Hello all,
I would like to upgrade the Jetson TX2 L4T 28.2.0 to 32.3.1 and Kernel 4.4.38-tegra.
Regards
RG
Hello all,
Regards
RG
You won’t be able to use kernel 4.4.38-tegra with L4T R32.3.1, the kernel is newer than this. If you want to see which L4T release is installed for a particular JetPack/SDK Manager, go here (you’ll need to go there, log in, and then click again):
https://developer.nvidia.com/embedded/jetpack-archive
L4T R32.3.1 would be installed if you flash via JetPack 4.3:
https://developer.nvidia.com/jetpack-43-archive
FYI, you won’t be able to mix the optional “extra” packages, e.g., CUDA, of one release, from a different release. There is a dependency between the L4T release and the CUDA release.
Flashing will erase everything currently on the system. If this is a problem, then you can clone the current system. You won’t be able to restore an R28.2 filesystem into R32.3.1, but you would have a full copy of everything to copy back in.
Hi Linux Dev,
I have flashed new image of JetPack 4.3 in a SD card and inserted into the Jetson and rebooted the Jetson,But nothing is happening,even the Jetson is Not turning ON.
When i remove the SD card, it is turning ON.
Am i missing anything here?
By “not turning on”, are you speaking of the LEDs not even lighting up? That would seem like a hardware issue, but if you just mean boot fails, then this is a software issue. If we are speaking of a software issue, then a serial console boot log with the SD card in would be useful.
If your SD card is just for data, then ignore this: If you are setting up to boot from SD card (or if for any reason the SD card is mistaken for boot media), then you probably still need the software used for booting within the eMMC to match the release version used by the SD card. Boot content and root filesystem tend to have dependencies.
I have a quick question, does this image will work with CONNECT TECH - QUASAR CARRIER (ASG016) FOR NVIDIA JETSON TX2/TX2I/TX1
https://www.siliconhighwaydirect.co.uk/product-p/asg016.htm
and NVIDIA JETSON TX2 MODULE - 900-83310-0001-000
https://www.siliconhighwaydirect.co.uk/product-p/900-83310-0001-000.htm
We are using jetson TX2 and Connectech carrier Board.
On this page https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#setup, i only see it as a Developer Kit.
The Connect Tech carrier board and the TX2 module look to be compatible. I do not know which L4T/JetPack release is supported by that carrier board though, so you would need to know ahead of time prior to any purchase if the supported releases of that carrier are good for your needs.
The Nano is different, and is not compatible with that Connect Tech carrier board (CTI might have other compatible carriers for a Nano, but Nano and TX2 carriers are mutually exclusive).
The Nano is available as a separate module, which has eMMC, but not an SD card. The Nano dev kit is available with SD card, but not eMMC. The regular module is intended for commercial applications and would thus require either your own carrier board or the carrier board from a third party. The Nano SD card development version does not work on carrier boards intended for the eMMC version.
You might find some NX modules compatible with some Nano carrier boards. You would definitely need to verify compatibility prior to any purchase, and verify if L4T/JetPack releases are compatible with the software you plan to work with.
Note: The current compute beast is the Xavier. There is a smaller (but still far more powerful than Nano) module which is Xavier NX.
It supports all the L4T r32.4.2 – Jetpack 4.4
L4T r32.3.1 – Jetpack 4.3
L4T r32.2.1 – Jetpack 4.2.2
L4T r32.2.0 – Jetpack 4.2.1
L4T r32.1.0 – Jetpack 4.2
L4T r28.2X – Jetpack 3.3
L4T r28.1.0 – Jetpack 3.1
L4T r27.1.0 – Jetpack 3.0
We have bought this Jetson and a Board from a Company used their AI. Now that company is No more.
So i am trying to change the Jetpack and L4T package on the device.
When we buy this device, we have got the device with Ready to use.
Can you please give me a guide where and how can i upgrade the Nano TX2.
Nano is different from TX2. They share many parts, but we need to know for sure which of these you are using:
The company selling the carrier board would provide the board support package to add to the host PC’s “Linux_for_Tegra/” directory prior to flash. JetPack/SDKM would download and install the “Linux_for_Tegra/” content, and then you would add the board support package (“BSP”) from CTI to this.
Hi Linuxdev,
During the flashing process i am getting these errors at 99.8%
Boot Rom Communication Failure,
18:51:38 INFO : Flash Jetson TX2 : [ 1.8207 ] Boot Rom communication
18:51:38 INFO : Flash Jetson TX2 : [ 1.8219 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
18:51:38 INFO : Flash Jetson TX2 : [ 1.8258 ] BootRom is not running
19:08:24 INFO : Flash Jetson TX2 : [ 6.9306 ]
19:08:24 INFO : Flash Jetson TX2 : [ 7.9334 ] tegrarcm_v2 --isapplet
19:25:20 INFO : Flash Jetson TX2 : [ 1012.5004 ]
19:25:20 INFO : Flash Jetson TX2 : [ 1012.5287 ] tegradevflash_v2 --iscpubl
19:25:20 INFO : Flash Jetson TX2 : [ 1012.5310 ] CPU Bootloader is not running on device.
