0x1b4130 0xffffffff 0xffffffff 0x1ae028 0x1ae028 0xffffffff 0xffffffff 0x1a7f20 0x1a7f20 0xffffffff 0xffffffff 0x1a1e18 0x1a1e18 0xffffffff 0xffffffff 0x19bd10 0x19bd10 0x13d814 0xffffffff 0x195c08 0x195c08 0x1382cc 0xffffffff 0x18fb00 0x18fb00 0x132d84 0xffffffff 0x1899f8 0x1899f8 0x12d83d 0xffffffff 0x1838f0 0x1838f0 0x1282f5 0xffffffff 0x17d7e8 0x17d7e8 0x122dad 0xffffffff 0x1776e0 0x1776e0 0x11d865 0xffffffff 0x1715d8 0x1715d8 0x11831d 0xffffffff 0x16b4d0 0x16b4d0 0x112dd5 0xffffffff 0x1653c8 0x1653c8 0x10d88e 0xffffffff 0x15f2c0 0x15f2c0 0x108346 0xffffffff 0x1591b8 0x1591b8 0x102dfe 0xffffffff 0x1530b0 0x1530b0 0xfd8b6 0xffffffff 0x14cfa8 0x14cfa8 0xf836e 0xffffffff 0x146ea0 0x146ea0 0xf2e27 0xffffffff 0x140d98 0x140d98 0xed8df 0xffffffff 0x13ac90 0x13ac90 0xe8397 0xffffffff 0x134b88 0x134b88 0xe2e4f 0xffffffff 0x12ea80 0x12ea80 0xdd907 0xffffffff 0x128978 0x128978 0xd83bf 0xffffffff 0x122870 0x122870 0xd2e78 0xffffffff 0x11c768 0x11c768 0xcd930 0xffffffff 0x116660 0x116660 0xc83e8 0xffffffff 0x110558 0x110558 0xc2ea0 0xffffffff 0x10a450 0x10a450 0xbd958 0xffffffff 0x104348 0x104348 0xb8411 0xffffffff 0xfe240 0xfe240 0xb2ec9 0xffffffff 0xf8138 0xf8138 0xad981 0xffffffff 0xf2030 0xf2030 0xa8439 0xffffffff 0xebf28 0xebf28 0xa2ef1 0xffffffff 0xe5e20 0xe5e20 0x9d9a9 0xffffffff 0xdfd18 0xdfd18 0x98462 0xffffffff 0xd9c10 0xd9c10 0x92f1a 0xffffffff 0xd3b08 0xd3b08 0x8d9d2 0xffffffff 0xcda00 0xcda00 0x8848a 0xffffffff 0xc78f8 0xc78f8 0x82f42 0xffffffff 0xc17f0 0xc17f0 0x7d9fb 0xffffffff 0xbb6e8 0xbb6e8 0x784b3 0xffffffff 0xb55e0 0xb55e0 0x72f6b 0xffffffff 0xaf4d8 0xaf4d8 0x6da23 0xffffffff 0xa93d0 0xa93d0 0x684db 0xffffffff 0xa32c8 0xa32c8 0x62f93 0xffffffff 0x9d1c0 0x9d1c0 0x5da4c 0xffffffff 0x970b8 0x970b8 0x58504 0xffffffff 0x90fb0 0x90fb0 0x52fbc 0xffffffff 0x8aea8 0x8aea8 0x4da74 0xffffffff 0x84da0 0x84da0 0x4852c 0xffffffff 0x7ec98 0x7ec98 0x42fe5 0xffffffff 0x78b90 0x78b90 0x3da9d 0xffffffff 0x72a88 0x72a88 0x38555 0xffffffff 0x6c980 0x6c980 0x3300d 0xffffffff 0x66878 0x66878 0x2dac5 0xffffffff 0x60770 0x60770 0x2857d 0xffffffff 0x5a668 0x5a668 0x23036 0xffffffff 0x54560 0x54560 0x1daee 0xffffffff 0x4e458 0x4e458 0x185a6 0xffffffff>;
cdev-type = "cpu-balanced";
phandle = <0x36>;
linux,phandle = <0x36>;
emergency_balanced {
throttle_table = <0x111ed0 0x111ed0 0x5f758 0x60ae0>;
cdev-type = "emergency-balanced";
cooling-max-state = <0x1>;
gpu_balanced {
throttle_table = <0x1d8760 0x1d8760 0x12b31c 0xffffffff 0x1d2658 0x1d2658 0x125ce2 0xffffffff 0x1cc550 0x1cc550 0x1206a9 0xffffffff 0x1c6448 0x1c6448 0x11b06f 0xffffffff 0x1c0340 0x1c0340 0x115a36 0xffffffff 0x1ba238 0x1ba238 0x1103fc 0xffffffff 0x1b4130 0x1b4130 0x10adc3 0xffffffff 0x1ae028 0x1ae028 0x105789 0xffffffff 0x1a7f20 0x1a7f20 0x100150 0xffffffff 0x1a1e18 0x1a1e18 0xfab16 0xffffffff 0x19bd10 0x19bd10 0xf54dd 0xffffffff 0x195c08 0x195c08 0xefea3 0xffffffff 0x18fb00 0x18fb00 0xea86a 0xffffffff 0x1899f8 0x1899f8 0xe5230 0xffffffff 0x1838f0 0x1838f0 0xdfbf7 0xffffffff 0x17d7e8 0x17d7e8 0xda5bd 0xffffffff 0x1776e0 0x1776e0 0xd4f84 0xffffffff 0x1715d8 0x1715d8 0xcf94a 0xffffffff 0x16b4d0 0x16b4d0 0xca310 0xffffffff 0x1653c8 0x1653c8 0xc4cd7 0xffffffff 0x15f2c0 0x15f2c0 0xbf69d 0xffffffff 0x1591b8 0x1591b8 0xba064 0xffffffff 0x1530b0 0x1530b0 0xb4a2a 0xffffffff 0x14cfa8 0x14cfa8 0xaf3f1 0xffffffff 0x146ea0 0x146ea0 0xa9db7 0xffffffff 0x140d98 0x140d98 0xa477e 0xffffffff 0x13ac90 0x13ac90 0x9f144 0xffffffff 0x134b88 0x134b88 0x99b0b 0xffffffff 0x12ea80 0x12ea80 0x944d1 0xffffffff 0x128978 0x128978 0x8ee98 0xffffffff 0x122870 0x122870 0x8985e 0xffffffff 0x11c768 0x11c768 0x84225 0xffffffff 0x116660 0x116660 0x7ebeb 0xffffffff 0x110558 0x110558 0x795b2 0xffffffff 0x10a450 0x10a450 0x73f78 0xffffffff 0x104348 0x104348 0x6e93e 0xffffffff 0xfe240 0xfe240 0x69305 0xffffffff 0xf8138 0xf8138 0x63ccb 0xffffffff 0xf2030 0xf2030 0x5e692 0xffffffff 0xebf28 0xebf28 0x59058 0xffffffff 0xe5e20 0xe5e20 0x53a1f 0xffffffff 0xdfd18 0xdfd18 0x4e3e5 0xffffffff 0xd9c10 0xd9c10 0x48dac 0xffffffff 0xd3b08 0xd3b08 0x43772 0xffffffff 0xcda00 0xcda00 0x3e139 0xffffffff 0xc78f8 0xc78f8 0x38aff 0xffffffff 0xc17f0 0xc17f0 0x334c6 0xffffffff 0xbb6e8 0xbb6e8 0x2de8c 0xffffffff 0xb55e0 0xb55e0 0x28853 0xffffffff 0xaf4d8 0xaf4d8 0x23219 0xffffffff 0xa93d0 0xa93d0 0x1dbe0 0xffffffff 0xa32c8 0xa32c8 0x185a6 0xffffffff>;
cdev-type = "gpu-balanced";
phandle = <0x3f>;
linux,phandle = <0x3f>;
cooling-max-state = <0x34>;
pwm@32a0000 {
reg = <0x0 0x32a0000 0x0 0x10000>;
clocks = <0xd 0xbd 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x65>;
status = "okay";
phandle = <0x104>;
linux,phandle = <0x104>;
eeprom-manager {
data-size = <0x100>;
boardid-with-config = <0xcee>;
boardid-with-revision = <0xcee>;
bus@0 {
i2c-bus = <0x8c>;
eeprom@0 {
slave-address = <0x50>;
label = "cvm";
eeprom@1 {
slave-address = <0x57>;
label = "cvb";
bus@1 {
i2c-bus = <0x87>;
eeprom@0 {
slave-address = <0x51>;
bus@2 {
i2c-bus = <0x86>;
eeprom@0 {
bus@3 {
i2c-bus = <0x88>;
