U-BOOT EMMC backup restoration
Good afternoon, dear Nvidia! I tried to create and then restore a backup from u-boot but I failed and don’t know why. Does you EMMC somehow protected from u-boot rewriting?
How we could know from u-boot - rootfs is the first part from 0x22 to 0x1c00022:
Tegra210 (P3450-0000) # mmc part
Partition Map for MMC device 0  --   Partition Type: EFI
Part	Start LBA	End LBA		Name
	Attributes
	Type GUID
	Partition GUID
  1	0x00000022	0x01c00021	"APP"
	attrs:	0x0000000000000000
	type:	ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
	guid:	14a5f991-9656-4668-8b02-0657086f6f63
  2	0x01c00022	0x01c00821	"DTB"
	guid:	4730a397-7700-4a53-8f9c-2332c2ec7d09
  3	0x01c00822	0x01c03821	"TOS"
	guid:	09422f1f-09c5-434b-ba7c-ab4efdc80822
  4	0x01c03822	0x01c23801	"LNX"
	guid:	3bc726a2-6f0e-4c35-a0e8-1e65a47e405c
  5	0x01c23802	0x01c24001	"DTB-1"
	guid:	6e8905df-bad5-41ec-ab94-2b3b5f178c03
  6	0x01c24002	0x01c27001	"TOS-1"
	guid:	2799eb78-af34-4c70-a198-690cacb3e76d
  7	0x01c27002	0x01c46fe1	"LNX-1"
	guid:	3ee20a91-f01f-43a4-85df-7705b4cef47f
  8	0x01c46fe2	0x01c471e1	"RP4"
	guid:	5293f83d-277e-4bdb-9a9c-0522cef13967
  9	0x01c471e2	0x01d59fde	"UDA"
	guid:	4243bdd5-9ee5-490b-9760-a94a6c617409
I backuped this with such a script:
usb start
usb storage
usb dev 0
setenv emmc_start 0x22
setenv emmc_end   0x1c00022
setenv load_addr  0x100000000
setenv block_size 0x40000000
setenv file_prefix "/backup_part_"
setenv current_sector ${emmc_start}
setenv current_offset 0
setenv part_num 0
setenv error 0
while itest ${current_sector} < ${emmc_end}; do
    setexpr sectors_to_write ${block_size} / 0x200
    mmc read ${load_addr} ${current_sector} ${sectors_to_write}
    if test $? -ne 0; then
        echo "Error reading block from eMMC"
        setenv error 1
        exit
    fi
    setenv current_file "${file_prefix}${part_num}.bin"
    ext4write usb 0:1 ${load_addr} ${current_file} ${block_size} 0
        echo "Error writing block to USB"
        setenv error 1
        exit
    fi
    setexpr current_sector ${current_sector} + ${sectors_to_write}
    setexpr current_offset ${current_offset} + ${block_size}
    setexpr part_num ${part_num} + 1
    echo "Copied to offset: ${current_offset}"
done
if test ${error} -eq 1; then
    echo "Copy process failed."
else
    echo "Copy process completed successfully."
fi
I gained this files and then combined it with cat:
ls                                               ✔  10s 
backup_part_00.bin  backup_part_04.bin  backup_part_08.bin  backup_part_12.bin
backup_part_01.bin  backup_part_05.bin  backup_part_09.bin  backup_part_13.bin
backup_part_02.bin  backup_part_06.bin  backup_part_10.bin
backup_part_03.bin  backup_part_07.bin  backup_part_11.bin
cat backup_part_*.bin > backup.bin
Then I try to restore this with such a script but all my EMMC turns to ashes inside:
usb start
usb storage
usb dev 0
setenv usb_start  0
setenv current_offset ${usb_start}
setenv error 0
    ext4load usb 0:1 ${load_addr} backup.bin ${block_size} ${current_offset}
        echo "Error loading block from USB"
        setenv error 1
        exit
    fi
    mmc write ${load_addr} ${current_sector} ${sectors_to_write}
        echo "Error writing block to eMMC"
        setenv error 1
        exit
    fi
    echo "Copied to sector: ${current_sector}"
done
else
fi
What do you think, why is this appears?
Sorry for the late response.
Yes it is still an issue - I froze this task until you will answer me)
Hi ATAineri,
Are you using the devkit or custom board for Jetson Nano?
Sorry that I’m not clear about your use case.
Are you trying to backup the internal eMMC?
If so, have you referred to README_backup_restore.txt?
I’m using 32.7.5 version and it is not matter what the board because of I’m not using any peripheral devices, only onboard EMMC.
No I have not read - where could I find it? The main idea that I have to reflash EMMC without any PC using, only with the board. If it is any mechanisms for it - I will be glad to use it. I saw that there was place for it in SDK but it was not finished and it marked as TODO in the .sh file.
We just want to know your status and check if we can verify them locally.
It should be included in the BSP package on your host (<Linux_for_Tegra>/tools/backup_restore/README_backup_restore.txt)
Do you mean that you want to use one Jetson Nano to flash another Jetson Nano w/o using x86 host PC?
No I want to restore rootfs from USB flash without using anything else, from U-BOOT.
It seems we don’t support this use case on Jetson Nano.