18:50:51 ERROR : Flash Jetson TX2 : 5004: RAW: 34361344( 8389 blks) ==> 3030411948:34361356
18:50:51 ERROR : Flash Jetson TX2 : 5005: SKP: 53248( 13 blks) ==> 3064773304:12
18:50:51 ERROR : Flash Jetson TX2 : 5006: RAW: 24870912( 6072 blks) ==> 3064773316:24870924
18:50:51 ERROR : Flash Jetson TX2 : 5007: SKP: 4096( 1 blks) ==> 3089644240:12
18:50:51 ERROR : Flash Jetson TX2 : 5008: RAW: 2408448( 588 blks) ==> 3089644252:2408460
18:50:51 ERROR : Flash Jetson TX2 : 5009: SKP: 8192( 2 blks) ==> 3092052712:12
18:50:51 ERROR : Flash Jetson TX2 : 5010: RAW: 12288( 3 blks) ==> 3092052724:12300
18:50:51 ERROR : Flash Jetson TX2 : 5011: SKP: 8192( 2 blks) ==> 3092065024:12
18:50:51 ERROR : Flash Jetson TX2 : 5012: RAW: 70905856( 17311 blks) ==> 3092065036:70905868
18:50:52 ERROR : Flash Jetson TX2 : 5013: SKP: 27668480( 6755 blks) ==> 3162970904:12
18:50:52 ERROR : Flash Jetson TX2 : 5014: RAW: 6918144( 1689 blks) ==> 3162970916:6918156
18:50:52 ERROR : Flash Jetson TX2 : 5015: SKP: 4096( 1 blks) ==> 3169889072:12
18:50:52 ERROR : Flash Jetson TX2 : 5016: RAW: 864256( 211 blks) ==> 3169889084:864268
18:50:52 ERROR : Flash Jetson TX2 : 5017: SKP: 4096( 1 blks) ==> 3170753352:12
18:50:52 ERROR : Flash Jetson TX2 : 5018: RAW: 4485120( 1095 blks) ==> 3170753364:4485132
18:50:52 ERROR : Flash Jetson TX2 : 5019: SKP: 4096( 1 blks) ==> 3175238496:12
18:50:52 ERROR : Flash Jetson TX2 : 5020: RAW: 3584000( 875 blks) ==> 3175238508:3584012
18:50:52 ERROR : Flash Jetson TX2 : 5021: SKP: 4096( 1 blks) ==> 3178822520:12
18:50:52 ERROR : Flash Jetson TX2 : 5022: RAW: 17686528( 4318 blks) ==> 3178822532:17686540
18:50:55 ERROR : Flash Jetson TX2 : 5023: SKP: 1744830464( 425984 blks) ==> 3196509072:12
18:50:55 ERROR : Flash Jetson TX2 : 5024: RAW: 16384( 4 blks) ==> 3196509084:16396
18:50:55 ERROR : Flash Jetson TX2 : 5025: SKP: 49152( 12 blks) ==> 3196525480:12
18:50:55 ERROR : Flash Jetson TX2 : 5026: RAW: 12288( 3 blks) ==> 3196525492:12300
18:50:55 ERROR : Flash Jetson TX2 : 5027: SKP: 53248( 13 blks) ==> 3196537792:12
18:50:55 ERROR : Flash Jetson TX2 : 5028: RAW: 4763648( 1163 blks) ==> 3196537804:4763660
18:50:55 ERROR : Flash Jetson TX2 : 5029: SKP: 28790784( 7029 blks) ==> 3201301464:12
18:50:55 ERROR : Flash Jetson TX2 : 5030: RAW: 10756096( 2626 blks) ==> 3201301476:10756108
18:50:55 ERROR : Flash Jetson TX2 : 5031: SKP: 89776128( 21918 blks) ==> 3212057584:12
18:50:56 ERROR : Flash Jetson TX2 : 5032: RAW: 132034560( 32235 blks) ==> 3212057596:132034572
18:50:56 ERROR : Flash Jetson TX2 : 5033: SKP: 4096( 1 blks) ==> 3344092168:12
18:50:57 ERROR : Flash Jetson TX2 : 5034: RAW: 135815168( 33158 blks) ==> 3344092180:135815180
18:50:57 ERROR : Flash Jetson TX2 : 5035: SKP: 4096( 1 blks) ==> 3479907360:12
18:50:57 ERROR : Flash Jetson TX2 : 5036: RAW: 9912320( 2420 blks) ==> 3479907372:9912332
18:50:57 ERROR : Flash Jetson TX2 : 5037: SKP: 4096( 1 blks) ==> 3489819704:12
18:50:57 ERROR : Flash Jetson TX2 : 5038: RAW: 43851776( 10706 blks) ==> 3489819716:43851788
18:50:57 ERROR : Flash Jetson TX2 : 5039: SKP: 28672( 7 blks) ==> 3533671504:12
18:50:57 ERROR : Flash Jetson TX2 : 5040: RAW: 8192( 2 blks) ==> 3533671516:8204
18:50:57 ERROR : Flash Jetson TX2 : 5041: SKP: 8192( 2 blks) ==> 3533679720:12
18:50:57 ERROR : Flash Jetson TX2 : 5042: RAW: 7708672( 1882 blks) ==> 3533679732:7708684
18:50:57 ERROR : Flash Jetson TX2 : 5043: SKP: 4096( 1 blks) ==> 3541388416:12
18:50:57 ERROR : Flash Jetson TX2 : 5044: RAW: 77824( 19 blks) ==> 3541388428:77836
18:50:57 ERROR : Flash Jetson TX2 : 5045: SKP: 4096( 1 blks) ==> 3541466264:12
18:50:58 ERROR : Flash Jetson TX2 : 5046: RAW: 17629184( 4304 blks) ==> 3541466276:17629196
18:50:58 ERROR : Flash Jetson TX2 : 5047: SKP: 8192( 2 blks) ==> 3559095472:12