eeprom@0 {
slave-address = <0x54>;
label = "cam";
enable-gpio = <0x2 0x9>;
pwm@32c0000 {
reg = <0x0 0x32c0000 0x0 0x10000>;
clocks = <0xd 0xbe 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x67>;
ape-ivc-channels {
phandle = <0x48>;
linux,phandle = <0x48>;
dbg@7c00 {
reg = <0x7c00 0xfc00>;
reg-names = "rx", "tx";
compatible = "nvidia,tegra186-camera-ivc-protocol-dbg";
nvidia,frame-size = <0x180>;
nvidia,frame-count = <0x1>;
nvidia,group = <0x1>;
nvidia,service = "debug";
nvidia,version = <0x0>;
dbg@7e00 {
reg = <0x7e00 0xfe00>;
compatible = "nvidia,tegra186-camera-ivc-protocol-debug";
vinotify@12c0 {
reg = <0x12c0 0x92c0>;
compatible = "nvidia,tegra186-camera-ivc-protocol-vinotify";
nvidia,frame-size = <0x80>;
nvidia,frame-count = <0x3f>;
device = <0x46>;
nvidia,service = "vinotify";
ivccontrol@52c0 {
compatible = "nvidia,tegra186-camera-ivc-protocol-capture-control";
nvidia,frame-size = <0x140>;
nvidia,frame-count = <0x10>;
nvidia,service = "capture-control";
echo@0 {
reg = <0x0 0x8000>;
compatible = "nvidia,tegra186-camera-ivc-protocol-echo";
nvidia,frame-size = <0x40>;
nvidia,service = "echo";
ivccapture@72c0 {
compatible = "nvidia,tegra186-camera-ivc-protocol-capture";
nvidia,service = "capture";
pwm@32d0000 {
reg = <0x0 0x32d0000 0x0 0x10000>;
clocks = <0xd 0xbf 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x68>;
pwm@32e0000 {
reg = <0x0 0x32e0000 0x0 0x10000>;
clocks = <0xd 0xc0 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x69>;
pwm@32f0000 {
reg = <0x0 0x32f0000 0x0 0x10000>;
clocks = <0xd 0xc1 0xd 0x10d>;
#pwm-cells = <0x2>;
resets = <0xd 0x6a>;
tegra-mce {
compatible = "nvidia,tegra186-mce";
bwmgr {
compatible = "nvidia,bwmgr";
clock-names = "emc";
clocks = <0xd 0x3a>;
status = "okay";
funnel_minor@8820000 {
reg = <0x0 0x8820000 0x0 0x1000>;
compatible = "arm,coresight-funnel", "arm,primecell";
status = "okay";
ports {
port@0 {
reg = <0x0>;
endpoint {
remote-endpoint = <0x100>;
phandle = <0xf7>;
linux,phandle = <0xf7>;
port@2 {
reg = <0x2>;
endpoint {
slave-mode;
remote-endpoint = <0x101>;
phandle = <0xef>;
linux,phandle = <0xef>;
tpiu@8060000 {
reg = <0x0 0x8060000 0x0 0x1000>;
compatible = "arm,coresight-tpiu", "arm,primecell";
status = "okay";
port {
enpoint@0 {
slave-mode;
remote-endpoint = <0xfe>;
phandle = <0xfa>;
linux,phandle = <0xfa>;
gp10b {
reg = <0x0 0x17000000 0x0 0x1000000 0x0 0x18000000 0x0 0x1000000 0x0 0x3b41000 0x0 0x1000>;
interrupts = <0x0 0x46 0x4 0x0 0x47 0x4>;
fuse-overrides = <0x228 0x9999>;
compatible = "nvidia,tegra186-gp10b", "nvidia,gp10b";
clock-names = "gpu", "gpu_sys";
access-vpr-phys;
interrupt-names = "stall", "nonstall";
clocks = <0xd 0x136 0xd 0x1>;
resets = <0xd 0xe>;
status = "okay";
phandle = <0x60>;
nvidia,host1x = <0x4f>;
linux,phandle = <0x60>;
tegra_cec {
reg = <0x0 0x3960000 0x0 0x1000>;
interrupts = <0x0 0xa2 0x4>;
compatible = "nvidia,tegra186-cec";
clock-names = "cec";
clocks = <0xd 0x5e>;
status = "okay";
sound {
compatible = "nvidia,tegra-audio-t186ref-mobile-rt565x";
clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub", "clk_m", "extern1";
reset-names = "extern1_rst";
nvidia,model = "tegra-snd-t186ref-mobile-rt565x";
nvidia,xbar = <0xca>;
clocks = <0xd 0x10d 0xd 0x10f 0xd 0xf6 0xd 0x57 0xd 0x261 0xd 0x7c>;
nvidia,audio-routing = "x Headphone", "x OUT", "x IN", "x Mic", "y Headphone", "y OUT", "y IN", "y Mic", "z Headphone", "z OUT", "z IN", "z Mic", "m Headphone", "m OUT", "m IN", "m Mic", "n Headphone", "n OUT", "n IN", "n Mic", "o Headphone", "o OUT", "o IN", "o Mic", "a IN", "a Mic", "b IN", "b Mic", "c IN", "c Mic", "d IN", "d Mic", "e Headphone", "e OUT", "e IN", "e Mic", "d1 Headphone", "d1 OUT", "d2 Headphone", "d2 OUT";
resets = <0xd 0x92>;
status = "okay";
phandle = <0x74>;
nvidia,num-codec-link = <0xd>;
linux,phandle = <0x74>;
nvidia,clk-rates = <0x10266000 0xac4400 0x2b11000 0x2b11000 0xea60000 0xbb8000 0x2ee0000 0x2ee0000>;
nvidia,num-clk = <0x8>;
nvidia,dai-link-10 {
cpu-dai = <0xdd>;
bit-
The diff is
----------------------------------------- 1 --------------------------------------
override@1 {
target = <0x9b>;
_overlay_ {
usb3-std-A-port2 {
override@2 {
target = <0x12>;
_overlay_ {
pcie0_lane2_mux {
status = "okay";
---------------------------------------- 2 ----------------------------------------
xhci@3530000 {
reg = <0x0 0x3530000 0x0 0x8000 0x0 0x3538000 0x0 0x1000>;
phys = <0x94 0x10 0x94 0x11>;
interrupts = <0x0 0xa3 0x4 0x0 0xa7 0x4>;
avddio_usb-supply = <0xf>;
compatible = "nvidia,tegra186-xhci";
clock-names = "host", "falcon_src", "ss", "ss_src", "hs_src", "fs_src", "pll_u_480M", "clk_m", "pll_e";
nvidia,boost_cpu_freq = <0x320>;
phy-names = "utmi-0", "utmi-1";
clocks = <0xd 0x71 0xd 0xf4 0xd 0x72 0xd 0xf2 0xd 0x27c 0xd 0xf5 0xd 0x215 0xd 0x261 0xd 0x200>;
mboxes = <0x96>;
status = "okay";
phandle = <0x70>;
avdd_pll_utmip-supply = <0xe>;
hvdd_usb-supply = <0xe>;
mbox-names = "xusb";
linux,phandle = <0x70>;
Moving this thread to the Jetson TX2 forum.
