I get the following weird result when compiling a little test program to see if type extension works.
c:\cygwin\home\pkrysl\f>pgfortran u.f90
NOTE: your trial license will expire in 13 days, 9.33 hours.
PGF90-S-0188-Argument number 1 to id: type mismatch (u.f90: 108)
PGF90-S-0188-Argument number 1 to nfens: type mismatch (u.f90: 108)
PGF90-S-0188-Argument number 1 to conn: type mismatch (u.f90: 108)
0 inform, 0 warnings, 3 severes, 0 fatal for test
Here are my modules and the test program:
module kinds_module
integer, parameter :: integer_kind =SELECTED_INT_KIND(9)
real, parameter :: real_kind =SELECTED_REAL_KIND(15)
end module
module gcellset_module
use kinds_module
implicit none
private
public:: gcellset_type, make_gcellset, constructor, nfens, id, conn
type gcellset_type
private
integer (integer_kind) :: id
integer (integer_kind), allocatable :: conn(:,:)
end type gcellset_type
interface constructor
procedure make_gcellset
end interface
contains
subroutine make_gcellset(gcells,conn,id)
type (gcellset_type), intent(out) :: gcells
integer (integer_kind), intent(in) :: conn(:,:)
integer (integer_kind), intent(in), optional :: id
gcells%id=1
allocate(gcells %conn(size(conn,1),size(conn,2)))
gcells%conn=conn
end subroutine
function id(gcells) result(n)
type (gcellset_type), intent(in) :: gcells
integer (integer_kind) :: n
n=gcells%id
end function
function nfens(gcells) result(n)
n= size(gcells%conn,1)
end function
function conn(gcells,range) result(n)
integer (integer_kind), intent(in) :: range(:)
integer (integer_kind) :: n(size(range),size(gcells%conn,2))
n=gcells%conn(range,:)
end function
end module
module gcellset_3_manifold_module
use kinds_module
use gcellset_module
implicit none
private
public:: gcellset_3_manifold_type, make_gcellset_3_manifold, constructor, manifdim
type, extends(gcellset_type) :: gcellset_3_manifold_type
end type
procedure make_gcellset_3_manifold
end interface
contains
subroutine make_gcellset_3_manifold(gcells,conn,id)
type (gcellset_3_manifold_type), intent(out) :: gcells
call make_gcellset(gcells,conn,id)
end subroutine
function manifdim(gcells) result(n)
type (gcellset_3_manifold_type), intent(in) :: gcells
n=3
end function
end module
program test
use kinds_module
use gcellset_module
use gcellset_3_manifold_module
implicit none
type (gcellset_3_manifold_type) :: gcells
integer (integer_kind) :: conns(3,2)
data conns /1, 2,2,3,3,4/
integer (integer_kind) :: range(1)
data range /2/
call make_gcellset_3_manifold(gcells,conns,1)
print *,‘Here id=’,id(gcells),’ nfens=‘,nfens(gcells),’ conn=',conn(gcells,range)
end program test
I would have thought that the function nfens should be fine with the actual argument being gcellset_3_manifold_type since it extends gcellset_type!? Am I doing something wrong?
Thank you for your help,
Petr Krysl