18:50:58 ERROR : Flash Jetson TX2 : 5048: RAW: 9211904( 2249 blks) ==> 3559095484:9211916
18:50:58 ERROR : Flash Jetson TX2 : 5049: SKP: 4096( 1 blks) ==> 3568307400:12
18:50:58 ERROR : Flash Jetson TX2 : 5050: RAW: 16384( 4 blks) ==> 3568307412:16396
18:50:58 ERROR : Flash Jetson TX2 : 5051: SKP: 4096( 1 blks) ==> 3568323808:12
18:50:58 ERROR : Flash Jetson TX2 : 5052: RAW: 16384( 4 blks) ==> 3568323820:16396
18:50:58 ERROR : Flash Jetson TX2 : 5053: SKP: 4096( 1 blks) ==> 3568340216:12
18:50:58 ERROR : Flash Jetson TX2 : 5054: RAW: 1634304( 399 blks) ==> 3568340228:1634316
18:50:58 ERROR : Flash Jetson TX2 : 5055: SKP: 4096( 1 blks) ==> 3569974544:12
18:50:58 ERROR : Flash Jetson TX2 : 5056: RAW: 20836352( 5087 blks) ==> 3569974556:20836364
18:51:00 ERROR : Flash Jetson TX2 : 5057: SKP: 1231777792( 300727 blks) ==> 3590810920:12
18:51:00 ERROR : Flash Jetson TX2 : 5058: RAW: 12288( 3 blks) ==> 3590810932:12300
18:51:00 ERROR : Flash Jetson TX2 : 5059: SKP: 402640896( 98301 blks) ==> 3590823232:12
18:51:00 ERROR : Flash Jetson TX2 : 5060: RAW: 12288( 3 blks) ==> 3590823244:12300
18:51:00 ERROR : Flash Jetson TX2 : 5061: SKP: 53248( 13 blks) ==> 3590835544:12
18:51:00 ERROR : Flash Jetson TX2 : 5062: RAW: 12288( 3 blks) ==> 3590835556:12300
18:51:00 ERROR : Flash Jetson TX2 : 5063: SKP: 53248( 13 blks) ==> 3590847856:12
18:51:01 ERROR : Flash Jetson TX2 : 5064: RAW: 4542464( 1109 blks) ==> 3590847868:4542476
18:51:01 ERROR : Flash Jetson TX2 : 5065: SKP: 29011968( 7083 blks) ==> 3595390344:12
18:51:01 ERROR : Flash Jetson TX2 : 5066: RAW: 13537280( 3305 blks) ==> 3595390356:13537292
18:51:01 ERROR : Flash Jetson TX2 : 5067: SKP: 86994944( 21239 blks) ==> 3608927648:12
18:51:02 ERROR : Flash Jetson TX2 : 5068: RAW: 163737600( 39975 blks) ==> 3608927660:163737612
18:51:02 ERROR : Flash Jetson TX2 : 5069: SKP: 4096( 1 blks) ==> 3772665272:12
18:51:02 ERROR : Flash Jetson TX2 : 5070: RAW: 77824( 19 blks) ==> 3772665284:77836
18:51:02 ERROR : Flash Jetson TX2 : 5071: SKP: 4096( 1 blks) ==> 3772743120:12
18:51:02 ERROR : Flash Jetson TX2 : 5072: RAW: 307200( 75 blks) ==> 3772743132:307212
18:51:02 ERROR : Flash Jetson TX2 : 5073: SKP: 4096( 1 blks) ==> 3773050344:12
18:51:02 ERROR : Flash Jetson TX2 : 5074: RAW: 585728( 143 blks) ==> 3773050356:585740
18:51:02 ERROR : Flash Jetson TX2 : 5075: SKP: 4096( 1 blks) ==> 3773636096:12
18:51:02 ERROR : Flash Jetson TX2 : 5076: RAW: 385024( 94 blks) ==> 3773636108:385036
18:51:05 ERROR : Flash Jetson TX2 : 5077: SKP: 1848156160( 451210 blks) ==> 3774021144:12
18:51:05 ERROR : Flash Jetson TX2 : 5078: RAW: 12288( 3 blks) ==> 3774021156:12300
18:51:05 ERROR : Flash Jetson TX2 : 5079: SKP: 53248( 13 blks) ==> 3774033456:12
18:51:05 ERROR : Flash Jetson TX2 : 5080: RAW: 12288( 3 blks) ==> 3774033468:12300
18:51:05 ERROR : Flash Jetson TX2 : 5081: SKP: 53248( 13 blks) ==> 3774045768:12
18:51:05 ERROR : Flash Jetson TX2 : 5082: RAW: 4857856( 1186 blks) ==> 3774045780:4857868
18:51:05 ERROR : Flash Jetson TX2 : 5083: SKP: 28696576( 7006 blks) ==> 3778903648:12
18:51:05 ERROR : Flash Jetson TX2 : 5084: RAW: 8380416( 2046 blks) ==> 3778903660:8380428
18:51:06 ERROR : Flash Jetson TX2 : 5085: SKP: 92151808( 22498 blks) ==> 3787284088:12
18:51:06 ERROR : Flash Jetson TX2 : 5086: RAW: 6860800( 1675 blks) ==> 3787284100:6860812
18:51:06 ERROR : Flash Jetson TX2 : 5087: SKP: 4096( 1 blks) ==> 3794144912:12
18:51:06 ERROR : Flash Jetson TX2 : 5088: RAW: 1617920( 395 blks) ==> 3794144924:1617932
18:51:06 ERROR : Flash Jetson TX2 : 5089: SKP: 4096( 1 blks) ==> 3795762856:12
18:51:06 ERROR : Flash Jetson TX2 : 5090: RAW: 44773376( 10931 blks) ==> 3795762868:44773388