Could you share the full kernel log?
Hi, WayneWWW
One more question, is the e3325-usb3-std-A-HS and USB2_D+/- same port?
Following is dmesg info.
worker@master:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38+ (chunliu@chunliu-ThinkPad-T470) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #2 SMP PREEMPT Wed Jan 16 11:56:20 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31256 r8192 d30184 u69632
[ 0.000000] pcpu-alloc: s31256 r8192 d30184 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0422818030755 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 coherent_pool=32M
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976064K/8208384K available (11332K kernel code, 1775K rwdata, 5748K rodata, 1152K init, 717K bss, 166784K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc00112f000 - 0xffffffc00124f000 ( 1152 KB)
.text : 0xffffffc000080000 - 0xffffffc00112f000 ( 17084 KB)
.data : 0xffffffc001270000 - 0xffffffc00142bdf8 ( 1776 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009800] Console: colour dummy device 80x25
[ 0.014455] console [tty0] enabled
[ 0.018009] bootconsole [uart0] disabled
[ 0.022106] kmemleak: Kernel memory leak detector disabled
[ 0.022118] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022130] pid_max: default: 32768 minimum: 301
[ 0.022175] Security Framework initialized
[ 0.022208] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022217] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022567] Initializing cgroup subsys freezer
[ 0.022580] Initializing cgroup subsys debug
[ 0.022722] CPU0 ipc=752
[ 0.022732] CPU1 ipc=1024
[ 0.022740] CPU2 ipc=1024
[ 0.022749] CPU3 ipc=752
[ 0.022758] CPU4 ipc=752
[ 0.022768] CPU5 ipc=752
[ 0.022804] ASID allocator initialised with 65536 entries
[ 0.046125] tegra-id: chipid=21817.
[ 0.046139] tegra-id: opt_subrevision=1.
[ 0.046149] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046850] DTS File Name: /data/git/JetPack-3.1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046870] DTB Build time: Jan 30 2019 10:41:23
[ 0.062520] CPU1: Booted secondary processor [4e0f0030]
[ 0.074044] CPU2: Booted secondary processor [4e0f0030]
[ 0.085768] CPU3: Booted secondary processor [411fd073]
[ 0.097771] CPU4: Booted secondary processor [411fd073]
[ 0.109775] CPU5: Booted secondary processor [411fd073]
[ 0.109847] Brought up 6 CPUs
[ 0.109913] SMP: Total of 6 processors activated.
[ 0.109927] CPU: All CPU(s) started at EL2
[ 0.110421] devtmpfs: initialized
[ 0.137619] Initilizing CustomIPI irq domain
[ 0.137810] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138631] pinctrl core: initialized pinctrl subsystem
[ 0.138792] OS set in device tree is not L4T.
[ 0.138999] regulator-dummy: no parameters
[ 0.139105] Initializing plugin-manager
[ 0.139162] Plugin module not found
[ 0.139580] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139926] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140544] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141747] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.142053] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142313] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142536] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142962] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143659] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143909] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144132] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144391] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146365] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148165] Adding domain adsp-pd to PM domain ape-pd
[ 0.150470] NET: Registered protocol family 16
[ 0.151232] console [pstore-1] enabled
[ 0.151244] pstore: Registered ramoops as persistent store backend
[ 0.151257] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161304] cpuidle: using governor ladder
[ 0.165768] cpuidle: using governor menu
[ 0.166924] bpmp: waiting for handshake
[ 0.166938] bpmp: handshake completed
[ 0.166980] bpmp: synchronizing channels
[ 0.167007] bpmp: channels synchronized
[ 0.167018] bpmp: mail init ok
[ 0.167367] vdso: 2 pages (1 code @ ffffffc001275000, 1 data @ ffffffc001274000)
[ 0.167401] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.186810] atomic_pool_init():526: DMA: preallocated 32768 KiB pool for atomic allocations
[ 0.188266] tegra_powergate_init: DONE
[ 0.188289] DTS File Name: /data/git/JetPack-3.1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.188316] DTB Build time: Jan 30 2019 10:41:23
[ 0.189331] Tegra reboot handler registered.
