Tx2 unboxed,Screen stuck at bootup
My first post. I have a new tx2. I setup the connections (hdmi port to display), the system gets stuck at bootup.
I have tried multiple power cycles but the system doesn’t complete boot step.
Anyone faced such an issue?
Side question, How Can I post an image to this post?
Hi atul799,
Please start from upgrading it to the latest version supporting TX2 with JetPack 3.3 (https://developer.nvidia.com/embedded/jetpack-3_3). Thanks!
FYI, if you purchased a module separately, then it has no software until you add it. If it is a dev kit, then it should be able to boot, but often video configuration failures are mistaken for boot failure. How do you know it didn’t boot? Is it stuck in the logo screen?
Thanks updating Jetpack worked for me.