18:51:06 ERROR : Flash Jetson TX2 : 5091: SKP: 4096( 1 blks) ==> 3840536256:12
18:51:07 ERROR : Flash Jetson TX2 : 5092: RAW: 135442432( 33067 blks) ==> 3840536268:135442444
18:51:07 ERROR : Flash Jetson TX2 : 5093: SKP: 4096( 1 blks) ==> 3975978712:12
18:51:07 ERROR : Flash Jetson TX2 : 5094: RAW: 4096( 1 blks) ==> 3975978724:4108
18:51:07 ERROR : Flash Jetson TX2 : 5095: SKP: 40960( 10 blks) ==> 3975982832:12
18:51:07 ERROR : Flash Jetson TX2 : 5096: RAW: 8192( 2 blks) ==> 3975982844:8204
18:51:07 ERROR : Flash Jetson TX2 : 5097: SKP: 4096( 1 blks) ==> 3975991048:12
18:51:07 ERROR : Flash Jetson TX2 : 5098: RAW: 11034624( 2694 blks) ==> 3975991060:11034636
18:51:07 ERROR : Flash Jetson TX2 : 5099: SKP: 4096( 1 blks) ==> 3987025696:12
18:51:07 ERROR : Flash Jetson TX2 : 5100: RAW: 59604992( 14552 blks) ==> 3987025708:59605004
18:51:10 ERROR : Flash Jetson TX2 : 5101: SKP: 1753853952( 428187 blks) ==> 4046630712:12
18:51:10 ERROR : Flash Jetson TX2 : 5102: RAW: 8192( 2 blks) ==> 4046630724:8204
18:51:10 ERROR : Flash Jetson TX2 : 5103: SKP: 57344( 14 blks) ==> 4046638928:12
18:51:10 ERROR : Flash Jetson TX2 : 5104: RAW: 8192( 2 blks) ==> 4046638940:8204
18:51:10 ERROR : Flash Jetson TX2 : 5105: SKP: 57344( 14 blks) ==> 4046647144:12
18:51:10 ERROR : Flash Jetson TX2 : 5106: RAW: 2138112( 522 blks) ==> 4046647156:2138124
18:51:10 ERROR : Flash Jetson TX2 : 5107: SKP: 31416320( 7670 blks) ==> 4048785280:12
18:51:10 ERROR : Flash Jetson TX2 : 5108: RAW: 7626752( 1862 blks) ==> 4048785292:7626764
18:51:10 ERROR : Flash Jetson TX2 : 5109: SKP: 92905472( 22682 blks) ==> 4056412056:12
18:51:10 ERROR : Flash Jetson TX2 : 5110: RAW: 5259264( 1284 blks) ==> 4056412068:5259276
18:51:10 ERROR : Flash Jetson TX2 : 5111: SKP: 4096( 1 blks) ==> 4061671344:12
18:51:10 ERROR : Flash Jetson TX2 : 5112: RAW: 1085440( 265 blks) ==> 4061671356:1085452
18:51:10 ERROR : Flash Jetson TX2 : 5113: SKP: 20480( 5 blks) ==> 4062756808:12
18:51:11 ERROR : Flash Jetson TX2 : 5114: RAW: 67133440( 16390 blks) ==> 4062756820:67133452
18:51:11 ERROR : Flash Jetson TX2 : 5115: SKP: 27160576( 6631 blks) ==> 4129890272:12
18:51:11 ERROR : Flash Jetson TX2 : 5116: RAW: 29360128( 7168 blks) ==> 4129890284:29360140
18:51:14 ERROR : Flash Jetson TX2 : 5117: SKP: 1883242496( 459776 blks) ==> 4159250424:12
18:51:14 ERROR : Flash Jetson TX2 : 5118: RAW: 8192( 2 blks) ==> 4159250436:8204
18:51:14 ERROR : Flash Jetson TX2 : 5119: SKP: 57344( 14 blks) ==> 4159258640:12
18:51:14 ERROR : Flash Jetson TX2 : 5120: RAW: 4096( 1 blks) ==> 4159258652:4108
18:51:14 ERROR : Flash Jetson TX2 : 5121: SKP: 61440( 15 blks) ==> 4159262760:12
18:51:14 ERROR : Flash Jetson TX2 : 5122: RAW: 1839104( 449 blks) ==> 4159262772:1839116
18:51:14 ERROR : Flash Jetson TX2 : 5123: SKP: 31715328( 7743 blks) ==> 4161101888:12
18:51:14 ERROR : Flash Jetson TX2 : 5124: RAW: 7442432( 1817 blks) ==> 4161101900:7442444
18:51:15 ERROR : Flash Jetson TX2 : 5125: SKP: 93089792( 22727 blks) ==> 4168544344:12
18:51:15 ERROR : Flash Jetson TX2 : 5126: RAW: 51339264( 12534 blks) ==> 4168544356:51339276
18:51:18 ERROR : Flash Jetson TX2 : 5127: SKP: 1961926656( 478986 blks) ==> 4219883632:12
18:51:18 ERROR : Flash Jetson TX2 : 5128: RAW: 16384( 4 blks) ==> 4219883644:16396
18:51:18 ERROR : Flash Jetson TX2 : 5129: SKP: 49152( 12 blks) ==> 4219900040:12
18:51:18 ERROR : Flash Jetson TX2 : 5130: RAW: 8192( 2 blks) ==> 4219900052:8204
18:51:18 ERROR : Flash Jetson TX2 : 5131: SKP: 57344( 14 blks) ==> 4219908256:12
18:51:18 ERROR : Flash Jetson TX2 : 5132: RAW: 2564096( 626 blks) ==> 4219908268:2564108
18:51:18 ERROR : Flash Jetson TX2 : 5133: SKP: 30990336( 7566 blks) ==> 4222472376:12
18:51:18 ERROR : Flash Jetson TX2 : 5134: RAW: 7589888( 1853 blks) ==> 4222472388:7589900