[ 0.190437] Registering Tegra186 clocks (this may take a while)...done
[ 0.191957] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.191974] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.191989] arm-smmu 12000000.iommu: stage 1 translation
[ 0.192002] arm-smmu 12000000.iommu: stage 2 translation
[ 0.192014] arm-smmu 12000000.iommu: nested translation
[ 0.192028] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.192048] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.192067] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.192081] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.192095] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.233201] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.238252] iommu: Adding device 3460000.sdhci to group 0
[ 0.239115] iommu: Adding device 3400000.sdhci to group 1
[ 0.242911] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.243538] iommu: Adding device 3160000.i2c to group 3
[ 0.243974] iommu: Adding device c240000.i2c to group 4
[ 0.244351] iommu: Adding device 3180000.i2c to group 5
[ 0.244711] iommu: Adding device 3190000.i2c to group 6
[ 0.245204] iommu: Adding device 31b0000.i2c to group 7
[ 0.245540] iommu: Adding device 31c0000.i2c to group 8
[ 0.245886] iommu: Adding device c250000.i2c to group 9
[ 0.246233] iommu: Adding device 31e0000.i2c to group 10
[ 0.248317] iommu: Adding device 3210000.spi to group 11
[ 0.248657] iommu: Adding device c260000.spi to group 12
[ 0.248976] iommu: Adding device 3240000.spi to group 13
[ 0.249776] iommu: Adding device 3100000.serial to group 14
[ 0.250082] iommu: Adding device 3110000.serial to group 15
[ 0.250423] iommu: Adding device c280000.serial to group 16
[ 0.250803] iommu: Adding device 3130000.serial to group 17
[ 0.251119] iommu: Adding device c290000.serial to group 18
[ 0.252361] iommu: Adding device 2490000.ether_qos to group 19
[ 0.252964] iommu: Adding device b000000.rtcpu to group 20
[ 0.253420] iommu: Adding device c1a0000.aon to group 21
[ 0.254291] Wake73 for irq=42
[ 0.254652] iommu: Adding device smmu_test to group 22
[ 0.255177] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.255229] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.255274] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.255343] mc: mapped MMIO address: 0xffffff8002ea0000 -> 0x2c40000
[ 0.255387] mc: mapped MMIO address: 0xffffff8002ec0000 -> 0x2c50000
[ 0.255428] mc-err: Set intmask: 0xf3140
[ 0.255612] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.256402] Wake76 for irq=199
[ 0.256433] Wake77 for irq=199
[ 0.256513] Wake78 for irq=199
[ 0.256555] Wake79 for irq=199
[ 0.256576] Wake80 for irq=199
[ 0.256596] Wake81 for irq=199
[ 0.256616] Wake82 for irq=199
[ 0.256737] iommu: Adding device 3530000.xhci to group 23
[ 0.257114] iommu: Adding device 3550000.xudc to group 24
[ 0.257896] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.257933] tegra-pmc: ### PMC reset source: Power on reset
[ 0.257965] tegra-pmc: ### PMC reset level: L0
[ 0.257994] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.258255] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.258293] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.258476] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.258532] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.259011] iommu: Adding device 13e10000.host1x to group 25
[ 0.259254] iommu: Adding device 13e10000.host1x:ctx0 to group 26
[ 0.259515] iommu: Adding device 13e10000.host1x:ctx1 to group 27
[ 0.259777] iommu: Adding device 13e10000.host1x:ctx2 to group 28
[ 0.259992] iommu: Adding device 13e10000.host1x:ctx3 to group 29
[ 0.260215] iommu: Adding device 13e10000.host1x:ctx4 to group 30
[ 0.260465] iommu: Adding device 13e10000.host1x:ctx5 to group 31
[ 0.260684] iommu: Adding device 13e10000.host1x:ctx6 to group 32
[ 0.260927] iommu: Adding device 13e10000.host1x:ctx7 to group 33
[ 0.261310] iommu: Adding device 150c0000.nvcsi to group 34
[ 0.261878] iommu: Adding device 15700000.vi to group 35
[ 0.262186] iommu: Adding device 15600000.isp to group 36
[ 0.262563] iommu: Adding device 15210000.nvdisplay to group 37
[ 0.262778] iommu: Adding device 15340000.vic to group 38
[ 0.263019] iommu: Adding device 154c0000.nvenc to group 39
[ 0.263232] iommu: Adding device 15480000.nvdec to group 40
[ 0.263580] iommu: Adding device 15380000.nvjpg to group 41
[ 0.263788] iommu: Adding device 15500000.tsec to group 42
[ 0.264019] iommu: Adding device 15100000.tsecb to group 43
[ 0.264708] iommu: Adding device 15810000.se to group 44
[ 0.264944] iommu: Adding device 15820000.se to group 45
[ 0.265129] iommu: Adding device 15830000.se to group 46
[ 0.265331] iommu: Adding device 15840000.se to group 47
[ 0.265838] iommu: Adding device 17000000.gp10b to group 48
[ 0.267189] tegra-reset 5000000.clock: registered 193 resets.
[ 0.269256] iommu: Adding device d000000.bpmp to group 49
[ 0.269512] bpmp: ping status is 0
[ 0.269693] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.270049] bpmp d000000.bpmp: probe ok
[ 0.272499] iommu: Adding device 2600000.dma to group 50
[ 0.273391] GPIO line 459 (pcie-lane2-mux) hogged as output/low
[ 0.273450] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.273515] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.273567] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.273613] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.273691] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.273790] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.275659] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.275813] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.276828] iommu: Adding device sound to group 51
[ 0.278476] iommu: Adding device 3510000.hda to group 52
[ 0.279657] iommu: Adding device adsp_audio to group 53
[ 0.281050] iommu: Adding device 2993000.adsp to group 54
[ 0.291010] vdd-ac-bat: 5000 mV
[ 0.293048] vdd-1v8-ap: 1800 mV
[ 0.312533] SCSI subsystem initialized
[ 0.312781] libata version 3.00 loaded.
[ 0.313004] usbcore: registered new interface driver usbfs
[ 0.313064] usbcore: registered new interface driver hub
[ 0.313173] usbcore: registered new device driver usb
[ 0.325760] media: Linux media interface: v0.10
[ 0.325822] Linux video capture interface: v2.00
[ 0.329744] pps_core: LinuxPPS API ver. 1 registered
[ 0.329771] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.329817] PTP clock support registered
[ 0.330706] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.330753] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.332224] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.334339] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.334528] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.334615] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.342232] vddio-ddr: at 1125 mV
[ 0.346056] avdd_dsi_csi: 1200 mV
[ 0.350054] vdd-1v8: 1800 mV
[ 0.354053] vdd-3v3-sys: 3300 mV
[ 0.355120] spmic-ldo0: at 1800 mV
[ 0.355907] spmic-ldo1: at 800 mV
[ 0.358056] vddio-3v3: 3300 mV
[ 0.358699] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.362057] vdd-rtc: at 800 mV
[ 0.362816] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.365775] spmic-ldo6: at 1500 mV
[ 0.369772] vdd-pex-1v05: 1000 mV
[ 0.370319] dvdd-pex: 1000 mV
[ 0.370582] max77620 4-003c: max77620 probe successful
[ 0.370843] Advanced Linux Sound Architecture Driver Initialized.
[ 0.371806] en-vdd-sd: 3300 mV
[ 0.371981] en-vdd-cam: 1800 mV
[ 0.373780] vdd-hdmi: 5000 mV
[ 0.373949] vdd-usb0-5v: 5000 mV
[ 0.374108] vdd-usb1-5v: 5000 mV
[ 0.377778] en-vdd-ts-1v8: 1800 mV
[ 0.381779] en-vdd-ts-hv-3v3: 3300 mV
[ 0.381916] en-vdd-disp-3v3: 3300 mV
[ 0.382054] en-mdm-pwr-3v7: 3700 mV
[ 0.382191] en-vdd-disp-1v8: 1800 mV
[ 0.382328] en-vdd-cam-hv-2v8: 2800 mV
[ 0.382463] en-vdd-cam-1v2: 1200 mV
[ 0.382609] vdd-fan: 5000 mV
[ 0.382715] vdd-3v3: 3300 mV
[ 0.382853] dis-vdd-1v2: 1200 mV
[ 0.382960] en-vdd-vcm-2v8: 2800 mV
[ 0.383100] vdd-usb2-5v: 5000 mV
[ 0.383203] vdd-sys-bl: 3300 mV
[ 0.383352] en-vdd-sys: 1200 mV
[ 0.386667] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.387076] clocksource: Switched to clocksource arch_sys_counter
[ 0.405476] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.405743] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.406217] nvmap_page_pool_init: Total RAM pages: 2010400
[ 0.406235] nvmap_page_pool_init: nvmap page pool size: 251300 pages (981 MB)
[ 0.406309] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.410811] Wake76 for irq=199
[ 0.410826] Wake77 for irq=199
[ 0.410838] Wake78 for irq=199
[ 0.410849] Wake79 for irq=199
[ 0.410859] Wake80 for irq=199
[ 0.410869] Wake81 for irq=199
[ 0.410880] Wake82 for irq=199
[ 0.411605] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.411794] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.412148] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.412223] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.412362] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.412501] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.412642] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.412936] isomgr_init(): iso emc max clk=1866000KHz
[ 0.412949] isomgr_init(): max_iso_bw=26870400KB
[ 0.413026] NET: Registered protocol family 2
[ 0.413371] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.413596] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.413886] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.413942] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.413998] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414163] NET: Registered protocol family 1
[ 0.414337] RPC: Registered named UNIX socket transport module.
