TX2 Jetpack 4.2.2 ,SPI enable
Hi, dear~
I have a Jetson TX2,Ubuntu 18.04,and Jetpack 4.2.2,I need to use SPI interface.
by the way, I can Succeed in enable SPI on TX2 Jetpack 4.2, and I try to use the same method for opening SPI by the following steps.
  1. decompiler the dtb to dts at
    $ sudo dtc -I dtb -O dts -o extracted_proc.dts tegra186-quill-p3310-1000-c03-00-base.dtb
  2. modify the dts
    $ sudo gedit extracted_proc.dts
    spi@3240000
    spi@0 {
    compatible = “spidev”;
    reg = <0x0>;
    spi-max-frequency = <0x1312D00>;
    nvidia,enable-hw-based-cs;
    nvidia,cs-setup-clk-count = <0x1e>;
    nvidia,cs-hold-clk-count = <0x1e>;
    nvidia,rx-clk-tap-delay = <0x1f>;
    nvidia,tx-clk-tap-delay = <0x0>;
  3. compiler dts
    $ sudo dtc -I dts -O dtb -o tegra186-quill-p3310-1000-c03-00-base.dtb extracted_proc.dts
  4. flash
    sudo ./flash.sh -k kernel-dtb jetson-tx2 mmcblk0p1
by the way, I use NVIDIA SDK Manager get the jetpack4.2.2 Linux_for_Tegra file,but I didn,t use it to install tx2 jetpack4.2.2. I don’t know it have problem or not.
Check the pinmux config from this wiki page.
https://elinux.org/Jetson/TX2_SPI
I already modify pinmux config ~
  1. At /nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg, the original config is the following message. I think I don’t need to modify it.
pinmux.0x02430038 = 0x00000401; # gpio_cam4_pn3: spi4, tristate-disable, input-disable
pinmux.0x02430040 = 0x00000455; # gpio_cam5_pn4: spi4, pull-down, tristate-enable, input-enable
pinmux.0x02430048 = 0x00000401; # gpio_cam6_pn5: spi4, tristate-disable, input-disable
pinmux.0x02430050 = 0x00000409; # gpio_cam7_pn6: spi4, pull-up, tristate-disable, input-disable
  1. I try to modify tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg and tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg, but stiil not enable spi.
by the way…I already create the /dev/spidev3.0…
by the way…I don’t know what is the difference between a00 and c03…
I modify the tegra186-quill-p3310-1000-c03-00-base.dtb, which config I need to modify…a00 or c03??
For your case should be the xxxx-c03.cfg
Also you can have devmem2 to read it back to confirm the REG value.
Hi. I modify my tegra186-mb1-bct-pinmux-qull-p3310-1000-c03.cfg,results are as follows.
I finish flash my TX2…and then I check it address value by devmem. I get the following msg,it let me confuse why I didn’t modify it.
#./devmem 0x02430038
value at address 0x02430038 (0x7fa3fc4038):0x56
#./devmem 0x02430040
value at address 0x02430038 (0x7f97415040):0x56
#./devmem 0x02430048
value at address 0x02430038 (0x7f928e1000):0x56
#./devmem 0x02430050
value at address 0x02430038 (0x7f89e39050):0x58
please help me…
Did you do the whole system flash?
I just run “sudo ./flash.sh -k kernel-dtb jetson-tx2 mmcblk0p1”.
I didn’t want to reflash all…
Need flash whole system instead of -k
sudo ./flash -r jetson-tx2 mmcblk0p1
But why I didn’t need to flash whole system at jetpack4.2?
It mean if I want to modify config above version Jetpack4.2.2,I need to flash whole system and it will reset my system…
By the way…If I want to know 0x02430038 stand for which pin and 0x401 stand for what ?
and spi@3240000 which stand for spi1 or spi2…etc,How do I known…
If you have any document can let me study,please tell me,thank you.
You can see this pin is SPI4, then it’s map to software spi3 aka spi@3240000. SPI4 is HW pin name it start from 1, and software function start from 0
Yes, if you need to update the cfg configure you need to flash whole system.
thank you…I try it on other board.
by the way…
if I want to know other REG Value, how can I do…ex: 0x402、0x403…etc, maybe have a document show every bit which mean .
You should be able find it in TRM. Just search “gpio_cam4”
thank you~~
I sucessfully enable SPI and I can use it by flashing a new board.
by the way~ have any solution which can let me flash REG value without clean my system.
It is not convenient for me~
For the debug purpose you can use devmem2 to write the REG after boot to the OS.
@ShaneCCC
What is TRM, could you give a link for jetson nano?
TRM is Technical Reference Manual. See (you might need to log in there, and then click the link a second time):
https://developer.nvidia.com/embedded/downloads#?search=trm&tx=$product,jetson_tx2