18:51:19 ERROR : Flash Jetson TX2 : 5135: SKP: 92942336( 22691 blks) ==> 4230062288:12
18:51:19 ERROR : Flash Jetson TX2 : 5136: RAW: 2101248( 513 blks) ==> 4230062300:2101260
18:51:19 ERROR : Flash Jetson TX2 : 5137: SKP: 4096( 1 blks) ==> 4232163560:12
18:51:19 ERROR : Flash Jetson TX2 : 5138: RAW: 5410816( 1321 blks) ==> 4232163572:5410828
18:51:19 ERROR : Flash Jetson TX2 : 5139: SKP: 4096( 1 blks) ==> 4237574400:12
18:51:19 ERROR : Flash Jetson TX2 : 5140: RAW: 36331520( 8870 blks) ==> 4237574412:36331532
18:51:19 ERROR : Flash Jetson TX2 : 5141: SKP: 4096( 1 blks) ==> 4273905944:12
18:51:20 ERROR : Flash Jetson TX2 : 5142: RAW: 190328832( 46467 blks) ==> 4273905956:190328844
18:51:20 ERROR : Flash Jetson TX2 : 5143: SKP: 8192( 2 blks) ==> 4464234800:12
18:51:20 ERROR : Flash Jetson TX2 : 5144: RAW: 425984( 104 blks) ==> 4464234812:425996
18:51:20 ERROR : Flash Jetson TX2 : 5145: SKP: 262144( 64 blks) ==> 4464660808:12
18:51:20 ERROR : Flash Jetson TX2 : 5146: RAW: 54870016( 13396 blks) ==> 4464660820:54870028
18:51:23 ERROR : Flash Jetson TX2 : 5147: SKP: 1723514880( 420780 blks) ==> 4519530848:12
18:51:23 ERROR : Flash Jetson TX2 : 5148: RAW: 8192( 2 blks) ==> 4519530860:8204
18:51:23 ERROR : Flash Jetson TX2 : 5149: SKP: 57344( 14 blks) ==> 4519539064:12
18:51:23 ERROR : Flash Jetson TX2 : 5150: RAW: 4096( 1 blks) ==> 4519539076:4108
18:51:23 ERROR : Flash Jetson TX2 : 5151: SKP: 61440( 15 blks) ==> 4519543184:12
18:51:23 ERROR : Flash Jetson TX2 : 5152: RAW: 2043904( 499 blks) ==> 4519543196:2043916
18:51:23 ERROR : Flash Jetson TX2 : 5153: SKP: 31510528( 7693 blks) ==> 4521587112:12
18:51:23 ERROR : Flash Jetson TX2 : 5154: RAW: 7335936( 1791 blks) ==> 4521587124:7335948
18:51:23 ERROR : Flash Jetson TX2 : 5155: SKP: 93196288( 22753 blks) ==> 4528923072:12
18:51:23 ERROR : Flash Jetson TX2 : 5156: RAW: 43102208( 10523 blks) ==> 4528923084:43102220
18:51:26 ERROR : Flash Jetson TX2 : 5157: SKP: 1970163712( 480997 blks) ==> 4572025304:12
18:51:28 ERROR : Flash Jetson TX2 : – Total:
18:51:28 ERROR : Flash Jetson TX2 : ---------------------------------------------------
18:51:28 ERROR : Flash Jetson TX2 : 5158 CHUNK 30064771072(7340032 blks) ==> 4572025316(1116202 blks)
18:51:28 INFO : Flash Jetson TX2 : done.
18:51:28 INFO : Flash Jetson TX2 : system.img built successfully.
18:51:28 INFO : Flash Jetson TX2 : Existing tbcfile(/home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
18:51:28 INFO : Flash Jetson TX2 : copying tbcdtbfile(/home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
18:51:31 INFO : Flash Jetson TX2 : copying cfgfile(/home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
18:51:31 INFO : Flash Jetson TX2 : Existing flasher(/home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
18:51:31 INFO : Flash Jetson TX2 : Existing flashapp(/home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
18:51:31 INFO : Flash Jetson TX2 : ./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb”
18:51:31 INFO : Flash Jetson TX2 : saving flash command in /home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/flashcmd.txt
18:51:31 INFO : Flash Jetson TX2 : saving Windows flash command to /home/ramesh/Downloads/sdk/JetPack_4.3_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/flash_win.bat
18:51:31 INFO : Flash Jetson TX2 : *** Flashing target device started. ***
18:51:32 INFO : Flash Jetson TX2 : Welcome to Tegra Flash
18:51:32 INFO : Flash Jetson TX2 : version 1.0.0
18:51:32 INFO : Flash Jetson TX2 : Type ? or help for help and q or quit to exit
18:51:32 INFO : Flash Jetson TX2 : Use ! to execute system commands
18:51:32 INFO : Flash Jetson TX2 : [ 0.0207 ] tegrasign_v2 --key None --getmode mode.txt