[ 0.414353] RPC: Registered udp transport module.
[ 0.414364] RPC: Registered tcp transport module.
[ 0.414376] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.414396] PCI: CLS 0 bytes, default 128
[ 0.414502] Trying to unpack rootfs image as initramfs...
[ 0.427918] host1x 13e10000.host1x: initialized
[ 0.428730] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.430861] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.430961] audit: initializing netlink subsys (disabled)
[ 0.430991] audit: type=2000 audit(0.416:1): initialized
[ 0.439353] io scheduler noop registered (default)
[ 0.442232] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.443372] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.444389] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.445402] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.448726] tsec 15500000.tsec: initialized
[ 0.449795] tsec 15100000.tsecb: initialized
[ 0.451819] nvdec 15480000.nvdec: initialized
[ 0.455172] falcon 15340000.vic: initialized
[ 0.456168] falcon 154c0000.nvenc: initialized
[ 0.457155] falcon 15380000.nvjpg: initialized
[ 0.457854] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.458352] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.458842] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.459377] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.459875] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.460363] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.460851] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.461338] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.462689] DC OR NODE connected to /host1x/sor1
[ 0.462811] generic_infoframe_type: 0x87
[ 0.462820] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.462913] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.462928] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.462946] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.462959] tegradc 15210000.nvdisplay: Display dc.ffffff8004220000 registered with id=0
[ 0.470161] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.470182] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.470198] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.470240] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.470256] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.470400] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.472668] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.472853] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.473483] kfuse 3830000.kfuse: initialized
[ 0.474614] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.475020] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.476848] console [ttyS0] disabled
[ 0.476894] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.477087] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 0.479057] tegradc 15210000.nvdisplay: probed
[ 2.477376] console [ttyS0] enabled
[ 2.478729] Console: switching to colour frame buffer device 80x30
[ 2.479329] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.480376] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.480586] serial-tegra 3130000.serial: RX in PIO mode
[ 2.481456] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.482435] c290000.serial: ttyTHS6 at MMIO 0xc290000 (irq = 41, base_baud = 0) is a TEGRA_UART
[ 2.499649] brd: module loaded
[ 2.504248] loop: module loaded
[ 2.504460] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.504464] nct1008_nct72 7-004c: starting parse dt
[ 2.504543] nct1008_nct72 7-004c: success parsing dt
[ 2.504659] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.511027] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.541375] tmp451: Enabled overheat logging at 104.00C
[ 2.541525] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.543815] THERMAL EST: found 3 subdevs
[ 2.543819] THERMAL EST num_resources: 0
[ 2.543824] [THERMAL EST subdev 0]
[ 2.543829] [THERMAL EST subdev 1]
[ 2.543832] [THERMAL EST subdev 2]
[ 2.544081] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.544084] THERMAL EST: thz register success.
[ 2.544206] THERMAL EST: end of probe, return err: 0
[ 2.544255] tegra_profiler: Branch: Dev
[ 2.544257] tegra_profiler: Version: 1.117
[ 2.544260] tegra_profiler: Samples version: 41
[ 2.544262] tegra_profiler: IO version: 22
[ 2.544270] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.544276] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.544280] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.544284] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.544289] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.544293] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.544325] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.544329] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.544333] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.544336] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.544340] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.544343] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.544521] tegra_profiler: auth: init
[ 2.547894] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.547906] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.548862] scsi host0: tegra_ahci
[ 2.549212] scsi host1: tegra_ahci
[ 2.549374] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.549378] ata2: DUMMY
[ 2.550275] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.550694] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.551111] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.551866] tun: Universal TUN/TAP device driver, 1.6
[ 2.551869] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.551994] vcan: Virtual CAN interface driver
[ 2.552001] slcan: serial line CAN interface driver
[ 2.552004] slcan: 10 dynamic interface channels.
[ 2.552012] CAN device driver interface
[ 2.552057] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.552059] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.552095] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.552097] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.553052] PPP generic driver version 2.4.2
[ 2.553205] PPP BSD Compression module registered
[ 2.553213] PPP Deflate Compression module registered
[ 2.553234] PPP MPPE Compression module registered
[ 2.553246] NET: Registered protocol family 24
[ 2.553295] usbcore: registered new interface driver r8152
[ 2.553327] usbcore: registered new interface driver asix
[ 2.553355] usbcore: registered new interface driver ax88179_178a
[ 2.553383] usbcore: registered new interface driver cdc_ether
[ 2.553416] usbcore: registered new interface driver smsc95xx
[ 2.553444] usbcore: registered new interface driver net1080
[ 2.553470] usbcore: registered new interface driver cdc_subset
[ 2.553495] usbcore: registered new interface driver zaurus
[ 2.553536] usbcore: registered new interface driver cdc_ncm
[ 2.553759] Wake76 for irq=199
[ 2.553762] Wake77 for irq=199
[ 2.553764] Wake78 for irq=199
[ 2.553766] Wake79 for irq=199
[ 2.553768] Wake80 for irq=199
[ 2.553770] Wake81 for irq=199
[ 2.553772] Wake82 for irq=199
[ 2.553824] tegra-xotg xotg: usb2 phy is not available yet
[ 2.554465] usbcore: registered new interface driver usb-storage
[ 2.554528] usbcore: registered new interface driver usbserial
[ 2.554553] usbcore: registered new interface driver ftdi_sio
[ 2.554572] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.554603] usbcore: registered new interface driver option
[ 2.554620] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.554644] usbcore: registered new interface driver pl2303
[ 2.554660] usbserial: USB Serial support registered for pl2303
[ 2.554842] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.556083] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c5 8 d5
[ 2.556632] libphy: dwc_phy: probed
[ 2.557473] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.620256] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.688859] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.690896] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.690908] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.691057] i2c /dev entries driver
[ 2.691827] gspca_main: v2.14.0 registered
[ 2.691871] usbcore: registered new interface driver gspca_zc3xx
[ 2.692101] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.693815] FAN dev name: pwm-fan
[ 2.693857] FAN:gpio request success.
