TX2i L4T 32.3.1 patch for PCN208460
I am attempting to flash a TX2i with L4T 32.3.1. However, I am receiving the following error when flashing to a custom carrier board:
[  16.6872 ] [................................................] 100%
[  17.3591 ]
[  17.3640 ] tegrarcm_v2 --boot recovery
[  17.3685 ] Applet version 01.00.0000
[  17.4268 ]
[  18.4346 ] tegrarcm_v2 --isapplet
[  19.1034 ]
[  19.1114 ] tegradevflash_v2 --iscpubl
[  19.1178 ] Cannot Open USB
[  19.2719 ]
[  20.2949 ] tegrarcm_v2 --isapplet
[  20.2968 ] USB communication failed.Check if device is in recovery
[  20.8709 ]
[  20.8763 ] tegradevflash_v2 --iscpubl
[  20.8816 ] CPU Bootloader is not running on device.
[ 1024.1356 ]
[ 1025.1421 ] tegrarcm_v2 --isapplet
My TX2i is a 900- series part.
I need a patch for TX2i for PCN208460. https://developer.nvidia.com/assets/embedded/secure/jetson/tx2/docs/jetson_tx2i_pcn208460_bom_addition_of_dram.pdf
Said patch is not available on L4T 32.3.1.
Upgrading to a newer Jetpack version is unfortunately not an option.
Thank you.
Yes, we don’t have the patch for L4T 32.3.1 as it’s almost a 4 years ago release.
We can only suggesto to upgrade to knew one to get the support.
Sorry for that.
I was under the impression that the TX2i benefited from extended support when compared to the TX2 counterparts.
PCN209140 for the TX2 has a patch for 32.3.1, released in November of 2022- https://developer.nvidia.com/jetson-tx2-pcn209140-addition-manufacturing-bom-components-hynix-dram
I’d argue that it is not unreasonable to expect similar software support for the industrial counterpart, considering the cost delta and that PCN208460 was released in May of 2022.