18:51:32 INFO : Flash Jetson TX2 : [ 0.0223 ] Assuming zero filled SBK key
18:51:32 INFO : Flash Jetson TX2 : [ 0.0326 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.0327 ] Generating RCM messages
18:51:32 INFO : Flash Jetson TX2 : [ 0.0489 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
18:51:32 INFO : Flash Jetson TX2 : [ 0.0505 ] RCM 0 is saved as rcm_0.rcm
18:51:32 INFO : Flash Jetson TX2 : [ 0.0528 ] RCM 1 is saved as rcm_1.rcm
18:51:32 INFO : Flash Jetson TX2 : [ 0.0532 ] List of rcm files are saved in rcm_list.xml
18:51:32 INFO : Flash Jetson TX2 : [ 0.0644 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.0644 ] Signing RCM messages
18:51:32 INFO : Flash Jetson TX2 : [ 0.0657 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
18:51:32 INFO : Flash Jetson TX2 : [ 0.0670 ] Assuming zero filled SBK key
18:51:32 INFO : Flash Jetson TX2 : [ 0.1006 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.1006 ] Copying signature to RCM mesages
18:51:32 INFO : Flash Jetson TX2 : [ 0.1018 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
18:51:32 INFO : Flash Jetson TX2 : [ 0.1463 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.1463 ] Parsing partition layout
18:51:32 INFO : Flash Jetson TX2 : [ 0.1538 ] tegraparser_v2 --pt flash.xml.tmp
18:51:32 INFO : Flash Jetson TX2 : [ 0.1927 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.1927 ] Creating list of images to be signed
18:51:32 INFO : Flash Jetson TX2 : [ 0.1950 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
18:51:32 INFO : Flash Jetson TX2 : [ 0.3166 ]
18:51:32 INFO : Flash Jetson TX2 : [ 0.3166 ] Generating signatures
18:51:32 INFO : Flash Jetson TX2 : [ 0.3178 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
18:51:32 INFO : Flash Jetson TX2 : [ 0.3191 ] Assuming zero filled SBK key
18:51:33 INFO : Flash Jetson TX2 : [ 1.0672 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.0672 ] Generating br-bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.0698 ] Updating dev and MSS params in BR BCT
18:51:33 INFO : Flash Jetson TX2 : [ 1.0699 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
18:51:33 INFO : Flash Jetson TX2 : [ 1.1419 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.1419 ] Updating bl info
18:51:33 INFO : Flash Jetson TX2 : [ 1.1432 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
18:51:33 INFO : Flash Jetson TX2 : [ 1.1595 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.1595 ] Updating smd info
18:51:33 INFO : Flash Jetson TX2 : [ 1.1634 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
18:51:33 INFO : Flash Jetson TX2 : [ 1.1833 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.1834 ] Updating Odmdata
18:51:33 INFO : Flash Jetson TX2 : [ 1.1846 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
18:51:33 INFO : Flash Jetson TX2 : [ 1.1966 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.1966 ] Get Signed section of bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.1978 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
18:51:33 INFO : Flash Jetson TX2 : [ 1.2111 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.2168 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
18:51:33 INFO : Flash Jetson TX2 : [ 1.2181 ] Assuming zero filled SBK key
18:51:33 INFO : Flash Jetson TX2 : [ 1.2314 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.2314 ] Updating BCT with signature
18:51:33 INFO : Flash Jetson TX2 : [ 1.2327 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
18:51:33 INFO : Flash Jetson TX2 : [ 1.2523 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.2524 ] Generating coldboot mb1-bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.2536 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.2574 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.2577 ] Copying Sdram info from 2 to 3 set