[ 2.693863] FAN: can't find tach_gpio
[ 2.693885] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.694037] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.694040] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.694328] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.694332] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.694335] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.694338] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.694341] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.694343] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.694346] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.694349] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.694352] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.694355] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.695088] device-mapper: uevent: version 1.0.3
[ 2.695248] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.695560] sdhci: Secure Digital Host Controller Interface driver
[ 2.695561] sdhci: Copyright(c) Pierre Ossman
[ 2.695565] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.695837] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.696091] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.696306] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.699417] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.699573] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.701160] usbcore: registered new interface driver usbhid
[ 2.701162] usbhid: USB HID core driver
[ 2.704153] nvadsp 2993000.adsp: in probe()...
[ 2.722299] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.722337] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.722551] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.734096] Denver: backdoor interface is NOT available.
[ 2.735107] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.735398] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.735698] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.739648] coresight-tmc 8030000.etf: TMC initialized
[ 2.750665] coresight-tmc 8050000.etr: TMC initialized
[ 2.751093] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.751625] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.752074] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.752541] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.752981] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.753628] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.754186] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.754750] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.755340] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.755369] Module initialized successfully
[ 2.758715] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.760164] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.760382] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.760736] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.760784] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.760822] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.760864] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.760901] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.760940] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.760979] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.761125] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (53)
[ 2.761127] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.761847] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.761850] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.761853] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.761856] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.761858] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.761860] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.761862] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.761890] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.765830] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.766578] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.766688] camchar: rtcpu character device driver loaded
[ 2.770544] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.770843] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.770990] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.771479] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.771508] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.771533] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.771556] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.771581] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.771606] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.771630] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.771654] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.771677] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.771702] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.771726] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.771750] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.771776] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.771804] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.771827] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.771877] **** A57 ECC: Enabled
[ 2.771880] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 2.772047] parse_throttle_dt_data: Num cap clks = 4
[ 2.772050] parse_throttle_dt_data: clk=mcpu type=1
[ 2.772052] parse_throttle_dt_data: clk=bcpu type=2
[ 2.772058] parse_throttle_dt_data: clk=gpu type=4
[ 2.772060] parse_throttle_dt_data: clk=emc type=3
[ 2.772584] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.772674] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.773142] mmc0: MAN_BKOPS_EN bit is not set
[ 2.775935] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.780330] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.782626] mmc0: Skipping tuning since strobe enabled
[ 2.790080] mmc0: periodic cache flush enabled
[ 2.790090] mmc0: new HS400 MMC card at address 0001
[ 2.790355] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.790464] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.790563] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.790667] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.791096] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.791358] sdhci-tegra: probe of 3400000.sdhci failed with error -16
[ 2.792016] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.827598] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 2.863114] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.025475] mmc1 tuning done saved tap delay=21
[ 3.025478] mmc1: hw tuning done ...
[ 3.025486] mmc1: tuning_window[0]: 0xfffffffe
[ 3.025493] mmc1: tuning_window[1]: 0xffffc7ff
[ 3.025498] mmc1: tuning_window[2]: 0xf0ffffff
[ 3.025503] mmc1: tuning_window[3]: 0x7fffffff
[ 3.025509] mmc1: tuning_window[4]: 0x0
[ 3.025514] mmc1: tuning_window[5]: 0x0
[ 3.025519] mmc1: tuning_window[6]: 0x0
[ 3.025525] mmc1: tuning_window[7]: 0x0
[ 3.025529] sdhci: Tap value: 21 | Trim value: 5
[ 3.025534] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.031898] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.031956] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.048929] tegradc 15210000.nvdisplay: fb registered
[ 4.055791] tegra-se-nvhost 15810000.se: initialized
[ 4.061730] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.068700] tegra-se-nvhost 15820000.se: initialized
[ 4.074494] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.081398] tegra-se-nvhost 15830000.se: initialized
[ 4.086952] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.093788] tegra-se-nvhost 15840000.se: initialized
[ 4.099458] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.109158] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.119800] cpufreq: platform driver Initialization: pass
[ 4.125715] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 4.132548] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.138875] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.149048] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.159194] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2cb894
[ 4.166594] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.175478] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.183272] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.192663] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.200849] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.211676] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
[ 4.254644] Release 3.2.0 from 19.12.2014
[ 4.259360] net can0: mttcan device registered (regs=ffffff8002efa000, irq=428)
[ 4.268779] Message RAM Configuration
| base addr |0x0c322000|
[ 4.310451] Release 3.2.0 from 19.12.2014
[ 4.314939] net can1: mttcan device registered (regs=ffffff8003f02000, irq=429)
[ 4.323359] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.330538] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.338575] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.347214] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.360520] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.371582] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.372265] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.372416] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.397441] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.406511] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.414312] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.422381] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.429595] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.438184] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.444733] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.463367] OPE platform probe
[ 4.467921] OPE platform probe successful
[ 4.563266] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.572057] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.580814] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.591600] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.600392] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.609186] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.618017] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.626849] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.635659] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.644578] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.653740] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.662973] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.672408] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.681683] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.690936] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.700205] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.709489] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.718748] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.728036] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.737291] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.750142] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.759547] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.768874] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.775490] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.816161] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.827696] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 4.836699] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.844703] GACT probability NOT on
[ 4.848925] Mirror/redirect action on
[ 4.853306] u32 classifier
[ 4.856700] Actions configured
[ 4.860804] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.868458] ipip: IPv4 over IPv4 tunneling driver
[ 4.874147] Initializing XFRM netlink socket
[ 4.879394] NET: Registered protocol family 10
[ 4.885160] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.891257] NET: Registered protocol family 17
[ 4.896327] NET: Registered protocol family 15
[ 4.901375] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.915123] can: controller area network core (rev 20120528 abi 9)
[ 4.921910] NET: Registered protocol family 29
[ 4.926921] can: raw protocol (rev 20120528)
[ 4.931742] can: broadcast manager protocol (rev 20120528 t)
[ 4.937937] can: netlink gateway (rev 20130117) max_hops=1
[ 4.944069] 8021q: 802.1Q VLAN Support v1.8
[ 4.949530] Registered cp15_barrier emulation handler
[ 4.955127] Registered setend emulation handler
[ 4.962111] registered taskstats version 1
[ 4.967920] Key type encrypted registered
[ 4.976280] isp 15600000.isp: initialized
[ 4.984995] nvcsi 150c0000.nvcsi: initialized
[ 4.990774] Wake76 for irq=199
[ 4.994291] Wake77 for irq=199
[ 4.997785] Wake78 for irq=199
[ 5.001269] Wake79 for irq=199
[ 5.004718] Wake80 for irq=199
[ 5.008151] Wake81 for irq=199
[ 5.011571] Wake82 for irq=199
[ 5.015376] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 5.021413] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 5.051161] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 5.061744] spi-tegra114 3210000.spi: Static pin configuration used
[ 5.068514] xhci-tegra 3530000.xhci: Falling back to user helper
[ 5.075629] spi-tegra114 c260000.spi: Static pin configuration used
[ 5.083056] spi-tegra114 3240000.spi: Static pin configuration used
[ 5.090341] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 5.097209] tegra-xotg xotg: update_id_state: ID grounded
[ 5.103010] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 5.109501] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 5.116804] tegra-xotg xotg: otg: gadget gadget registered
[ 5.122687] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 5.129433] tegra-xotg xotg: otg: host not registered yet
[ 5.135217] tegra-xotg xotg: otg: start OTG finite state machine
[ 5.141664] tegra-xudc-new 3550000.xudc: entering ELPG
[ 5.147229] tegra-xotg xotg: FSM: can't move to a_idle, host isn't ready
[ 5.154842] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 5.155315] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.188575] tegra_rtc c2a0000.rtc: setting system clock to 2019-01-30 02:42:25 UTC (1548816145)
[ 5.227364] bpmp: mounted debugfs mirror
[ 5.232352] [dram-timers] DRAM derating cdev registered.
