I’m using tegraflash.py to flash partitions on a custom TX2 device but I’m experiencing hangs most of the time when I attempt this operation.
I’m developing on Ubuntu 16.04 on a Dell XPS 15 9570.
I modified tegraflash_internal.py to prompt me to unplug and replug my USB cabled when it detects an error response of ‘BootRom is not running’ which helps to overcome this issue.
The output of my session is as follows:
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0038 ] Generating RCM messages
[ 0.0045 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0052 ] RCM 0 is saved as rcm_0.rcm
[ 0.0054 ] RCM 1 is saved as rcm_1.rcm
[ 0.0054 ] List of rcm files are saved in rcm_list.xml
[ 0.0054 ]
[ 0.0054 ] Signing RCM messages
[ 0.0060 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0067 ] Assuming zero filled SBK key
[ 0.0096 ]
[ 0.0096 ] Copying signature to RCM mesages
[ 0.0103 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0113 ]
[ 0.0113 ] Boot Rom communication
[ 0.0120 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.0126 ] BootRom is not running
[ 1.3111 ]
[ 1.3111 ] Unplug and replug USB cable then press ENTER...
[ 86.0185 ] BootRom is not running
[ 87.2951 ]
[ 87.2951 ] Unplug and replug USB cable then press ENTER...
[ 97.3799 ] BR_CID: 0x81801001644036470800000011fd8440
[ 97.5315 ] RCM version 0X180001
[ 97.5480 ] Boot Rom communication completed
[ 98.5550 ]
[ 98.5577 ] tegrarcm_v2 --isapplet
[ 98.5602 ] Applet version 01.00.0000
[ 98.5780 ]
[ 98.5808 ] tegrasign_v2 --key None --getmode mode.txt
[ 98.5833 ] Assuming zero filled SBK key
... flash succeeds ...
In the above log you can see the prompt that I added requesting an unplug and replug - at this point I physically unplug the USB cable to my device and then plug it back in and the tegrarcm_v2 command will succeed after one or more replug attempts.
I’ve also tested against the standard Jetson TX2 Developer Kit with the JetPack 3.3 flashing utilities with similar results. With enough replug attempts I can get the flashing to work.
I’ve also captured USB traffic via usbmon and Wireshark. When flashing fails I see a URB_BULK in request which returns a URB with length 0 and an -ENOENT error code. When it succeeds the URB length is 16.
Example capture for failure:
Request (raw):
0000 80 aa 27 42 ee 88 ff ff 53 03 81 27 01 00 2d 3c .ª'Bî.ÿÿS..'..-<
0010 fd 97 75 5c 00 00 00 00 a4 8d 07 00 8d ff ff ff ý.u\....¤....ÿÿÿ
0020 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 `...............
0030 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 ................
Request (text):
Frame 174: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface 0
USB URB
[Source: host]
[Destination: 1.39.1]
URB id: 0xffff88ee4227aa80
URB type: URB_SUBMIT ('S')
URB transfer type: URB_BULK (0x03)
Endpoint: 0x81, Direction: IN
Device: 39
URB bus id: 1
Device setup request: not relevant ('-')
Data: not present ('<')
URB sec: 1551210493
URB usec: 495012
URB status: Operation now in progress (-EINPROGRESS) (-115)
URB length [bytes]: 96
Data length [bytes]: 0
[Response in: 175]
[bInterfaceClass: Unknown (0xffff)]
Unused Setup Header
Interval: 0
Start frame: 0
Copy of Transfer Flags: 0x00000200
Number of ISO descriptors: 0
Response (raw):
0000 80 aa 27 42 ee 88 ff ff 43 03 81 27 01 00 2d 00 .ª'Bî.ÿÿC..'..-.
0010 fe 97 75 5c 00 00 00 00 b4 08 08 00 fe ff ff ff þ.u\....´...þÿÿÿ
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Response (text):
Frame 175: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface 0
USB URB
[Source: 1.39.1]
[Destination: host]
URB type: URB_COMPLETE ('C')
Device: 39
URB bus id: 1
Data: present (0)
URB sec: 1551210494
URB usec: 526516
URB status: No such file or directory (-ENOENT) (-2)
URB length [bytes]: 0
[Request in: 174]
[Time from request: 1.031504000 seconds]
Unused Setup Header
Interval: 0
Start frame: 0
Example capture for success:
Request (raw):
0000 c0 a9 27 42 ee 88 ff ff 53 03 81 29 01 00 2d 3c À©'Bî.ÿÿS..)..-<
0010 5e 98 75 5c 00 00 00 00 9b 63 0b 00 8d ff ff ff ^.u\.....c...ÿÿÿ
Request (text):
Frame 464: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface 0
USB URB
[Source: host]
[Destination: 1.41.1]
URB id: 0xffff88ee4227a9c0
Device: 41
URB bus id: 1
URB sec: 1551210590
URB usec: 746395
[Response in: 465]
[bInterfaceClass: Vendor Specific (0xff)]
Unused Setup Header
Interval: 0
Start frame: 0
Response (raw):
0000 c0 a9 27 42 ee 88 ff ff 43 03 81 29 01 00 2d 00 À©'Bî.ÿÿC..)..-.
0010 5e 98 75 5c 00 00 00 00 da 63 0b 00 00 00 00 00 ^.u\....Úc......
0020 10 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 ................
0040 40 84 fd 11 00 00 00 08 47 36 40 64 01 10 80 81 @.ý.....G6@d....
Response (text):
Frame 465: 80 bytes on wire (640 bits), 80 bytes captured (640 bits) on interface 0
USB URB
[Source: 1.41.1]
[Destination: host]
Device: 41
URB bus id: 1
Data: present (0)
URB sec: 1551210590
URB usec: 746458
URB status: Success (0)
URB length [bytes]: 16
Data length [bytes]: 16
[Request in: 464]
[Time from request: 0.000063000 seconds]
Unused Setup Header
Interval: 0
Start frame: 0
Leftover Capture Data: 4084fd11000000084736406401108081
I there a way that I can ensure a more reliable flash? Anyone else run into this issue?