18:51:33 INFO : Flash Jetson TX2 : [ 1.3273 ] Packing sdram param for instance[0]
18:51:33 INFO : Flash Jetson TX2 : [ 1.3282 ] Packing sdram param for instance[1]
18:51:33 INFO : Flash Jetson TX2 : [ 1.3330 ] Packing sdram param for instance[2]
18:51:33 INFO : Flash Jetson TX2 : [ 1.3365 ] Packing sdram param for instance[3]
18:51:33 INFO : Flash Jetson TX2 : [ 1.3566 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3574 ] Appending platform config data of size :- 3032
18:51:33 INFO : Flash Jetson TX2 : [ 1.3593 ] Parsing config file :mobile_scr.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3603 ] Appending platform config data of size :- 12240
18:51:33 INFO : Flash Jetson TX2 : [ 1.3636 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3685 ] Appending platform config data of size :- 24
18:51:33 INFO : Flash Jetson TX2 : [ 1.3723 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3732 ] Appending platform config data of size :- 672
18:51:33 INFO : Flash Jetson TX2 : [ 1.3733 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3733 ] Appending platform config data of size :- 64
18:51:33 INFO : Flash Jetson TX2 : [ 1.3733 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.3733 ] Appending platform config data of size :- 1628
18:51:33 INFO : Flash Jetson TX2 : [ 1.3733 ] Updating mb1-bct with firmware information
18:51:33 INFO : Flash Jetson TX2 : [ 1.3744 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
18:51:33 INFO : Flash Jetson TX2 : [ 1.3790 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.3883 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.3884 ] Updating mb1-bct with storage information
18:51:33 INFO : Flash Jetson TX2 : [ 1.3896 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
18:51:33 INFO : Flash Jetson TX2 : [ 1.3930 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.4098 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.4112 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.4242 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.4255 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
18:51:33 INFO : Flash Jetson TX2 : [ 1.4446 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.4462 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
18:51:33 INFO : Flash Jetson TX2 : [ 1.4491 ] Assuming zero filled SBK key
18:51:33 INFO : Flash Jetson TX2 : [ 1.4654 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.4730 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
18:51:33 INFO : Flash Jetson TX2 : [ 1.4803 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.4804 ] Generating recovery mb1-bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.4816 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.4855 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.4858 ] Copying Sdram info from 2 to 3 set
18:51:33 INFO : Flash Jetson TX2 : [ 1.5393 ] Packing sdram param for instance[0]
18:51:33 INFO : Flash Jetson TX2 : [ 1.5410 ] Packing sdram param for instance[1]
18:51:33 INFO : Flash Jetson TX2 : [ 1.5419 ] Packing sdram param for instance[2]
18:51:33 INFO : Flash Jetson TX2 : [ 1.5440 ] Packing sdram param for instance[3]
18:51:33 INFO : Flash Jetson TX2 : [ 1.5455 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5503 ] Appending platform config data of size :- 3032
18:51:33 INFO : Flash Jetson TX2 : [ 1.5531 ] Parsing config file :minimal_scr.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5538 ] Appending platform config data of size :- 12240
18:51:33 INFO : Flash Jetson TX2 : [ 1.5806 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5806 ] Appending platform config data of size :- 24