[ 5.242311] spmic-ldo0: disabling
[ 5.244631] tegra-vi4 15700000.vi: initialized
[ 5.245747] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 5.245749] tegra-vi4 15700000.vi: all channel register failed
[ 5.268255] spmic-ldo1: disabling
[ 5.272235] vddio-sdmmc1: disabling
[ 5.276374] en-vdd-sd: disabling
[ 5.280109] en-vdd-cam: disabling
[ 5.283925] vdd-usb0-5v: disabling
[ 5.287808] vdd-usb1-5v: disabling
[ 5.291719] en-vdd-disp-3v3: disabling
[ 5.295991] en-mdm-pwr-3v7: disabling
[ 5.300124] en-vdd-disp-1v8: disabling
[ 5.304336] en-vdd-cam-hv-2v8: disabling
[ 5.308702] en-vdd-cam-1v2: disabling
[ 5.312802] vdd-3v3: disabling
[ 5.316281] en-vdd-vcm-2v8: disabling
[ 5.320361] vdd-usb2-5v: disabling
[ 5.324168] vdd-sys-bl: disabling
[ 5.327877] en-vdd-sys: disabling
[ 5.339108] ALSA device list:
[ 5.342453] #0: tegra-hda at 0x3518000 irq 401
[ 5.347448] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.383618] EXT4-fs (mmcblk0p1): recovery complete
[ 5.390066] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.398913] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.407798] devtmpfs: mounted
[ 5.411487] Freeing unused kernel memory: 1152K (ffffffc00112f000 - ffffffc00124f000)
[ 5.420132] Freeing alternatives memory: 96K (ffffffc00124f000 - ffffffc001267000)
[ 5.434239] btb inv war enabled
[ 5.490939] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.502723] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[ 5.513787] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.534172] systemd[1]: Detected architecture arm64.
[ 5.546292] systemd[1]: Set hostname to <master>.
[ 5.564152] random: systemd: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[ 5.568010] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 88 bits of entropy available)
[ 5.591180] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 5.591286] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 5.592436] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 5.600236] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 91 bits of entropy available)
[ 5.636472] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 92 bits of entropy available)
[ 5.647769] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 5.737284] systemd[1]: Reached target Swap.
[ 5.743244] systemd[1]: Listening on udev Control Socket.
[ 5.750146] systemd[1]: Created slice System Slice.
[ 5.756522] systemd[1]: Listening on udev Kernel Socket.
[ 5.763284] systemd[1]: Reached target Encrypted Volumes.
[ 5.770127] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.777498] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.785172] systemd[1]: Created slice User and Session Slice.
[ 5.792300] systemd[1]: Reached target Slices.
[ 5.798403] systemd[1]: Reached target Remote File Systems (Pre).
[ 5.805974] systemd[1]: Reached target Remote File Systems.
[ 5.813167] systemd[1]: Listening on Journal Audit Socket.
[ 5.820151] systemd[1]: Listening on Journal Socket.
[ 5.827778] systemd[1]: Starting Journal Service...
[ 5.835135] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.845306] systemd[1]: Starting Load Kernel Modules...
[ 5.855848] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.867731] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.877451] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.888271] systemd[1]: Mounting Debug File System...
[ 5.896059] systemd[1]: Started Journal Service.
[ 5.962761] systemd-journald[279]: Received request to flush runtime journal from PID 1
[ 6.142205] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.151193] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.159212] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 6.161468] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 6.258786] random: nonblocking pool is initialized
[ 6.288542] dhd_module_init in
[ 6.292256] tegra_net_perf_init: cannot get wifi sclk
[ 6.297951] found wifi platform device bcmdhd_wlan
[ 6.304518] wifi_platform_get_country_code_map: could not get country_code_map
[ 6.312972] wifi_plat_dev_drv_probe:platform country code map is not available
[ 6.321437] Power-up adapter 'DHD generic adapter'
[ 6.326909] wifi_platform_set_power = 1
[ 6.332304] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 6.400785] EXT4-fs (mmcblk0p29): recovery complete
[ 6.408061] EXT4-fs (mmcblk0p29): mounted filesystem with ordered data mode. Opts: (null)
[ 6.489651] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.535099] wifi_platform_bus_enumerate device present 1
[ 6.559682] wifi_platform_bus_enumerate device present 0
[ 6.565939] F1 signature read @0x18000000=0x17214354
[ 6.574935] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.582552] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.590218] wifi_platform_prealloc: failed to alloc static mem section 7
[ 6.597618] wifi_platform_get_mac_addr
[ 6.603106] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 6.604619] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.639588] wl_create_event_handler(): thread:wl_event_handler:292 started
[ 6.639604] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e10a1a70
[ 6.656090] dhd_attach(): thread:dhd_watchdog_thread:294 started
[ 6.656132] dhd_attach(): thread:dhd_dpc:295 started
[ 6.656190] dhd_attach(): thread:dhd_rxf:296 started
[ 6.656194] dhd_deferred_work_init: work queue initialized
[ 6.657602] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Dec 6 2018 at 15:34:56
[ 6.657864] tegra_sysfs_register
[ 6.657891] Register interface [wlan0] MAC: 00:04:4b:c5:08:d3
[ 6.657894] dhd_prot_ioctl : bus is down. we have nothing to do
[ 6.657976] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 21
[ 6.659016] wifi_platform_set_power = 0
[ 6.763549] cfg80211: World regulatory domain updated:
[ 6.769441] cfg80211: DFS Master region: unset
[ 6.769448] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.769455] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.769458] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.769460] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.769465] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.769468] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.769472] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.769492] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.769495] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.035127] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.083320] gk20a 17000000.gp10b: railgate is disabled.
[ 7.199473] CPU1: shutdown
[ 7.202196] tegradc 15210000.nvdisplay: blank - powerdown
[ 7.202229] psci: CPU1 killed.
[ 7.228612] CPU2: shutdown
[ 7.231340] psci: CPU2 killed.