18:51:33 INFO : Flash Jetson TX2 : [ 1.5806 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5806 ] Appending platform config data of size :- 672
18:51:33 INFO : Flash Jetson TX2 : [ 1.5807 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5807 ] Appending platform config data of size :- 64
18:51:33 INFO : Flash Jetson TX2 : [ 1.5807 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
18:51:33 INFO : Flash Jetson TX2 : [ 1.5807 ] Appending platform config data of size :- 1628
18:51:33 INFO : Flash Jetson TX2 : [ 1.5807 ] Updating mb1-bct with firmware information
18:51:33 INFO : Flash Jetson TX2 : [ 1.5819 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
18:51:33 INFO : Flash Jetson TX2 : [ 1.5856 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.5958 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.5958 ] Updating mb1-bct with storage information
18:51:33 INFO : Flash Jetson TX2 : [ 1.5970 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
18:51:33 INFO : Flash Jetson TX2 : [ 1.6012 ] MB1-BCT version: 0xf
18:51:33 INFO : Flash Jetson TX2 : [ 1.6123 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.6135 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
18:51:33 INFO : Flash Jetson TX2 : [ 1.6363 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.6375 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
18:51:33 INFO : Flash Jetson TX2 : [ 1.6513 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.6529 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
18:51:33 INFO : Flash Jetson TX2 : [ 1.6574 ] Assuming zero filled SBK key
18:51:33 INFO : Flash Jetson TX2 : [ 1.6723 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.6739 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
18:51:33 INFO : Flash Jetson TX2 : [ 1.6923 ]
18:51:33 INFO : Flash Jetson TX2 : [ 1.6924 ] Copying signatures
18:51:33 INFO : Flash Jetson TX2 : [ 1.6936 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
/home/ramesh/Downloads/nvidia
You can ignore the “ERROR” in the creation of the sparse image where it has all of the log lines which look like this:
However, those final lines are of course fatal to flashing:
This particular error can happen for other reasons, but by far the most common reason is having a host which is a VM. Sometimes it is from using charger cables instead of a quality micro-B USB cable.
Is your host a VM? If not, do you have other brands of micro-B USB cables available? About 4 out of 5 micro-B USB cables out on the market (usually with the “OTG” label) will fail at some point in the flash, and a cable which actually advertises as being for data and not marketed as a charger cable tend to be your best bet if you do not have one provided by NVIDIA.
HI Linuxdev,
I was using Virtual Box with 16.04, then it was not working.
Now i have changed to VMWare, and i have flashed the device. But on the TX2, after flashing, to install the SDK componets the keyboard and Mouse are not detecting.
So i have struck at installing the components on Tx2 now.
failed to setup -xusb ports: -517
This could be an issue with a VM if this is from host side. However, it sounds like this is probably on the Jetson side. This could be from an incorrect board support package (such as from a third party carrier board), whereby the hardware is perfectly functional, but the module does not know how to correctly find the USB hardware. Are you using the version of the BSP from that manufacturer which corresponds to the specific release being flashed?
Hi
I have successfully installed the New Jetpack Using VMWare.
When i use the Virtual box it is giving errors.
Thank you for the suggestions