[ 7.341750] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 7.353298] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 7.358775] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 7.367290] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 7.375941] xhci-tegra 3530000.xhci: irq 60, io mem 0x03530000
[ 7.381928] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.388792] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.396049] usb usb1: Product: xHCI Host Controller
[ 7.400984] usb usb1: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 7.406508] usb usb1: SerialNumber: 3530000.xhci
[ 7.411424] hub 1-0:1.0: USB hub found
[ 7.415253] hub 1-0:1.0: 4 ports detected
[ 7.443111] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 7.448591] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 7.455083] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.457100] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 7.469429] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.476257] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.483501] usb usb2: Product: xHCI Host Controller
[ 7.488394] usb usb2: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 7.488396] usb usb2: SerialNumber: 3530000.xhci
[ 7.488725] hub 2-0:1.0: USB hub found
[ 7.488758] hub 2-0:1.0: 3 ports detected
[ 7.489196] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 7.809352] fuse init (API version 7.23)
[ 7.867089] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.275148] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.686712] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.695149] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 8.701826] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 8.711297] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 9.136218] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 9.143317] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 9.835144] xhci-tegra 3530000.xhci: entering ELPG
[ 9.841645] xhci-tegra 3530000.xhci: entering ELPG done
[ 9.872044] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9.881107] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.836647] mttcan c310000.mttcan can0: Bitrate set
[ 21.843356] mttcan c310000.mttcan can0: Bitrate set
[ 21.850461] mttcan_controller_config: ctrlmode 0
[ 21.855216] mttcan c310000.mttcan can0: Bitrate set
[ 21.862413] mttcan c320000.mttcan can1: Bitrate set
[ 21.870112] mttcan c320000.mttcan can1: Bitrate set
[ 21.878321] mttcan_controller_config: ctrlmode 0
[ 21.883069] mttcan c320000.mttcan can1: Bitrate set
[ 21.918544] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 25.872410] CPU1: Booted secondary processor [4e0f0030]
[ 25.912480] CPU2: Booted secondary processor [4e0f0030]
worker@master:~$
Please also check the runtime device tree under node /proc/device-tree
If you are asking the usb2.0 on the USB type A port on devkit, then e3325-usb3-std-A-HS is that port.
Hi, WayneWWW
Thanks for you reply!
worker@master:/proc/device-tree/pinctrl@3520000/pinmux/e3325-usb3-std-A-HS$ cat status
okay
But the usb port could not work.
J33_02.dts.txt (387 KB)
Your log does not looks like it is not working.
After you enable PCIe on M.2 keyslot, the USB3.0 on typeA port should be disabled but USB2.0 should still work. Are you working on our devkit?
Could you tell us what is detected here?
Also, could you share the result of lsusb?
Hi, WayneWWW
– I am working on our board, not nvidia’s devkit.
[ 2.636980] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 2.655379] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 2.664311] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 2.678113] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 2.691482] xhci-tegra 3530000.xhci: irq 60, io mem 0x03530000
[ 2.699405] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.707699] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.717812] usb usb1: Product: xHCI Host Controller
[ 2.724187] usb usb1: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 2.730961] usb usb1: SerialNumber: 3530000.xhci
[ 2.737098] hub 1-0:1.0: USB hub found
[ 2.742050] hub 1-0:1.0: 4 ports detected
[ 2.762103] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 2.768620] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 2.779289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.787369] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.797172] usb usb2: Product: xHCI Host Controller
[ 2.803325] usb usb2: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 2.809869] usb usb2: SerialNumber: 3530000.xhci
[ 2.815943] hub 2-0:1.0: USB hub found
[ 2.820984] hub 2-0:1.0: 3 ports detected
[ 2.826632] tegra-xotg xotg: otg: host 3530000.xhci registered
worker@master:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
These should be the usb root hub as the Linux Foundation 3.0 root hub and Linux Foundation 2.0 root hub.
It looks like usb should still work. Could you tell us which configuration are you using? I mean the configuration on the adaptation guide.
Hi
I use the USB Lane Mapping config 1.
It looks like the usb is still working. Could you see new message from dmesg when you plug in new devices?
There are no logs on usb2-2, when plug/unplug
worker@master:~$
Bus 001 Device 007: ID 062a:4101 Creative Labs Wireless Keyboard/Mouse
worker@master:~$
Bus 001 Device 008: ID 062a:4101 Creative Labs Wireless Keyboard/Mouse
worker@master:~$
[ 268.866802] xhci-tegra 3530000.xhci: exiting ELPG
[ 268.895286] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 268.909698] xhci-tegra 3530000.xhci: exiting ELPG done
[ 269.130987] usb 1-1: new full-speed USB device number 7 using xhci-tegra
[ 269.269094] usb 1-1: New USB device found, idVendor=062a, idProduct=4101
[ 269.277860] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 269.287044] usb 1-1: Product: 2.4G Keyboard Mouse
[ 269.293803] usb 1-1: Manufacturer: MOSART Semi.
[ 269.300545] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 269.311903] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 269.322199] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3530000.xhci/usb1/1-1/1-1:1.0/0003:062A:4101.000B/input/input14
[ 269.391254] hid-generic 0003:062A:4101.000B: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3530000.xhci-1/input0
[ 269.408466] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3530000.xhci/usb1/1-1/1-1:1.1/0003:062A:4101.000C/input/input15
[ 269.475108] hid-generic 0003:062A:4101.000C: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3530000.xhci-1/input1
[ 270.556061] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 270.565233] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 274.680211] usb 1-1: USB disconnect, device number 7
[ 274.795593] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 274.947071] xhci-tegra 3530000.xhci: entering ELPG
[ 274.955434] xhci-tegra 3530000.xhci: entering ELPG done
[ 276.237694] xhci-tegra 3530000.xhci: exiting ELPG
[ 276.267316] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 276.281766] xhci-tegra 3530000.xhci: exiting ELPG done
[ 276.503031] usb 1-2: new full-speed USB device number 8 using xhci-tegra
[ 276.641100] usb 1-2: New USB device found, idVendor=062a, idProduct=4101
[ 276.649890] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 276.659109] usb 1-2: Product: 2.4G Keyboard Mouse
[ 276.665891] usb 1-2: Manufacturer: MOSART Semi.
[ 276.672634] usb 1-2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 276.684137] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 276.694464] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:062A:4101.000D/input/input16
[ 276.763267] hid-generic 0003:062A:4101.000D: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3530000.xhci-2/input0
[ 276.780504] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/3530000.xhci/usb1/1-2/1-2:1.1/0003:062A:4101.000E/input/input17
[ 276.847176] hid-generic 0003:062A:4101.000E: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3530000.xhci-2/input1
[ 277.928124] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 277.937321] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
worker@master:~$
How many usb ports are there on your board? Could you firstly describe how does your board look like?
Does the keyboard you are using is connected to that one you claimed not working?
If the pcie x1 can work, it means it definitely not driven by SS usb mode. Thus, it is all under expectation.
Hi, WayneWWW
There are three usb ports on my board.
USB2.0_0(usb2-micro-AB) <–> usb Type A connector
USB2.0_1(usb2-std-A-port2) <–> usb Type A connector
USB2.0_2(e3325-usb3-std-A-HS) <–> usb Type A connector
The USB2.0_2 dosn’t work, when enable pcie x1(config 1).
So you didn’t connect your keyboard or mouse on USB2.0_2 during above test but other port?
Using one keyboard, connect to usb2.0_0/1/2 Alternately.
Just USB2.0_2 dosn’t work, other ports works.
